OfficeExtend Solution Query
Ryan Morgan
We've recently setup a WLAN infrastructure using a WLC2504 and Aironet 1261 LWAP's; two SSID's are configured on the WLC; one configured for Guest [using lobby ambasador] and one configured for Internal use.
The requirement to deploy the Aironet 600 seris AP's has arisen due to the need to be more flexible with our telewokers.
I've read through the community posts on the subject, Aironet 600 Series OfficeExtend Access Point Configuration Guide and reviewed the capabilities of the WLC2504 yet I'm still a little hazy as to if we can support OfficeExtend with the current infrastructure equipment or if we need to review the design as a whole.
From what I've gathered OfficeExtend is supported on WLC2504's but they cannot be configured as guest anchor controller, also the 2500 series cannot terminate guest traffic outside the firewall only originate guest tunnels.
Does this mean I need to deploy a annother WLC swhich can be cnfigured as an anchor / EoIP such as WLC5508 as guest anchor controller /Office Extend controller in the DMZ with EoIP to the existing 2504?
The reason I ask is I couldn't find documentation with OfficeExtend referenced in context with an existing single WLC deployment, the configuration guide  shows a WLC situated in the DMZ with a publicly reachable IP address and UDP ports 5246 and 5247 open - our solution currently consists of 1x WLC2504 on the internal LAN which presumably we can't just relocate this to the DMZ as internal AP's won't be able to authenticate?.
Ryan Morgan
Vinay Sharma
Level 7
Level 7
For More information on OEAP-600, please watch the "Community Tech-Talk Series" Cisco Office Extend Access Point OEAP-600
https://supportforums.cisco.com/community/netpro/wireless-mobility/begin-wireless/blog/2012/02/24/cisco-office-extend-access-point-oeap-600
Vinay Sharma
Community Manager - Wireless
Thanks & Regards
5 Replies 5
Stephen Rodriguez
It works very similar to having the anchor WLC.  You still configure the FW to NAT UDP 5246/5247 to the inside address of the WLC.  Whether or not it's in the DMZ or not is moot for the most part.
So configure the FW to NAT the above, and configure the Nat IP on the managment interface of the WLC and see if your OEAP will join.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hi Steve,
Wouldn't this pose a secuirty risk? effectively we would be allowing external devices to directly access the corporate network albeit on specific ports.
Just wondering regarding best practices for solution design - I couldn't find any mention of OfficeExtend or OEAP in the SRND; realistically we could do this for our environment but in the case of most of our customers they wouldn't want any device to be able to register with the internal controller - I guess we're portentially two controllers in these cases.
Thanks for your input so far
Ryan
what every device hits the wireless still has to authenticate.  SO if you are running 802.1x with the AD as the backend DB, they would have to compromise an account to gain access.
Then on the wired port, you can confugre security as well, so not just any device can be connected.
Steve
HTH,
Steve
Vinay Sharma
Level 7
Level 7
Vinay Sharma
Thanks & Regards
Thanks Vinay, very useful link which has cleared up some of the questions I had.
