01-09-2012 09:17 PM - edited 07-03-2021 09:20 PM
I could see that antenna gain setting under 802.11b/g ap showing 0 valu. However, the antenna connected to that AP is AIR-1728 which has 5.2dbi. Please let me know if it shows 0 then will I get the Maximum power ? or do we need to change ito some value to get the maximum of the antenna power.
01-09-2012 10:38 PM
So you need to enter the value of "10".
01-09-2012 10:40 PM
Thanks. Will it make difference if the value is 0 ?
01-10-2012 05:44 AM
yes. The value you place in that field tells the WLC how much gain the antenna has, so that it can take it into account for RRM
01-10-2012 06:53 AM
Thanks.One more clarification i need, if they value is 0 will it affect the users with respect to the signal coverage since the value is not 10.
01-10-2012 06:56 AM
Not really, with a value of 0 the WLC assumes a standard 2.2dBi of gain, IIRC. Putting in the correct value for the antenna gain, allows the WLC to make better power settings.
HTH,
Steve
