06-01-2015 05:53 PM - edited 07-05-2021 03:20 AM
Hi Guys,
If I have different models of access points says 1000 and 2000 series and if I want to use option 43, do i need to define them separately (I gone through the dhcp doc from cisco and looks like yes i have to as they have different values). Could someone please confirm ?
06-01-2015 07:19 PM
So I have in all my deployments. Works fine without issue. However I think if u leave vci60 blank I think Steve said it would accept any model. But I never tested that ..
06-01-2015 07:28 PM
As a good practice, yes.
08-26-2015 10:51 AM
Check the below document for clear understanding and proper configuration.
http://www.cisco.com/image/gif/paws/97066/dhcp-option-43.pdf
Note: You need to know before configuration the option 60 (VCI) , option 43 and sub-option TLV block .
11-02-2015 02:32 AM
