Problem setting Flexconnect Local Authentication
p-blalock
Not sure if this is a bug or not, but whenever I try to enable Flexconnect Local Auth at the SSID level, I get the following "The following errors occurred while updating the WLAN: Flexconnect Local Authentication is not supported with Local Switch Central DHCP."  I do have local switching on the Flexconnect, but I do not have "Switch Central DHCP."  I then created a Flexconnect Group and enabled "Enable AP Local Authentication"and No Central DHCP, then palced the APs into that Flexconnect Group, but still seeing "%DOT1X-3-INVALID_REPLAY_CTR" in the WLC syslog while clients roam.
I have two questions:
Why can't I enable Flexconnect Local Auth per SSID?
How can I determine that Flexconnect Local Auth is actually enabled and working?
WLC version is 8.3.122.0 (multiple controllers 8510s and AIR-CT2504-K9S - happens on all them)
3 SSIDs, two in Flexconnect mode
APs receiving DHCP from local switch
Flexconnect clients receiving DHCP from same local switch
Clients for tunnel SSID receiving DHCP from central server
Stumped.  Anyone have a suggestion?
Best
Clients
p-blalock
Update:  I had to disable the SSID first, then had to disable FT for the SSID - didn't know that you can't do local auth and FT together.
