2264
Beginner
Predownload issue
Opened a TAC case and so far they have been very helpful.  I should go on to say that not every wireless case with TAC is horrible, but there are some guys that have no business taking cases.
I'm sure my frustration yesterday got the best of me, so I needed to clarify that TAC in general is great... but I have had some not so great experiences.
Will update when I have more info from TAC.
Thanks,Tony
Predownload issue
@Tony,
Tony any update on your progress?  I am currently running 5508 with version 7.0.116.0.  When I try to predownload a backup image to my APs nothing happens, actually one of 59 pre downloaded.
I have tried several times.
(Cisco Controller) >show ap image all
Total number of APs.............................. 59
Number of APs
        Initiated....................................... 0
        Predownloading.................................. 0
        Completed predownloading........................ 1
        Not Supported................................... 0
        Failed to Predownload........................... 0
                                                 Predownload     Predownload
AP Name            Primary Image  Backup Image   Status          Version        Next Retry Time  Retry Count
xxxxxxxxx            7.0.116.0      0.0.0.0        None            None           NA               NA
xxxxxxxxx            7.0.116.0      7.0.116.0      Complete        7.0.116.0      NA               NA
Highlighted
Beginner
Re: Predownload issue
I completely forgot to update this...
According to TAC, this is an unresolved bug that started in a previous code release.  I am currently running 7.0.116.0, that was to get past a bug in 7.0.98.0.  I am planning to upgrade to 7.0.220.0 to fix the VLAN Select feature(interface group).  So I can't confirm whether 7.0.116.0 will give me the same problem as 7.0.98.0 did in my original post.
How I fixed 7.0.98.0:
If you log into an Access Point, you'll see that the code really did upload.  The bug exists where the WLC is supposed to issue the boot system flash command and tell the AP to boot the new image.
I use SecureCRT as a telnet manager.  So, I modified a script that logs in to the AP's directly, changes the boot sys flash variable to run the new image, writes the config to memory, and exits.  It reads a list of devices from a text file that I populated with a device report from WCS.  I know all of this may sound complicated, but it's not.  It's certainly better than manually logging into 500 AP's to do this.
It appears that I can't attach any files here, so I'll paste the code for others to use if they need it.  As far as I know, this only works with SecureCRT, but you may be able to run it if other telnet managers run scripts.
FYI, I had to manually upgrade at least one AP to get the software version that I put in the SecureCRT.vbs
Tony
Beginner
Predownload issue
Actually, I was able to upload to my profile area...
https://supportforums.cisco.com/servlet/JiveServlet/downloadBody/23686-102-1-58571/scripts.zip
If that link doesn't work, go check my profile.
Predownload issue
WOW!!!  Very cool.  I will give it a shot.
Beginner
Predownload issue
Let me know if I can answer any questions...
Learn something new today! Thanks Tony I am going to take a peek at this over the weekend. +5
Beginner
Glad I could help... that's a first for me I think(being on the helping end)
Beginner
Predownload issue
This saved my butt. Thanks Tony. I tried finding the bug on Cisco's site but nothing. Have the number just for reference?
Beginner
I can't recall what the actual bug ID is... sorry. Glad the script worked out for you!
Tony
>>> dkorell 6/4/2012 6:29 PM >>>
Home ( https://supportforums.cisco.com/index.jspa )
Re: Predownload issue created by dkorell ( https://supportforums.cisco.com/people/dkorell ) in Other Wireless - Mobility Subjects - View the full discussion ( https://supportforums.cisco.com/message/3652284#3652284 )
This saved my ****. Thanks Tony. I tried finding the bug on Cisco's site but nothing. Have the number just for reference?
Reply to this message by going to Home ( https://supportforums.cisco.com/message/3652284#3652284 )
Start a new discussion in Other Wireless - Mobility Subjects at Home ( https://supportforums.cisco.com/choose-container!input.jspa?contentType=1&containerType=14&container=2043 )
This message is confidential, intended only
for the named recipient(s) and may contain
information that is privileged or exempt from
disclosure under applicable law. If you are
not the intended recipient(s), you are notified
that the dissemination, distribution or copying
of this message is strictly prohibited. If you
received this message in error, or are not the
named recipient(s), please notify the sender
and delete this e-mail from your computer.
ETMC has implemented secure messaging for
certain types of messages. For more information
about our secure messaging system, go to:
http://www.etmc.org/mail/
Thank you.
Predownload issue
Tony
+5!
Content for Community-Ad
August's Community Spotlight Awards
