I am looking for a way for an external group to have access to a portal or some automated way to add mac addresses to a mac-filter database either on the WLC, Prime, or even using ISE. So using the portal or a method, the user would be able to register a device, and put the MAC Address in and then the device would be off and running. Is there a way to use a template in Prime, or have a limited access to the WLC to be able to register a mac-address to gain access to a WLAN?
