Need to receive alarms by e-mail for AP Utilization beyond the threshold
JGatti
I am using Cisco Prime 3.1. I need to set a threshold for AP Utilization. Then, need to generate alarms for when the utilization is above that limit and receive those alarms by e-mail. I've seen that some questions about this issue have been made but I couldn't solve my problem. I have seen too that in Monitor/Monitoring Tools/Alarms and Events/Email Notification/AP you can set the security levels for the alarms to be sent and you can indicate the mail address as well. However, I just want to receive AP Utilization over the threshold alarm, not all (i.e.) Critical alarms. Moreover, I couldn't find what is the security level in which utilization over the threshold alarm it is.
Thanks in advance,
Salma Sulthana
Hi JGatti,
Please do refer the link below to customize or create the Threshold Values on prime.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/user/guide/pi_ug/mon-pol-thresh.html
Salma
Salma Sulthana
Hi JGatti,
Salma
