Community Live- Understanding How Multicast Works with Cisco
68015
OSX: Removing remains from unusual AnyConnect uninstall
Someone has uninstalled the AnyConnect Client on OSX 10.8.5, but without using the graphical uninstaller (just by dragging the folder from the applications bin into the trash bin). Now any further attempts to reinstall the software fail, by  delivering a message during the installation routine saying that a cisco client would already be installed. Scanning the entire system for files having cisco in their filename or folders or having cisco in the content of a file and removing them, lead to no tangible results. My quetion in this case is:
What files may still be on the system - and : is there a way to see WHAT file the installer checks for to determine if there is cisco installed on the system.
And no - i do not want to set up a fresh os x install yet - although that way may be much easier and less time consuming, i want it to have the hard way and I want to know what files are checked by the installer of any connect….
Thanks in advance for any further hints
Dan
1 ACCEPTED SOLUTION
Highlighted
Beginner
Ok, Daniyal and I solved the issue. Here it is:
in Terminal.app:
sudo pkgutil --forget com.cisco.pkg.anyconnect.vpn
After that, you can reinstall the client.
11 REPLIES 11
Highlighted
Beginner
in Terminal.app:
Works like a charm. Excellent solution. Many thanks Serge! I hope that others that run into that kind of problem will find that solution too
Beginner
Worked perfectly!James
Worked perfectly!
James
Beginner
OMG THANK YOU SO MUCH
This also worked for me.
Beginner
Thank you!
Thank you!
Re: OSX: Removing remains from unusual AnyConnect uninstall
Hi ,
it works find and I was able to re-install the client , but what if I need to remove other modules , where initially I installed the full package and I am not able to re-install again [Web Security , diagnostics and reporting tool , ...etc ]
Mohamed
Exactly what I needed to repair the problem. thanks.
Beginner
Worked great for me, thank
Worked great for me, thank you! Have been trying to figure this out for weeks...
Beginner
Partially solved the problem.
Partially solved the problem. But it's still better than nothing. Thank you!
Beginner
Solved
Still does its magic in 2019 on Macos 10.15 running Anyconnect 4.8
Content for Community-Ad
August's Community Spotlight Awards
