2864
Beginner
Multiple Client Deauthentication & Association Issues
Hello all.
I've been experiencing a problem at a customer's site in which all the wireless devices at some point or another appear to have connectivity problems.  I am using a single, centrally-located AIR-AP1041N-A-K9 access point.  There are about six (6) client devices connecting to the AP that are using either Windows XP Pro or Windows 7 Pro.  I am constantly receiving logs similar to the following for these clients:
May  2 15:05:15.443: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec55.f9c3.d67d Reason: Previous authentication no longer valid
May  2 15:05:17.179: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  ec55.f9c3.d67d Reassociated KEY_MGMT[WPAv2 PSK]
May  2 15:05:22.444: %DOT11-4-CCMP_REPLAY: Client ec55.f9c3.d67d had 1 AES-CCMP TSC replays
May  2 15:05:22.445: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001e.6555.87ea Reason: Previous authentication no longer valid
May  2 15:05:22.541: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   001e.6555.87ea Associated KEY_MGMT[WPAv2 PSK]
May  2 15:05:50.448: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec55.f9c3.d000 Reason: Previous authentication no longer valid
May  2 15:05:52.182: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  ec55.f9c3.d000 Reassociated KEY_MGMT[WPAv2 PSK]
May  2 15:05:57.450: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001e.652a.08a6 Reason: Previous authentication no longer valid
May  2 15:05:57.543: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   001e.652a.08a6 Associated KEY_MGMT[WPAv2 PSK]
May  2 15:05:59.452: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station ec55.f9c3.d67d Reason: Previous authentication no longer valid
May  2 15:06:00.451: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f008.f165.6019 Reason: Previous authentication no longer valid
May  2 15:06:01.149: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  ec55.f9c3.d67d Reassociated KEY_MGMT[WPAv2 PSK]
May  2 15:06:05.162: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f008.f165.6019 Associated KEY_MGMT[WPAv2 PSK]
As a result, clients occasionally lose connectivity and the locally-hosted application crashes on their laptops (eClinicalWorks is the application they are using).  I have tried changing the channel from 1 to 6 but this didn't resolve issues.  I also borrowed and ran a spectrum analyzer at the location but I couldn't find any intereference devices.  I have made sure that drivers on the laptops are updated.
Any advice would be greatly appreciated.
6 REPLIES 6
I've had similar issues in the past. My problem was specific to interference. It sounds like you did a sweep. Did you do the sweep at the same time a device had this behavior. Are all the devices or some of the devices behaving like this at the same time ?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Beginner
Hello George.
I used AirMagnet Spectrum Analyzer to perform a sweep of the facility.  The only intereferer that I could find was the Microwave Oven(s) when they were running.  Unfortunately, I only did the one sweep and I did not do it while they were experiencing issues.  Furthermore, I no longer have the tool available as I was borrowing it.
Some devices seem to have more problems that others.  I had one computer in particular that was dropping off the network very badly.  I found that the drivers were up-to-date and I tried uninstalling and reinstalling the wireless NIC.  I also tried turning off all other startup and services that weren't necessary.  These methods did not improve problem.  Is there a free tool available to determine if there is a wireless intereference issue happening at the site?
Here are a few ideas.
* Meta Geek has a really good inexpensive spectrum analyzer as an alternative it is called WiSpy
* Do you have proper cell sizing ? Your clients aren't dropping because lack of signal ?
* What clients, nic models and driver ar you using ?
* Are you doing 802.11n at 40 Mhz channels ?
* Can you post an example of your config ?
Beginner
Re: Multiple Client Deauthentication & Association Issues
I've heard of that tool before but I've never personally used it.  I will look into it.
The single AP is supporting a building that is 50 ft x 75 ft.  The building is partitioned rooms (doctor's practice).  I did a quick survey before installing the AP and I found the weakest areas had a signal of -65dB.  When I've looked at the connected clients on the AP, I have seen their signals range from -44dB to -70dB.  It doesn't seem to make a difference on the signal level as the clients drop off the network regardless.
The XP Pro client machines are using Intel WiFi Link 5100AGN adapters.  The drivers are from 2008/12/22 (12.4.0.21).
The 7 Pro client machines are using ThinkPad 1x1 11b/g/n Wireless LAN PCI Express Half Mini Card Adapter.  The drivers are from 2012/05/13 (these are the latest drivers available 1005.32.306.2012).  These machines seem to have the most connection problems.
This AP only supports 2.4GHz frequency.  I can only set the channel at 20MHz.
Here you go
Littell-1041N-WAP#sh run
Building configuration...
Current configuration : 2008 bytes
! Last configuration change at 10:59:46 -0400 Fri May 3 2013 by admin
! NVRAM config last updated at 13:30:21 -0400 Fri May 3 2013 by admin
version 15.2
no service pad
service timestamps log datetime localtime
service password-encryption
hostname Littell-1041N-WAP
logging rate-limit console 9
enable secret 5 <>
no aaa new-model
clock timezone -0500 -5 0
clock summer-time -0400 recurring
ip cef
dot11 syslog
dot11 ssid Littell
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 <>
dot11 wpa handshake timeout 1000
username admin privilege 15 password 7 <>
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid Littell
antenna gain 0
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
packet retries 128 drop-packet
channel 2437
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.1.253 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
sntp server 192.168.1.103
sntp broadcast client
end
Enthusiast
I would suggest adjusting your basic data rate to something other than 1Mbps, perhaps 11Mbps, or a non DSSS/HR-DSSS rate like 6, 9, or 12 (if you want to prevent 802.11b clients).  This is probably not contributing to the behavior you're experiencing, but that's a very slow data rate to be mandatory and used for all management/control traffic and is wasteful of the airtime.
Also, be careful when posting your configs.   You did remove the local credentials, but you have essentially put the PSK of your customer's WLAN out for anyone to decrypt very easily.
As far as the interference and client behavior, can you post the output of your radio interface?
#show controller d0
Beginner
Here you go....
Littell-1041N-WAP#sh controllers d0
Radio AIR-AP1140G, Base Address b4e9.b010.ac40, BBlock version 0.00, Software version 4.10.1
Serial number: FOC16515BLL
Unused dynamic SQRAM memory: 0x00002B4C (10 KB)
Unused dynamic SDRAM memory: 0x00074B14 (466 KB)
Number of supported simultaneous BSSID on Dot11Radio0: 16
Carrier Set: Americas (US) (-A)
Uniform Spreading Required: No
Configured Frequency: 2437 MHz  Channel 6
Allowed Frequencies:
     2412(  1)  2417(  2)  2422(  3)  2427(  4)  2432(  5)  2437(  6)  2442(  7)  2447(  8)  2452(  9)  2457( 10)
     2462( 11)
Listen Frequencies:
     2462( 11)  2467( 12)  2472( 13)  2484( 14)
Beacon Flags: 0, Interface Flags 20105, Interface Events 0, Mode 9; Beacons are enabled; Probes are enabled
Antenna:            Rx[right-a left-b ]
                Tx[right-a left-b  cck single ofdm all]
--More--
                Internal
                Gain [Allowed 8, Reported 0, Configured 0, In Use 8]  (dBi x 2)
Configured TxPower:        20 dBm
Allowed Power Levels:        20 17 14 11 8 5 2 -1  dBm
Allowed Client Power Levels:    20 17 14 11 8 5 2 -1  dBm
Active Rates:  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Current Rates:  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Allowed Rates:  1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
All Rates:  1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Default Rates:  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Best Range Rates:  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Best Throughput Rates:  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
--More--                           Current Voice Rates:  basic-5.5 basic-11.0 6.0 12.0 24.0 [disabled until voice packet-discard enabled]
Default Voice Rates:  basic-5.5 basic-11.0 6.0 12.0 24.0
Managment Rates:  basic-1.0
Multicast Rates:  basic-1.0
Multicast Active rate: 1.0
RTS Rates:  basic-1.0
RTS Active rate 1.0
RTS Max rate 1.0
Local Packet Rate Probing is disabled : Packet Size 1
Data Rate Sensitivity (rate, SNR dB, Contention dBm)
( 1.0, 10, -93)   ( 2.0, 10, -92)   ( 5.5, 11, -90)   (11.0, 14, -90)
( 6.0, 15, -89)   ( 9.0, 16, -88)   (12.0, 18, -88)   (18.0, 19, -86)
(24.0, 20, -85)   (36.0, 24, -81)   (48.0, 27, -78)   (54.0, 31, -77)
ERP settings: short slot time.
Neighbors in non-erp mode:
TX A-MPDU Priority: 0x31 A-MSDU Priority 0x3F
RIFS 0
Guard-Interval: Any
HT protection: HT (no protection).
Neighbors with non-HT members:
--More--                           Number of MFP Indices: 10
RFID Tag Detection: Disabled
Multicast Address filtered:
Packet type filtered:
00 0C rm_scn
Probe limit: active off, filter on, count 0, time 0
Assoc limit: active off, count 0, time 0
GAS Req limit: active off, count 0, time 0
Radio Management (RM) Configuration: Regular AP, Mode 1, Disabled
ELM Disabled, Promiscuous Mode dwelling 0 %
MCST RSCs: [0]0x0 [1]0x0 [2]0x0 [3]0x0 [4]0x0 [5]0x0 [6]0x0 [7]0x0 [8]0x0
TKIP Cum Stats: STA            MIC-L-Errs MIC-R-Errs Replay   C-Measure
                0000.0000.0000 00000000   00000000   00000000 00000000
AES-CCMP Cum Stats: 00001266 replays discarded
Channel Utilization Extensions: Disabled
SMPS Mode: Enabled
QBSS Load: 0x3, Policing Stats: Rx downgrades 0, Tx downgrades 0
Classifier Stats tx_on_up6  0, tx_on_up4 0
Configured Local Access Class Parameters
  Back      : cw-min 4 cw-max 10 fixed-slot 7 admission-control Off txop 0
  Best      : cw-min 4 cw-max 6 fixed-slot 3 admission-control Off txop 0
  Video     : cw-min 3 cw-max 4 fixed-slot 1 admission-control Off txop 3008
--More--                             Voice     : cw-min 2 cw-max 3 fixed-slot 1 admission-control Off txop 1504
Configured Local Custom Access Class Parameters
  Best      : cw-min 1 cw-max 2 fixed-slot 1 admission-control Off txop 0
Configured Cell Access Class Parameters
  Best      : cw-min 4 cw-max 10 fixed-slot 3 admission-control Off txop 0
  Video     : cw-min 3 cw-max 4 fixed-slot 2 admission-control Off txop 3008
  Voice     : cw-min 2 cw-max 3 fixed-slot 2 admission-control Off txop 1504
SIP stats sip_udp_rx_pkt 0, sip_tcp_rx_pkt 0,downlink classified_pkt 0,uplink classified_pkt 0,num_processed_SIP_Calls 0
Off Channel Rdy 0 Done 0 0 0
Transmit queues: Limit 2264 Current 0 In-Progress 0 AMSDU In-Progress 0 APSD In-Progress 0
       ---- Active --- In-Progress --------------- Counts --------------
        Cnt  Quo  Bas  Max  Cnt  Quo  Bas       Sent   Discard  Fail    Retry  Multi
Uplink    0    0    0    0    0    0    0          0         0     0        0      0
Voice     0    1 1509    1    0    1  300      46517         0    31     4758    301
--More--                           Video     0    0    0    0    0    0    0          0         0     0        0      0
Best      0    3  754    3    0    3  150     714780       407    16    42242  18458
MC0       0    0    0    0    0    0    0     257487     30503     0        0      0
Back      0    0    0    0    0    0    0          0         0     0        0      0
BSSIDS Index Flags State Next Held Defer NonDefer Clients Tsf Dtim  Txq
  AC40     0    20     5    0    0     0        0       1   0    2   0e
Driver TX blocks: in use 0, high 0, at reset 0, fail 0 drop 0
Off Channel Stats: Last Duration 0, Errors: Timeouts 0 Tx 0 Intr 0
---Clients 0  AID VLAN Status:S/I/B/A Age TxQ-R(A) Mode Enc Key  Rate  Mask Tx   Rx   BVI   Split-ACL
ec55.f9c3.d000    3    0 00 40140 000 07E 6    0-0 (0) 33B0 200 0-10 1EFFFF0000 0207 107
001e.6529.f8ba    5    0 00 40140 000 07E 39   0-0 (0) 33B0 200 0-10 1EFFFFFF00 020F 207
001e.652a.08a6    2    0 00 40160 000 07E 29   0-0 (0) 73B0 200 0-10 1EFFFFFF00 020F 00C
001e.6555.87ea    1    0 00 40140 000 07E 58   0-0 (0) 73B0 200 0-10 1EFFFFFF00 020F 06C
                 RxPkts KBytes  Dup Dec Mic   TxPkts  KBytes  Retry RSSI SNR
--More--                           ec55.f9c3.d000   104030  33443  260  81   0    75234   10575   1193   42  52
001e.6529.f8ba    85852  28346    7  11   0    72613   36549   9689   42  50
001e.652a.08a6    60020  13811   17  21   0    42779   16817  11294   55  39
001e.6555.87ea    58281  13109   13  87   0    47204   23628   2555   52  41
    Tx Params  Pri BA TxLt
ec55.f9c3.d000   0   4  80
ec55.f9c3.d000   1   0  80
ec55.f9c3.d000   2   0  80
ec55.f9c3.d000   3   0  80
ec55.f9c3.d000   4   1  80
ec55.f9c3.d000   5   1  80
ec55.f9c3.d000   6   0  80
ec55.f9c3.d000   7   0  80
001e.6529.f8ba   0   4  80
001e.6529.f8ba   1   0  80
001e.6529.f8ba   2   0  80
001e.6529.f8ba   3   0  80
001e.6529.f8ba   4   1  80
001e.6529.f8ba   5   1  80
001e.6529.f8ba   6   0  80
001e.6529.f8ba   7   0  80
001e.652a.08a6   0   4  80
001e.652a.08a6   1   0  80
--More--                           001e.652a.08a6   2   0  80
001e.652a.08a6   3   0  80
001e.652a.08a6   4   1  80
001e.652a.08a6   5   1  80
001e.652a.08a6   6   0  80
001e.652a.08a6   7   0  80
001e.6555.87ea   0   4  80
001e.6555.87ea   1   0  80
001e.6555.87ea   2   0  80
001e.6555.87ea   3   0  80
001e.6555.87ea   4   1  80
001e.6555.87ea   5   1  80
001e.6555.87ea   6   0  80
001e.6555.87ea   7   0  80
               IP Address      Pauses  Idle   RateTx   RateDataTx   RSC
ec55.f9c3.d000 192.168.1.92    00000 000000      0      0 [0]0x3B
001e.6529.f8ba 192.168.1.91    00000 000000      0      0 [0]0x45
001e.652a.08a6 192.168.1.96    00000 000000      0      0 [0]0x6A
001e.6555.87ea 192.168.1.94    00000 000000      0      0 [0]0x7
    Block Ack  Pri, Rcv Wind  Timeout SeqNum Held, Xmt Wind  Timeout
ec55.f9c3.d000   0        64        0    3C0    0        64        0 4, 0 0 0
ec55.f9c3.d000   4                                        0        0 1, 0 0 0
ec55.f9c3.d000   5                                        0        0 1, 0 0 0
--More--                           001e.6529.f8ba   0                                       64       31 4, 0 0 0
001e.6529.f8ba   4                                        0        0 1, 0 0 0
001e.6529.f8ba   5                                        0        0 1, 0 0 0
001e.652a.08a6   0                                       64       31 4, 0 0 0
001e.652a.08a6   4                                        0        0 1, 0 0 0
001e.652a.08a6   5                                        0        0 1, 0 0 0
001e.6555.87ea   0                                       64       31 4, 0 0 0
001e.6555.87ea   4                                        0        0 1, 0 0 0
001e.6555.87ea   5                                        0        0 1, 0 0 0
Video Report:  Cnt  Rate  Retries/Tot
8021x auth in prog 0 allowed 0
Vlan BSSID   Clients PSP Pri/U/M HT Encr  Key0 Key1 Key2 Key3 iGTK  SSIDs MFP
   0n AC40 0        4  1    0 0 0  2  214       x128           DIS
Packet Tx (in radio) Metrics
Max Stuck time: Normal 0 MC 0 Off Channel 0
Stuck Cnt        Normal     MC    Off Channel
Paks > 30 Secs     0         0         0
Paks > 20 Secs     0         0         0
Paks > 15 Secs     0
Paks > 10 Secs     0         0         0
Paks >  5 Secs     0
Paks >  1 Secs     0         0         0
--More--                           0 0 flags 3 match 7
Protocol 12D5
Radio MAC SoC ID: 19, Rev: 5
Data Offsets: 122 72, 0 - 4146, 4 - 9224, 8 - 4154, 12 - 9321, 16 - 4196, 20 - 10086, 24 - 4369, 28 - 8813, 32 - 4231, 36 - 9353, 40 - 4075, 44 - 10147, 48 - 3909, 52 - 9205, 56 - 787752, 60 - 8860, 64 - 9392, 68 - 9386, 72 - 4340, 76 - 9724, 80 - 4086, 84 - 9680, 88 - 4054, 92 - 10793, 96 - 4096, 100 - 8788, 104 - 3813, 108 - 9184, 112 - 4529, 116 - 9006, 120 - 4256, 124 - 9888
27002864 00000005 00000004 00000000
00000000 00040000 000B0000 00000000 FFFFFFFF
00000000 003F8000 00000000 FFFFFFFF 4522541 0
Tx rdy 07002F18 (07002D1C - 070035B4)
07002D1C:  588CAB8  58C5838  590F938  58BD9B8  58F8738  591F6F8  5914338  58A3238
07002D3C:  590A4B8  58B5038  5939E38  58AA6B8  58E5EB8  58B4538  58836B8  593FD38
07002D5C:  58E5438  58D0C38  58E5E9C  5906FB8  58949B8  5935EB8  58DD538  593A8B8
07002D7C:  5891F38  5918D38  5937EB8  59123B8  58993B8  5893F38  58D60B8  58E49B8
07002D9C:  58C7838  5896938  5938938  5943238  59349B8  592CAB8  5884138  5897EB8
07002DBC:  58F7C38  5935438  58FA6B8  58A71B8  58C4DB8  58AC6B8  592D538  59295B8
--More--                           07002DDC:  592DFB8  591E1B8  58E7E20  5930A38  592EA38  58DF538  58DEA38  5887638
07002DFC:  593D338  5907A38  58D36B8  588B5B8  58DDFB8  58C38B8  588D538  58E3F38
07002E1C:  58E34B8  5880C38  58CA2B8  58BE438  58AB138  5886BB8  58B10B8  5927638
07002E3C:  593BDB8  59447B0  58C2E38  58D80B8  591ECB8  58B6538  58F1D38  59216B8
07002E5C:  58C0E38  58CF738  58E8938  589B338  58F3CB8  500D26C  5901B38  58E6938
07002E7C:  590EEB8  500CB24  589DDB8  58F47B8  59162A0  58B7A38  593C8B8  58C5838
07002E9C:  593F2B8  58C6D40  59025B8  590C438  588EAB8  59197B8  590AF38  500E744
07002EBC:  500F51C  506FDDC  5040A0C  503E104  500D9DC  500C63C  500C774  5004D94
07002EDC:  500D8A4  500C044  500D62C  58BCEB8  500E37C  58949B8  5888B38  500C294
07002EFC:  500C15C  58FE638  58860B8  5882188  589F2B8  59084B8  5945CB8        0
07002F1C:  588D4F4  58F3238  58949B8  58EDDB8  5922C38  590A4B8  591F738  593F2B8
07002F3C:  58AA6B8  592AAB8  5924138  589A8B8  58C4338  5935EB8  58D60B8  5884BB8
--More--                           07002F5C:  59010B8  5898938  5903038  5909A38  58AD138  590C438  58B05B8  59197B8
07002F7C:  591E1B8  59412B8  5935438  58A9C38  58BAF38  588A038  58EC8B8  592DFB8
07002F9C:  591C238  590E438  58A91B8  589E838  58C03B8  58E0A38  58A7C38  58821B8
07002FBC:  58C38B8  58836B8  58AFB38  58AB138  58B9A38  5895EB8  587ECB8  5945CB8
07002FDC:  5931F38  5907A38  58BD9B8  58DDFB8  58BCEB8  5886BB8  58A3238  58D80B8
07002FFC:  58FF0B8  59427B8  5882C38  5912E38  58A6738  5917838  58E5EB8  58B7A38
0700301C:  58ABBB8  5941D38  5920C38  5895438  58DB5B8  58A0838  591AD38  58880B8
0700303C:  5936938  588AB38  592B5B8  58CE238  58C8D38  592D538  58C2E38  5930A38
0700305C:  58DF538  58A3D38  58B3AB8  58C82B8  588DFB8  58D36B8  587F738  593E838
0700307C:  58A12B8  5944738  58A5CB8  59005B8  59201B8  58C1938  58CC238  589F2B8
0700309C:  58A5238  5922138  58F71B8  59314B8  589DDB8  5904FB8  500D4E4  593D338
070030BC:  593B338  58BE438  58D6BB8  58A1D38  5880C38  58FBBB8  5914DB8  58B6FB8
--More--                           070030DC:  58CD738  58BC438  58C0E38  500C63C  58E8938  500C8CC  589B338  5901B38
070030FC:  58B4538  589FDB8  5903AB8  58B3050  58D017C  500CD94  5922C38  5906FB8
0700311C:  50403DC  50645EC  503FA44  590B9B8  503FD6C  59236B8  500C794  5004D94
0700313C:  500D9BC  500D884  500C03C  590A4B8  5896938  5905AB8  589A8B8  58AA6B8
0700315C:  58D2C38  589935C  58B5A38  58DCA54  592BFB4  5893EBC  5935EB8  58DD538
0700317C:  5893EBC  58DCA54  500D614  500E37C  592EA38  593691C  588EAB8  58BEEB8
0700319C:  58AD138  58B5AAC  58A7180  58F7174  58EDD5C  588EA1C  58E7394  58801B8
070031BC:  592CAB8  5897EB8  58F7174  58F7C38  5935438  58AC6B8  500C15C  58D5638
070031DC:  58EDD5C  500D76C  500F51C  506F70C  5040A0C  503E104  500CA04  500E10C
070031FC:  500B664  500E5EC  500BB64  500DB14  500DD7C  5915838  500D134  592DFB8
0700321C:  591C238  58F5238  58B10B8  58B5A38  500B79C  589E838  5904538  58F0838
0700323C:  58A7C38  58821B8  5943CB8  58C6DB8  58CB7B8  58AB138  58C38B8  58F91B8
--More--                           0700325C:  58E93B8  58DAAB8  58EFD38  500BEEC  58AB180  58CECB8  5907A38  588B5B8
0700327C:  58DDFB8  590D9B8  5886BB8  58BE3B4  58FF0B8  58EF2B8  58D7638  58A6738
0700329C:  58EF2C0  58F3238  59216B8  58F9130  5917838  58A27B8  592AAB8  58ABBB8
070032BC:  58DFFB8  58C4338  5895438  58880B8  591AD38  588AB38  593DDB8  5884BB8
070032DC:  58CE238  59412B8  5898938  589C8B8  58FD138  588C038  58BAF38  58C2E38
070032FC:  5916338  593BDB8  5927638  58E1F38  588FFB8  58CCCB8  58B1B38  58AFB38
0700331C:  592F4B8  588FF44  5895EB8  587ECB8  58C82B8  59427B8  5925638  5945CB8
0700333C:  5941D38  5920C38  58D16B8  58C8D38  58D9FFC  58ED338  58A9C38  58D1680
0700335C:  58D2138  58E7EB8  590F938  589DDB8  58B3AB8  58C5838  588CAB8  588A038
0700337C:  59280B8  58EA8B8  58F8738  5906538  58E14B8  58C4DB8  5939E38  5924BB8
0700339C:  58CC1D8  58B5038  58F6738  5928B38  58836B8  58B4538  58BC438  5903AB8
070033BC:  58949B8  58D0C38  5922C38  58BCEB8  5906FB8  58914B8  593C8B8  5896938
--More--                           070033DC:  59123B8  5905AB8  593A8B8  58D2C38  58A5238  59236B8  58D60B8  5893F38
070033FC:  59010B8  592C038  58C7838  5924138  58F9C38  5943238  5938938  5899E38
0700341C:  5909A38  59349B8  58FA6B8  590C438  5897EB8  589BE38  58EC8B8  59197B8
0700343C:  592D538  58F9BFC  58B5AB8  59393B8  591C238  58B10B8  5904538  589E838
0700345C:  592DFB8  58A47B8  5936938  592EA38  58801B8  58AD138  58BA4B8  5888B38
0700347C:  59260B8  58DAAB8  58E93B8  58FE638  59329B8  5946738  590D9B8  58895B8
0700349C:  500B3F4  58E29B8  58860B8  59084B8  5940838  58E34B8  588D538  500C3D4
070034BC:  591CCB8  58AB138  58F3238  5914DB8  58CB7B8  58C6DB8  5943CB8  58821B8
070034DC:  58A7C38  58F0838  58D80B8  589F2C0  58DB5B8  58FC638  591ECB8  589D338
070034FC:  5897440  58A6714  58F1D38  59182B8  591A238  58C23B8  58EBE38  58B25B8
0700351C:  58D4138  58B1B38  58CCCB8  58B6FB8  588FFB8  58CD738  58AFB40  58CF738
0700353C:  5925638  58A91B8  500B2DC  5040704  506317C  500FB4C  5040094  500DFF4
--More--                           0700355C:  500B8D4  500DC2C  500CEC4  500E264  500ADFC  5004C74  589B338  5885638
0700357C:  500E4B4  58DA040  58A86A8  5933438  5901B38  500AF14  58B3038  590EEB8
0700359C:  590E438  500D3A4  58E1F40  58A5CB8  589DDC0  58C1938
Off Channel rdy 07003E4C (07003E4C - 07003EEC)
07003E4C:        0        0        0        0        0        0        0        0
07003ECC:        0        0
Off Channel done 07003EEC (07003EEC - 07003F8C)
07003EEC:        0        0        0        0        0        0        0        0
07003F6C:        0        0
Tx done 070035B4, current 070037B0
070035B4:        0        0        0        0        0        0        0        0
070035D4:        0        0        0        0        0        0        0        0
070035F4:        0        0        0        0        0        0        0        0
07003614:        0        0        0        0        0        0        0        0
--More--                           07003634:        0        0        0        0        0        0        0        0
07003654:        0        0        0        0        0        0        0        0
07003674:        0        0        0        0        0        0        0        0
07003694:        0        0        0        0        0        0        0        0
070036B4:        0        0        0        0        0        0        0        0
070036D4:        0        0        0        0        0        0        0        0
070036F4:        0        0        0        0        0        0        0        0
07003714:        0        0        0        0        0        0        0        0
07003734:        0        0        0        0        0        0        0        0
07003754:        0        0        0        0        0        0        0        0
07003774:        0        0        0        0        0        0        0        0
07003794:        0        0        0        0        0        0        0        0
--More--                           070037B4:        0        0        0        0        0        0        0        0
070037D4:        0        0        0        0        0        0        0        0
070037F4:        0        0        0        0        0        0        0        0
07003814:        0        0        0        0        0        0        0        0
07003834:        0        0        0        0        0        0        0        0
07003854:        0        0        0        0        0        0        0        0
07003874:        0        0        0        0        0        0        0        0
07003894:        0        0        0        0        0        0        0        0
070038B4:        0        0        0        0        0        0        0        0
070038D4:        0        0        0        0        0        0        0        0
070038F4:        0        0        0        0        0        0        0        0
07003914:        0        0        0        0        0        0        0        0
--More--                           07003934:        0        0        0        0        0        0        0        0
07003954:        0        0        0        0        0        0        0        0
07003974:        0        0        0        0        0        0        0        0
07003994:        0        0        0        0        0        0        0        0
070039B4:        0        0        0        0        0        0        0        0
070039D4:        0        0        0        0        0        0        0        0
070039F4:        0        0        0        0        0        0        0        0
07003A14:        0        0        0        0        0        0        0        0
07003A34:        0        0        0        0        0        0        0        0
07003A54:        0        0        0        0        0        0        0        0
07003A74:        0        0        0        0        0        0        0        0
07003A94:        0        0        0        0        0        0        0        0
--More--                           07003AB4:        0        0        0        0        0        0        0        0
07003AD4:        0        0        0        0        0        0        0        0
07003AF4:        0        0        0        0        0        0        0        0
07003B14:        0        0        0        0        0        0        0        0
07003B34:        0        0        0        0        0        0        0        0
07003B54:        0        0        0        0        0        0        0        0
07003B74:        0        0        0        0        0        0        0        0
07003B94:        0        0        0        0        0        0        0        0
07003BB4:        0        0        0        0        0        0        0        0
07003BD4:        0        0        0        0        0        0        0        0
07003BF4:        0        0        0        0        0        0        0        0
07003C14:        0        0        0        0        0        0        0        0
--More--                           07003C34:        0        0        0        0        0        0        0        0
07003C54:        0        0        0        0        0        0        0        0
07003C74:        0        0        0        0        0        0        0        0
07003C94:        0        0        0        0        0        0        0        0
07003CB4:        0        0        0        0        0        0        0        0
07003CD4:        0        0        0        0        0        0        0        0
07003CF4:        0        0        0        0        0        0        0        0
07003D14:        0        0        0        0        0        0        0        0
07003D34:        0        0        0        0        0        0        0        0
07003D54:        0        0        0        0        0        0        0        0
07003D74:        0        0        0        0        0        0        0        0
07003D94:        0        0        0        0        0        0        0        0
--More--                           07003DB4:        0        0        0        0        0        0        0        0
07003DD4:        0        0        0        0        0        0        0        0
07003DF4:        0        0        0        0        0        0        0        0
07003E14:        0        0        0        0        0        0        0        0
07003E34:        0        0        0        0        0        0
Rcv rdy 07003F8C, current 07003FC8
07003F8C:  591C1D4  5926080  5888AE8  58E341C  58E9350  58FE5D0  58BE3BC  58FB0EC
07003FAC:  5886B2C  5886098  587F6D0  5882120  593BD94  5945C40  58B4FA4        0
07003FCC:  58E7394  58C2DC8  58D8048  5883648  5908F10  58E53D8  58D0BEC  5939DD8
07003FEC:  58D75B4  5939344  5926B14  5906F54  58B0598  59275A8  58EDD5C  58973A0
0700400C:  58BF8E4  58A1CE0  58DD4E8  590058C  58AD0B4  58BA444  58F1CD4  5891F00
0700402C:  58C2334  5937E1C  58C9790  58F7174  58EBDA0  58D608C  588957C  58F51B8
--More--                           0700404C:  58B1AC0  592BFB4  593E7E4  5935E60  587EC3C  59407A0  58E09CC  593B300
0700406C:  591CC68  5904504  58F31FC  58F07AC  58CEC30  5893EBC  58A7C14  589D2D4
0700408C:  58D6B20  58EF284  59431F0  591A218  58FBB80  58B2554  58F9130  58D40D0
070040AC:  592F498  58B6F60  5895E78  58C8268  588FF44  58CD708  58CCC74  59388B0
070040CC:  5934938  5897E34  59255EC  58A7180  58A913C  5920BE0  58C4D84  58F3C90
070040EC:  58B5A38  58AC620  5929564  589FD24  594275C  58E7E28  5901AB4  592EA04
0700410C:  58CF6C4  590EE44  59353CC  590E3B0  58BC400  58A5C58  589DD68  591036C
0700412C:  593D2BC  58EE7F0  58B79F4  593C828  58C5818  58A51C4  5902548  58AA664
0700414C:  590C3F4  590AECC  5928AD0  5912DBC  58DBFC0  58C18A0  5913850  5903A70
0700416C:  588CA60  58C385C  5922108  589146C  58A86A8  590F8D8  58BCE94  58BD928
Rcv done 0700418C, current 070041CC
0700418C:        0        0        0        0        0        0        0        0
--More--                           070041AC:        0        0        0        0        0        0        0        0
070041CC:        0        0        0        0        0        0        0        0
070041EC:        0        0        0        0        0        0        0        0
0700420C:        0        0        0        0        0        0        0        0
0700422C:        0        0        0        0        0        0        0        0
0700424C:        0        0        0        0        0        0        0        0
0700426C:        0        0        0        0        0        0        0        0
0700428C:        0        0        0        0        0        0        0        0
070042AC:        0        0        0        0        0        0        0        0
070042CC:        0        0        0        0        0        0        0        0
070042EC:        0        0        0        0        0        0        0        0
0700430C:        0        0        0        0        0        0        0        0
--More--                           0700432C:        0        0        0        0        0        0        0        0
0700434C:        0        0        0        0        0        0        0        0
0700436C:        0        0        0        0        0        0        0        0
Off Channel scheduler statistics: (mSec)
Priority  avg_wait_time  avg_serve_time  timeout_count  request_count
       0              0               0              0              0
       1              0               0              0              0
       2              0               0              0              0
       3              0               0              0              0
       4              0               0              0              0
off chan inprog = 0
TXSM Jammer information:
  State: 0
Flags: 00000000
  Beacons seen: 0
  Time since: 0
  Jammer Radio resets: 0
TXSM Beacon information:
  Monitoring State: 1
--More--                             Flags: 00000000
  Beacons seen: 1064579
  Time since: 1
  Max Time w/o beacons: 2
  Beacon stopped count: 0
  Counts > 120 0
  Counts > 90 0
  Counts > 60 0
  Counts > 30 0
  Counts > 15 0
  Counts > 10 0
  Counts >  5 0
TXSM Current Beacon Outage:
  Beacon Monitor Flags   OP Mode Flags   Reason
  0x00000000             0x00000000
TXSM Beacon Outage Stats:
  Outage(Seconds)   Beacon Monitor Flags   OP Mode Flags   Reason
   > 120
   >  90
   >  60
   >  30
   >  15
   >  10
--More--                              >   5
Last Cmd Received Time:2930617434
Last stats update: 108895
Current Time:108896
Radio PCI resets:0
RX Ring Errors - Pak:0 Order:0 Max:0
Radio commands - total:310558 delayed:0 elapsed:0 timeouts:0 time high 00000000 low 00000000 usecs 00000000
Log buf magic 0(FA1A1AFA) 1(00000000) Active(0) 0700C3CC Last(1) 0700C6C8
Last cmd host 17 fw 17 HTS 5AACAD5D FWWD ED1F123E PP 0 MAGIC FA1A1AFA
CMD(04) - TS HOST 00000000 FW 07F77B19 seq 6
CMD(05) - TS HOST 00000000 FW 07F77B39 seq 6
CMD(06) - TS HOST 00000000 FW 000901DD seq 6
CMD(07) - TS HOST 00000000 FW 07F77B66 seq 6
CMD(08) - TS HOST 00000000 FW ED03E023 seq 6
CMD(09) - TS HOST 00000000 FW ED03DFB2 seq 6
CMD(0A) - TS HOST 00000000 FW 07F797BF seq 6
CMD(0B) - TS HOST 00000000 FW 07F7E64E seq 6
CMD(0C) - TS HOST 00000000 FW 07F786D4 seq 6
CMD(0D) - TS HOST 00000000 FW ECE61F2D seq 6
CMD(0F) - TS HOST 00000000 FW ED1294C5 seq 6
CMD(10) - TS HOST 00000000 FW 07F77A96 seq 6
--More--                            CMD(12) - TS HOST 00000000 FW 07F77345 seq 6
CMD(14) - TS HOST 00000000 FW 0009074A seq 6
CMD(15) - TS HOST 00000000 FW 07F7B02E seq 6
CMD(16) - TS HOST 5AACACCE FW ED137EC0 seq 6
CMD(17) - TS HOST 00000000 FW ED137F4D seq 6
CMD(1E) - TS HOST 00000000 FW 000A11AA seq 6
CMD(20) - TS HOST 00000000 FW ECE62DA2 seq 6
CMD(27) - TS HOST 00000000 FW 07F7C942 seq 6
CMD(34) - TS HOST 00000000 FW B48401A0 seq 6
Well aligned packets transmitted: 790447
Misaligned packet transmitted: 237630
Active power levels by rate
     1.0 to 11.0  , 20  dBm
     6.0 to 9.0   , 17  dBm, changed due to regulatory maximum
    12.0 to 18.0  , 16  dBm, changed due to regulatory maximum
    24.0 to 24.0  , 14  dBm, changed due to regulatory maximum
    36.0 to 48.0  , 13  dBm, changed due to regulatory maximum
    54.0 to 54.0  , 11  dBm, changed due to regulatory maximum
   6.0bf to 9.0bf , 17  dBm, changed due to regulatory maximum
  12.0bf to 18.0bf, 16  dBm, changed due to regulatory maximum
  24.0bf to 24.0bf, 14  dBm, changed due to regulatory maximum
  36.0bf to 48.0bf, 13  dBm, changed due to regulatory maximum
  54.0bf to 54.0bf, 11  dBm, changed due to regulatory maximum
--More--                               m0-2 to m0-2  , 17  dBm, changed due to regulatory maximum
    m1-2 to m2-2  , 16  dBm, changed due to regulatory maximum
    m3-2 to m3-2  , 14  dBm, changed due to regulatory maximum
    m4-2 to m5-2  , 13  dBm, changed due to regulatory maximum
    m6-2 to m6-2  , 11  dBm, changed due to regulatory maximum
    m7-2 to m7-2  , 10  dBm, changed due to regulatory maximum
    m8-2 to m8-2  , 17  dBm, changed due to regulatory maximum
    m9-2 to m10-2 , 16  dBm, changed due to regulatory maximum
   m11-2 to m11-2 , 14  dBm, changed due to regulatory maximum
   m12-2 to m13-2 , 13  dBm, changed due to regulatory maximum
   m14-2 to m14-2 , 11  dBm, changed due to regulatory maximum
   m15-2 to m15-2 , 10  dBm, changed due to regulatory maximum
   m16-2 to m23-2 , 0   dBm, changed due to regulatory maximum
    m0-4 to m5-4  , 13  dBm, changed due to regulatory maximum
    m6-4 to m6-4  , 11  dBm, changed due to regulatory maximum
    m7-4 to m7-4  , 10  dBm, changed due to regulatory maximum
    m8-4 to m13-4 , 13  dBm, changed due to regulatory maximum
   m14-4 to m14-4 , 11  dBm, changed due to regulatory maximum
   m15-4 to m15-4 , 10  dBm, changed due to regulatory maximum
   m16-4 to m23-4 , 0   dBm, changed due to regulatory maximum
    6.0d to 9.0d  , 17  dBm, changed due to regulatory maximum
   12.0d to 18.0d , 16  dBm, changed due to regulatory maximum
   24.0d to 24.0d , 14  dBm, changed due to regulatory maximum
--More--                              36.0d to 48.0d , 13  dBm, changed due to regulatory maximum
   54.0d to 54.0d , 11  dBm, changed due to regulatory maximum
    m0b2 to m23b4 , 0   dBm, changed due to regulatory maximum
  OffChnl Power: 20, Rate 1.0
-Channel Range-  -------Rates------ Max Power   Allowed
  1 to   1 by 1  1.0    to 11.0     19  0     -1 2 5 8 11 14 17 20
                 6.0    to 18.0     16  14
                 24.0   to 24.0     14  14
                 36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
                 6.0bf  to 48.0bf   13  13
                 54.0bf to 54.0bf   11  11
                 m0-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
                 m8-2   to m11-2    14  14
                 m12-2  to m13-2    13  13
                 m14-2  to m14-2    11  11
                 m15-2  to m15-2    10  10
                 m16-2  to m23-2    0   0
                 m0-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
--More--                                            m8-4   to m14-4    11  11
                 m15-4  to m15-4    10  10
                 m16-4  to m23-4    0   0
                 6.0d   to 18.0d    16  14
                 24.0d  to 24.0d    14  14
                 36.0d  to 48.0d    13  13
                 54.0d  to 54.0d    11  11
                 m0b2   to m23b4    0   0
  2 to   2 by 1  1.0    to 11.0     20  0     -1 2 5 8 11 14 17 20
                 6.0    to 9.0      17  16
                 12.0   to 18.0     16  16
                 24.0   to 24.0     14  14
                 36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
                 6.0bf  to 24.0bf   14  14
                 36.0bf to 48.0bf   13  13
                 m0-2   to m0-2     17  16
                 m1-2   to m2-2     16  16
                 m3-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
--More--                                            m8-2   to m10-2    16  16
                 m11-2  to m11-2    14  14
                 m16-2  to m23-2    0   0
                 m0-4   to m5-4     13  13
                 m6-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m13-4    13  13
                 m14-4  to m14-4    11  11
                 m16-4  to m23-4    0   0
                 6.0d   to 9.0d     17  16
                 12.0d  to 18.0d    16  16
                 m0b2   to m23b4    0   0
  3 to   3 by 1  1.0    to 11.0     20  0     -1 2 5 8 11 14 17 20
                 6.0    to 9.0      17  17
                 12.0   to 18.0     16  16
                 24.0   to 24.0     14  14
--More--                                            36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
                 6.0bf  to 18.0bf   16  16
                 24.0bf to 24.0bf   14  14
                 m0-2   to m0-2     17  17
                 m1-2   to m2-2     16  16
                 m3-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
                 m8-2   to m8-2     17  17
                 m9-2   to m10-2    16  16
                 m16-2  to m23-2    0   0
                 m0-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m14-4    11  11
--More--                                            m16-4  to m23-4    0   0
                 6.0d   to 9.0d     17  17
                 m0b2   to m23b4    0   0
  4 to   4 by 1  1.0    to 11.0     20  0     -1 2 5 8 11 14 17 20
                 6.0    to 9.0      17  17
                 12.0   to 18.0     16  16
                 24.0   to 24.0     14  14
                 36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
                 6.0bf  to 9.0bf    17  17
                 12.0bf to 18.0bf   16  16
                 m0-2   to m0-2     17  17
                 m1-2   to m2-2     16  16
                 m3-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
--More--                                            m7-2   to m7-2     10  10
                 m8-2   to m8-2     17  17
                 m9-2   to m10-2    16  16
                 m16-2  to m23-2    0   0
                 m0-4   to m3-4     14  14
                 m4-4   to m5-4     13  13
                 m6-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m11-4    14  14
                 m12-4  to m13-4    13  13
                 m16-4  to m23-4    0   0
                 6.0d   to 9.0d     17  17
                 m0b2   to m23b4    0   0
--More--                             5 to   5 by 1  1.0    to 11.0     20  0     -1 2 5 8 11 14 17 20
                 6.0    to 9.0      17  17
                 12.0   to 18.0     16  16
                 24.0   to 24.0     14  14
                 36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
                 m0-2   to m0-2     17  17
                 m1-2   to m2-2     16  16
                 m3-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
                 m8-2   to m8-2     17  17
                 m9-2   to m10-2    16  16
--More--                                            m16-2  to m23-2    0   0
                 m0-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m14-4    11  11
                 m16-4  to m23-4    0   0
                 6.0d   to 9.0d     17  17
                 m0b2   to m23b4    0   0
  6 to   6 by 1  1.0    to 11.0     20  0     -1 2 5 8 11 14 17 20
                 6.0    to 9.0      17  17
                 12.0   to 18.0     16  16
                 24.0   to 24.0     14  14
                 36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
--More--                                            m0-2   to m0-2     17  17
                 m1-2   to m2-2     16  16
                 m3-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
                 m8-2   to m8-2     17  17
                 m9-2   to m10-2    16  16
                 m16-2  to m23-2    0   0
                 m0-4   to m5-4     13  13
                 m6-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m13-4    13  13
                 m16-4  to m23-4    0   0
                 6.0d   to 9.0d     17  17
--More--                                            36.0d  to 48.0d    13  13
                 m0b2   to m23b4    0   0
  7 to   7 by 1  1.0    to 11.0     20  0     -1 2 5 8 11 14 17 20
                 6.0    to 9.0      17  17
                 12.0   to 18.0     16  16
                 24.0   to 24.0     14  14
                 36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
                 m0-2   to m0-2     17  17
                 m1-2   to m2-2     16  16
                 m3-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
                 m8-2   to m8-2     17  17
                 m9-2   to m10-2    16  16
--More--                                            m12-2  to m13-2    13  13
                 m16-2  to m23-2    0   0
                 m0-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m14-4    11  11
                 m16-4  to m23-4    0   0
                 6.0d   to 9.0d     17  17
                 m0b2   to m23b4    0   0
  8 to   8 by 1  1.0    to 11.0     20  0     -1 2 5 8 11 14 17 20
                 6.0    to 9.0      17  17
                 12.0   to 18.0     16  16
                 24.0   to 24.0     14  14
                 36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
--More--                                            24.0bf to 24.0bf   14  14
                 m0-2   to m0-2     17  17
                 m1-2   to m2-2     16  16
                 m3-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
                 m8-2   to m8-2     17  17
                 m9-2   to m10-2    16  16
                 m16-2  to m23-2    0   0
                 m0-4   to m3-4     14  14
                 m4-4   to m5-4     13  13
                 m6-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m11-4    14  14
--More--                                            m15-4  to m15-4    10  10
                 m16-4  to m23-4    0   0
                 6.0d   to 9.0d     17  17
                 m0b2   to m23b4    0   0
  9 to   9 by 1  1.0    to 11.0     20  0     -1 2 5 8 11 14 17 20
                 6.0    to 9.0      17  17
                 12.0   to 18.0     16  16
                 24.0   to 24.0     13  14
                 36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
                 m0-2   to m2-2     16  16
                 m3-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
                 m8-2   to m10-2    16  16
--More--                                            m11-2  to m11-2    14  14
                 m16-2  to m23-2    0   0
                 m0-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m14-4    11  11
                 m16-4  to m23-4    0   0
                 6.0d   to 9.0d     17  17
                 24.0d  to 24.0d    13  14
                 m0b2   to m23b4    0   0
10 to  10 by 1  1.0    to 11.0     19  0     -1 2 5 8 11 14 17 20
                 6.0    to 18.0     16  14
                 24.0   to 24.0     14  14
                 36.0   to 48.0     13  13
                 54.0   to 54.0     11  11
--More--                                            54.0bf to 54.0bf   11  11
                 m0-2   to m2-2     16  14
                 m3-2   to m3-2     14  14
                 m4-2   to m5-2     13  13
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
                 m8-2   to m11-2    14  14
                 m16-2  to m23-2    0   0
                 m0-4   to m5-4     13  13
                 m6-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m13-4    13  13
                 m16-4  to m23-4    0   0
                 6.0d   to 18.0d    16  14
                 m0b2   to m23b4    0   0
--More--                            11 to  11 by 1  1.0    to 11.0     18  0     -1 2 5 8 11 14 17 20
                 6.0    to 24.0     14  13
                 36.0   to 48.0     13  13
                 54.0   to 54.0bf   11  11
                 m0-2   to m5-2     13  11
                 m6-2   to m6-2     11  11
                 m7-2   to m7-2     10  10
                 m8-2   to m14-2    11  11
                 m16-2  to m23-2    0   0
                 m0-4   to m6-4     11  11
                 m7-4   to m7-4     10  10
                 m8-4   to m14-4    11  11
                 m16-4  to m23-4    0   0
                 6.0d   to 24.0d    14  13
                 m0b2   to m23b4    0   0
    DOT11 Statistics (Cumulative Total/Last 5 Seconds):
RECEIVER                               TRANSMITTER
Host Rx K Bytes:    1715515 / 946      Host Tx K Bytes:        134133 / 545
Unicasts Rx:        1176266 / 31       Unicasts Tx:            738826 / 20
--More--                           Unicasts to host:   1176266 / 31       Unicasts by host:       729533 / 20
Broadcasts Rx:       143198 / 3        Broadcasts Tx:         1261111 / 58
Beacons Rx:           33498 / 0        Beacons Tx:            1064628 / 49
Broadcasts to host:  143198 / 3        Broadcasts by host:     196483 / 9
Multicasts Rx:            0 / 0        Multicasts Tx:           92768 / 1
Multicasts to host:       0 / 0        Multicasts by host:      92768 / 1
Mgmt Packets Rx:     133889 / 7        Mgmt Packets Tx:        128224 / 9
RTS received:           102 / 0        RTS transmitted:        212160 / 5
Duplicate frames:         0 / 0        CTS not received:        13648 / 0
CRC errors:           57977 / 0        Unicast Fragments Tx:  1028077 / 29
WEP errors:            3890 / 1        Retries:                 91794 / 1
Buffer full:              0 / 0        Packets one retry:       28241 / 1
Host buffer full:         0 / 0        Packets > 1 retry:       18759 / 0
Header CRC errors:        0 / 0        Protocol defers:             0 / 0
Invalid header:           0 / 0        Energy detect defers:        0 / 0
Length invalid:           0 / 0        Jammer detected:             0 / 0
Incomplete fragments:     0 / 0        Packets aged:                0 / 0
Rx Concats:               0 / 0        Tx Concats:                  0 / 0
Tx Watchdog stats:
Tx SW Watchdog        0 / 0
Tx HW Watchdog        0 / 0
--More--                           RATE 1.0
Rx Packets:          224841 / 3        Tx Packets:              41467 / 8
Rx Bytes:          15074178 / 145      Tx Bytes:              2387024 / 422
RTS Retries:              0 / 0        Data Retries:             6258 / 1
RATE 2.0
Rx Packets:           51388 / 0        Tx Packets:                 18 / 0
Rx Bytes:              3267 / 0        Tx Bytes:                 1874 / 0
RTS Retries:              0 / 0        Data Retries:                0 / 0
RATE 5.5
Rx Packets:           48719 / 0        Tx Packets:                 84 / 0
Rx Bytes:             37952 / 0        Tx Bytes:                13049 / 0
RTS Retries:              0 / 0        Data Retries:              397 / 0
RATE 11.0
Rx Packets:             101 / 0        Tx Packets:                  0 / 0
Rx Bytes:             10201 / 0        Tx Bytes:                    0 / 0
RATE 6.0
Rx Packets:          191442 / 16       Tx Packets:                 57 / 0
Rx Bytes:           1163177 / 390      Tx Bytes:                11794 / 0
--More--                           RTS Retries:              0 / 0        Data Retries:              113 / 0
RATE 9.0
Rx Packets:             141 / 0        Tx Packets:                  0 / 0
Rx Bytes:             13730 / 0        Tx Bytes:                    0 / 0
RATE 12.0
Rx Packets:              89 / 0        Tx Packets:                  0 / 0
Rx Bytes:             11353 / 0        Tx Bytes:                    0 / 0
RATE 18.0
Rx Packets:              94 / 0        Tx Packets:                  0 / 0
Rx Bytes:             15779 / 0        Tx Bytes:                    0 / 0
RATE 24.0
Rx Packets:             192 / 0        Tx Packets:                  0 / 0
Rx Bytes:             28591 / 0        Tx Bytes:                    0 / 0
RATE 36.0
--More--                           Rx Packets:             395 / 0        Tx Packets:                  0 / 0
Rx Bytes:             64589 / 0        Tx Bytes:                    0 / 0
RATE 48.0
Rx Packets:            1263 / 0        Tx Packets:                  0 / 0
Rx Bytes:            236657 / 0        Tx Bytes:                    0 / 0
RATE 54.0
Rx Packets:           24156 / 6        Tx Packets:                  0 / 0
Rx Bytes:           2727619 / 317      Tx Bytes:                    0 / 0
RATE m0-2
Rx Packets:             123 / 0        Tx Packets:                171 / 0
Rx Bytes:              8669 / 0        Tx Bytes:                38363 / 0
RTS Retries:              0 / 0        Data Retries:              431 / 0
RATE m1-2
Rx Packets:             284 / 0        Tx Packets:                237 / 0
Rx Bytes:             28901 / 0        Tx Bytes:                54462 / 0
RTS Retries:              0 / 0        Data Retries:               20 / 0
--More--
RATE m2-2
Rx Packets:             553 / 0        Tx Packets:                599 / 0
Rx Bytes:             54622 / 0        Tx Bytes:               137950 / 0
RTS Retries:              0 / 0        Data Retries:               39 / 0
RATE m3-2
Rx Packets:            1266 / 0        Tx Packets:               1363 / 0
Rx Bytes:            172688 / 0        Tx Bytes:               418025 / 0
RTS Retries:              0 / 0        Data Retries:             1715 / 0
RATE m4-2
Rx Packets:            3193 / 0        Tx Packets:               1772 / 0
Rx Bytes:            554619 / 0        Tx Bytes:               699964 / 0
RTS Retries:              0 / 0        Data Retries:               69 / 0
RATE m5-2
Rx Packets:            6793 / 0        Tx Packets:               9660 / 0
Rx Bytes:           1623902 / 0        Tx Bytes:              4393820 / 0
RTS Retries:              0 / 0        Data Retries:             4968 / 0
RATE m6-2
Rx Packets:           50541 / 0        Tx Packets:              30556 / 0
--More--                           Rx Bytes:          12260705 / 0        Tx Bytes:             19105700 / 0
RTS Retries:              0 / 0        Data Retries:             2665 / 0
RATE m7-2
Rx Packets:          713890 / 9        Tx Packets:             278770 / 2
Rx Bytes:          189308933 / 660      Tx Bytes:            128928548 / 340
RTS Retries:              0 / 0        Data Retries:            20646 / 0
RATE m8-2
Rx Packets:               0 / 0        Tx Packets:                 17 / 0
Rx Bytes:                 0 / 0        Tx Bytes:                 3459 / 0
RTS Retries:              0 / 0        Data Retries:                1 / 0
RATE m9-2
Rx Packets:               0 / 0        Tx Packets:                639 / 0
Rx Bytes:                 0 / 0        Tx Bytes:               184458 / 0
RATE m10-2
Rx Packets:               0 / 0        Tx Packets:                650 / 0
Rx Bytes:                 0 / 0        Tx Bytes:               178103 / 0
RTS Retries:              0 / 0        Data Retries:               14 / 0
--More--                           RATE m11-2
Rx Packets:               0 / 0        Tx Packets:                838 / 0
Rx Bytes:                 0 / 0        Tx Bytes:               322717 / 0
RTS Retries:              0 / 0        Data Retries:               32 / 0
RATE m12-2
Rx Packets:               0 / 0        Tx Packets:               5551 / 0
Rx Bytes:                 0 / 0        Tx Bytes:              2604931 / 0
RTS Retries:              0 / 0        Data Retries:             9102 / 0
RATE m13-2
Rx Packets:               0 / 0        Tx Packets:              43281 / 1
Rx Bytes:                 0 / 0        Tx Bytes:             43021245 / 58
RTS Retries:              0 / 0        Data Retries:             1854 / 0
RATE m14-2
Rx Packets:               0 / 0        Tx Packets:              51472 / 1
Rx Bytes:                 0 / 0        Tx Bytes:             39821502 / 76
RTS Retries:              0 / 0        Data Retries:             9169 / 0
RATE m15-2
Rx Packets:               0 / 0        Tx Packets:             257002 / 7
Rx Bytes:                 0 / 0        Tx Bytes:            130407973 / 714
--More--                           RTS Retries:              0 / 0        Data Retries:            34281 / 0
Multicast throttle drops: 0
Client TX pause count: 876
Bad receive packet count: 0
Media Direct Band Configuration
    Unicast Video Redirect = 0
    Client Min Phy Rate = 0
    Max Retry Percentage = 0
Dot11 Current Video Transmission Metrics:
    Arrivals:0 Q-Drops:0 Tries:0 Agg:0 Success:0 Fail:0
Dot11 5-second Video Transmission Metrics:
    Arrivals:0 Tries:0 Agg:0 Success:0 Fail:0
    Radio-Q-Peak:5 Video-Q-Peak:0 Video-Q-Drops:0
    Delay - Tot Msec:0 10/20/40/40+ Msec:0/0/0/0
Dot11 1-second Video Transmission Metrics:
    Q-util:0 max-tx-time:0 p-chan:15 p-video:0 L/r:0
Extended Radio Parameters:
        Beacon period (not supported), range (not supported)
        Ext Conf flags: 0
        Mcast rate 0 Mbps (Disabled)
--More--                                   RX sensitivity -0 dB (Disabled)
        CCA threshold -0 dB (Disabled)
Last radio reset code: 37
Radio resets - total:11 retries:0 failed:0
Reset Stats: Start Cnt: 2, Recovery: Cnt 0, Last Ret: 0, Fails: 0, Recvry Status: Stalled NO, In Prog NO
   Code/Count: 37/00008 2 67/00001 0 68/00002 0
802.11 forwarding statistics:
   IDB fastsend:1089873 frame_tx:1179766 frame_rx:1141810 vidb_tx:0
   Global mcast TX - total:0 mc2uc:0 drops:0 bad pri:0
   IDB mcast TX - filter:0,0,0 igmp_filter:0 from_self:0
   MGMT Action - GAS Req Rcvd:0 GAS Req Rx Drop:0
Log Buffer:
Content for Community-Ad
August's Community Spotlight Awards
