N+1 on Permanent AP Count 2504 WLC
joagusti.v1
Hi All,
We have a customer with two existing 2504 WLC each with 25 AP licenses. Now they are adding more APs and only bought additional AP license for the Primary only. I suggested to change their setup to N+1 so they no longer need to buy another license.
1. How do I do it Primary WLC GUI? I understand that you need to enter below command in CLI but how about in GUI which most clients prefer?
config advanced backup-controller primary backup_controller_name
backup_controller_IP_address
2. Does enabling "HA SKU secondary unit" on the Secondary WLC do the trick? Any other config needed?
3. After 90 days, what will happen to the APs connected to the Secondary WLC? Will they be dropped or a warning will only appear?
Appreciate prompt response.
Sandeep Choudhary
You are correct. If you have WLC version 7.5 or higher then you can convert 2nd WLC to HA model.
You will just need to buy AP adder license from primary WLC.
Here is the post to configure N+1 on Cisco 2504 WLC:
https://rscciew.wordpress.com/2014/06/07/n1-high-availability-configuration-on-cisco-2504wlc/
You dont need to enter any command on primary . You just need to run this command on secondary WLC "
(WLC2) >config redundancy unit secondary
same as point 1.
You will just get warning in log messages.No drop.
Dont forget to rate helpful posts
5 Replies 5
joagusti.v1
P.S.
Both controllers are AIR-CT2504-K9 and are at version 8.1.131 with 25 AP license each. And I understand that the Secondary WLC should run at least Release 7.5 to be configured as N+1. Any more additional requirement?
Sandeep Choudhary
same as point 1.
Hi Sandeep,
Thanks for the answers for the questions. So on item number 2, enabling "HA SKU secondary unit" under Controller > General is the same as entering config redundancy unit secondary?
yes. Its same.
Dont forget to rate all helpful posts
Thank you! Will rate once everything works fine ;)
