narrow DCA Channel List on flexconnect 7500
Sun-Gi Kim
Dear all,
I have problem with flexconnect 7500 and 1140AP that can not be utilized ample channel list.
only flex7500 DCA Channel List are 149, 153, 157, 161.
would you let me know how can I use 36,44,52,60 ... so many channels available in KR country code.
thanks
regards,
Sungi Kim
5 Replies 5
Scott Fella
If you have multiple country codes configured on the WLC, the common power and channel setting for all the configured country codes will apply.  That means that if one country only allows those 4 channels, all the AP's can only use those four channels.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Configured Country Code(s) is KR.
Total with DFS must be 21.
No multiple country codes.
I don't understand why only have 149, 153, 157, 161.
thanks
I don't know.. You have a link that states what channels are available for KR?
-Scott
Are you sure your controller supports kr ? What is the part number of your controller and your aps ? The full part number ..
controller is AIR-CT7510-K9, and all flexconnect AP are AIR-LAP1142N-K-K9.
thanks
