04-19-2013 10:38 AM - edited 07-03-2021 11:56 PM
I have Cisco 1040 model ap's and now Cisco 1600 ap models that I have up add an LWAPP entry to the dhcpd.conf file to allow the AP's to boot to the controller.
Exisiting:
option space LWAPP;
option LWAPP.controller code 241 = array of ip-address;
class "LWAPP" {
match option vendor-class-identifier;
subclass "LWAPP" "Cisco AP c1040" {
vendor-option-space LWAPP;
option LWAPP.controller IP.of.controller;
With another model added:
option space LWAPP;
class "LWAPP" {
subclass "LWAPP" "Cisco AP c1600" {
Just wondering if this is the configuration or do I need to double all the confirutation, with each subclass going with it's own option space / class paragraph.
Thanks in advance.
Matt
Solved! Go to Solution.
04-19-2013 02:58 PM
Here is the thing.... if you have one WLC, forget using option 43 and use DNS. Create a record that will resolve cisco-capwap-controller.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
04-19-2013 03:34 PM
Looks like option 43 is already defined on your script.
https://supportforums.cisco.com/message/1272318#1272318
04-19-2013 12:02 PM
If you have one WLC, you don't need option 60 as that is optional. Only use it if you want certain model AP's to connect to a certain WLC.
Scott
11-13-2015 06:00 AM
We have multiple WLC for different customers but we are using a central DHCP server under ISC DHCPD.
I tried this configuration:
option space LWAPP;
class "LWAPP" {
subnet x.x.x.0 netmask 255.255.255.192 {
authoritative;
option routers x.x.x.1;
option subnet-mask 255.255.255.192;
default-lease-time 600;
option domain-name "scrl.local";
option domain-name-servers x.x.x.x, x.x.x.x;
range dynamic-bootp x.x.x.10 x.x.x.30;
max-lease-time 7200;
subclass "LWAPP" "Cisco AP c3700" {
option LWAPP.controller x.x.x.44;
subclass "LWAPP" "Cisco AP c2700" {
subnet y.y.y.0 netmask 255.255.255.192 {
authoritative;
option routers y.y.y.1;
range dynamic-bootp y.y.y.10 y.y.y.30;
option LWAPP.controller y.y.y.50;
The Access point receives well the right IP addres from the pool but the IP address of the controller is "y.y.y.50" instead of "x.x.x.44"...
Do you have an idea? If I put "x.x.x.44" in the other pool I get the right IP for the controller... it's strange.
Version of the ISC DHCPD: Internet Systems Consortium DHCP Server 4.3.1
Thks.
Lionel
04-19-2013 12:13 PM
Thanks Scott
Any suggestion what syntax I would use to have all ap's that boot go to one particular controller?
Matt
04-19-2013 12:17 PM
I don't know the syntax, but you need to only use option 43.
04-19-2013 02:58 PM
Scott
04-19-2013 03:26 PM
Thanks Scott in some sites we have 155 sites that report back to the master controller and the server entry we do use some sites just use a simple DNs server that is Linux will have to figure out option 43! Lol
Thanks for all your help Scott
M
04-19-2013 03:31 PM
Yeah I was stuck on an install where the customers guy who management their Linux dhcp and DNS retired. Well dhcp was a pain and we ended up figuring out how to setup the DNS.
04-19-2013 03:34 PM
04-19-2013 03:37 PM
Bingo I see what I need here with one of the bottom lwapp line, this is exactly what I am looking for! Thanks so much for that!
04-19-2013 03:45 PM
No problem.
