10-07-2010 07:54 AM - edited 07-03-2021 07:15 PM
I recently enabled multicast on the wireless to a VLAN that only has one SSID(Private) but for some reason when i go to monitor>multicast on the controller i see that there are clients on the same multicast group on another VLAN (Guest) which i didnt enable multicast on and it doesnt have the same SSID as the other one.
I was wondering if this suppose to work this way.
Thank you
Vic
10-07-2010 08:57 AM
When you say you didn't enable multicast on, are you meaninig that you didn't PIM enable that VLAN?
on the WLC, did you enable multicast > multicast or multicast > unicast ?
for multicast > multicast did you give an "private" 239.x.x.x address ?
10-07-2010 09:33 AM
That's correct
Multicast
239.255.255.250
