Power adaptor for 2802 access point
abinaya.2.r
Hi. i am ordering a 2802 access point. This AP will not connect to the POE switch. Can you help me  with the part code for the external power source ? I am ordering the below in Cisco portal. Can you help with the power source
AIR-AP2802I-E-K9
AIR-AP-T-RAIL-R
AIR-AP-BRACKET-1
SW2802-CAPWAP-K9
AIR2800-DNA-OPTOUT
6 Replies 6
Leo Laohoo
AIR-PWRINJ6
AIR-PWRINJ6=
AIR-PWR-CORD-XX
Along with power injector power cord is required right?
And more over my doubt is power injector is for poe switches right?
Power injector is for the AP.
Both are for the Aps. You cannot just order a power injector alone.
Yes, you can.
And if you already have a POE switch then maybe you want to try to get that working - for example maybe you've just forgotten to enabled CDP or LLDP on the port.
It would help to mention the code version you're running on the AP and what switch model and code version is.
