Cisco Community Designated VIP Class of 2020
294
Beginner
No client connectivity whereas 1310 repeater AP associated to parent
I have a WLC2500 which controls some 1310 lightweight APs.
I've loaded an autonomous IOS on one of the 1310 APs, and configure it as repeater.
Repeater is successfully associated with its parent lightweight controlled AP, and receive its IP by this parent.
Clients can associate to my repeater and, with a static IP, can ping repeater IP.
But that's all ! Client packet's can't go outside repeater (ex: ping to gateway) whereas repeater can successfully ping its gateway.
Here is the conf of the repeater and some console messages when repeater associate to parent, and client associate to repeater.
Someone can help me ?
Thank you !
*Mar  1 17:10:37.394: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP MyParentAP 003a.9ad8.69f0 [None]
*Mar  1 17:12:48.700: %DOT11-6-ASSOC: Interface Dot11Radio0, Station AP1310-REPEAT 6067.2079.9ff8 Associated KEY_MGMT[NONE]
AP1310-REPEAT#show dot11 associations
802.11 Client Stations on Dot11Radio0:
SSID [MySSID] :
MAC Address    IP address      Device        Name            Parent         State
003a.9ad8.69f0 2.2.2.2         LWAPP-Parent MyParentAP      -              Assoc
6067.2079.9ff8 172.31.0.99     ccx-client    AP1310-REPEAT   self           Assoc
AP1310-REPEAT#sh run
Building configuration...
Current configuration : 1163 bytes
version 12.4
no service pad
service password-encryption
hostname AP1310-REPEAT
enable secret 5 $1$TAWf$ggggplwqAezCa/Az1Bp/k0
no aaa new-model
dot11 syslog
dot11 ssid MySSID
   authentication open
   guest-mode
   infrastructure-ssid
username Cisco password 7 072C285F4D06
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid MySSID
parent 1 003a.9ad8.69f0
station-role repeater
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip default-gateway 172.31.0.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
1 ACCEPTED SOLUTION
Hall of Fame Master
There isn't much you can do since the WLC's do not support AP's in repeater mode.  There is no solution if you still want to use the 1310's and not install new AP's in lightweight or autonomous.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
5 REPLIES 5
Hall of Fame Master
Re: No client connectivity whereas 1310 repeater AP associated t
Repeaters are not supported on a lightweight environment. Only WGB is supported. Here is a link that explains the workgroup bridges as it may help.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080905cea.shtml
-Scott
Highlighted
Beginner
WGB is a good way to interconnect a wired network to the lightweight environnement.
But what I have far away from lightweight environnement is not a wired network, it is WiFi clients.
So if I use WGB, I might have one AP as client of the lightweight environnement, install another AP to broadcast WiFi, connect both by wire, and bridge them.
Any suggestions ?
Hall of Fame Master
What you need is a dual band access point. This way one radio is used as a bridge and the other to service clients. You would need a dual band for both ends so you can at least use the 5ghz as the backhaul and the 2.4ghz for client access.
-Scott
Beginner
I agree,
This is what I do for another client, with 1552 outdoor APs.
But in this case, client have already 1310 APs installed in autonomous mode, and some of them are in repeater mode.
What I have to do, is to install a WLC2504 controller to pass installation in lightweight mode.
This is the reason why I need to keep repeater mode for certain APs.
Do you think there is a solution ?
Hall of Fame Master
Scott
-Scott
Content for Community-Ad
August's Community Spotlight Awards
