12-15-2011 12:18 PM - edited 07-03-2021 09:15 PM
Does anyone know what dbm or mw each of the power local settings are? I see on a 1042 from -1 thru 20 and am assuming 20dBm is 100mW. Anyone know the others?
OM-ess-lab-WLAN1(config-if)#power local ?
<-1 - 20> One of: -1 2 5 8 11 14 17 20
maximum Set power to allowed maximum
Solved! Go to Solution.
12-15-2011 12:22 PM
Hi there...
This blog post I did might help you a little.
However, you are correct 20 dBm is 100mW. And it will get 1/2 each step down, thats why you see 17,14,11 etc ...
Make sense ...?
12-15-2011 12:37 PM
Piggy backing George here.
Keep in mind that 802.11n does change the power scheme a bit, as it accounts for two transmitters not just one, as legacy 5GHz/2.4GHz does.
And finally, the 1-5 are subjective. 1 does not mean 20dBm, it means max power for that band + channel combo.
At one point I had been pushing for Cisco to show the actual dBm with/instead of the 1-5 designator, but I'm not sure where that is at.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
12-15-2011 12:22 PM
Hi there...
Make sense ...?
12-15-2011 12:31 PM
Ya, makes sense. Each 3 db doubles is what I used to remember. I used to know how to calculate this stuff but it has been a while. Thanks
12-15-2011 12:37 PM
HTH,
Steve
12-15-2011 01:37 PM
Good Info as always, Cisco Forums ROCK!
Thanks guys
12-15-2011 01:44 PM
If you find CSC helpful support the rating system!
12-16-2011 10:06 AM
Gerard you are right, CSC Rocks ... . Don't forget to mark this questions as Answered.
Vinay Sharma
Community Manager
