I have the following scenario:
WLC 5508 with VWLAN fully configured according cisco requirements.
Perfect roaming and voice quality for cisco 7925 phone and Nokia E51 with cisco call connect 1.6.
Very bad voice quality and very bad roaming for Nokia E66, Nokia E71 and Nokia E63 with latest cisco call connect and Nokia FW.
(Assume QoS at platinum level for the VoWLAN)
I also noticed the following behaviour:
all phones in standby shows an echo reply to a ping with heavy delay (between 80-200 ms).
Nokia E51 and Cisco 7925 shows an echo reply stable at 3 - 5 ms during a call.
Nokia E66 shows an echo reply unstable with delay 80-200ms during a call.
If I put the E66 in a WLAN with QoS set to silver the phone works, the roaming is pretty better (but not completely satisfying) the voice quality is better but not completely acceptable. Answer to ping is stable at 3-5 ms during a call.
so i can assume that something is not working with E66 (and E71, E63) QoS.
I can add that call manager release 6.1.x has the NOKIA.cop files to recognize the nokia type of phone, it shows S60 in the phone lists but it's not able to recognize the nokia phones and it registers them as 7970 cisco phone.
I thank you all for your collaboration.
Best
Johnny
