03-24-2009 12:11 PM - edited 07-03-2021 05:21 PM
Is there a way to gracefully power down a Wireless LAN Controller or do you just turn it off? I can't find anything in the manuals.
Solved! Go to Solution.
03-24-2009 02:04 PM
Just power it off. There's nothing more graceful than that for a Cisco appliance.
Just make sure that you are not in the middle of doing something, like up/downloading of the firmware.
03-24-2009 02:04 PM
03-24-2009 04:32 PM
Thanks for the rating.
