Problem with MSE tracking
Hello.
I have a problem with MSE tracking client in my network.
What we have:
PI 1.3 with evaluation license (temporary)
MSE 7.4.100 with 3k device licenses (hardware appliance 3355)
WLC 5508 7.4.100
For now MSE is reacheble from PI and WLC, all setings are synchronized, NMSP status is active, mse assigned for maps and synchronized, on map we have 3 APs, but in Contex Aware tab we didnt see any tracking devices, all counts 0.
Any  suggestions why it can be ?
Thank you very much.
Vinay Sharma
Level 7
Level 7
MSE not discovering Clients with CISCO SINGLE BAND AP
CSCuh07165
Description
Symptom:
MSE discovery is not working with Single Band AP
Conditions:
Single Band AP
Workaround:
change Single band AP with Dual Band
This issue is captured in the following document:
Cisco Mobility Services Engine (MSE) unable to discover clients and rogues
Vinay Sharma
Community Manager
Thanks & Regards
12 Replies 12
Scott Fella
Can you console into the MSE and post the: /etc/init.d/msed status
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Yes, only in monday, but as i remember all status is fine.
You have the Context Aware status enabled on PI?  If so, try removing it and enabling it back.
Scott
-Scott
i will try
Hello.
Nothing can help: re-enable, restart, remove.
Here status
]0;root@mse:~ [root@mse ~]# /etc/init.d/msed status
STATUS:
Health Monitor is running
Starting MSE Platform, Waiting to check the status.
MSE services are up, getting the status
Server Config
Product name: Cisco Mobility Service Engine
Version: 7.4.100.0
Health Monitor Ip Address: 1.1.1.1
High Availability Role: 1
Hw Version: V01
Hw Product Identifier: AIR-MSE-3355-K9
Use HTTP: false
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Days to keep events: 2
Session timeout in mins: 30
DB backup in days: 2
[7m--More-- [27m
[K
Services
Service Name: Context Aware Service
Service Version: 7.4.0.38
Admin Status: Enabled
Operation Status: Up
Service Name: WIPS
Service Version: 1.0.4041.0
Admin Status: Disabled
Operation Status: Down
Service Name: Mobile Concierge Service
Service Version: 2.0.0.37
Service Name: Location Analytics Service
Service Version: 1.0.0.12
Server Monitor
Server start time: Fri Apr 05 12:22:05 MSK 2013
Server current time: Mon Apr 08 10:38:43 MSK 2013
Server timezone: Europe/Moscow
Server timezone offset: 14400000
Restarts: 7
Used Memory (bytes): 136924360
Allocated Memory (bytes): 533528576
Max Memory (bytes): 1908932608
DB virtual memory (kbytes): 0
DB virtual memory limit (bytes): 0
DB disk memory (bytes): 2184652416
DB free size (kbytes): 0
Active Sessions
[7m--More-- [27m
Session ID: 23444
Session User ID: 1
Session IP Address: 172.30.0.70
Session start time: Fri Apr 05 12:45:28 MSK 2013
Session last access time: Mon Apr 08 10:37:44 MSK 2013
Default Trap Destinations
Trap Destination - 1
IP Address: 172.30.0.100
Last Updated: Thu Apr 04 15:49:32 MSK 2013
Total Active Elements(Wireless Clients, Tags, Rogue APs, Rogue Clients, Interferers, Wired Clients): 0
Active Wireless Clients: 0
Active Tags: 0
Active Rogue APs: 0
Active Rogue Clients: 0
Active Interferers: 0
Active Wired Clients: 0
Active Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients, Tags) Limit: 3000
Active Sessions: 1
Wireless Clients Not Tracked due to the limiting: 0
Tags Not Tracked due to the limiting: 0
Rogue APs Not Tracked due to the limiting: 0
Rogue Clients Not Tracked due to the limiting: 0
Interferers Not Tracked due to the limiting: 0
Wired Clients Not Tracked due to the limiting: 0
Total Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients) Not Tracked due to the limiting: 0
Context Aware Sub Services
Subservice Name: Aeroscout Tag Engine
[7m--More-- [27m
Subservice Name: Cisco Tag Engine
And today i found few strange info messages
4/08/13 10:45:53.80 INFO[location] [33] Failed to find heatmap for AP interface 34:a8:4e:4e:07:d0-5.0-0
4/08/13 10:45:53.80 INFO[location] [33] Failed to find heatmap for AP interface 34:a8:4e:c2:72:d0-5.0-0
4/08/13 10:45:53.80 INFO[location] [33] Failed to find heatmap for AP interface 34:a8:4e:c2:f8:50-5.0-0
Any idea?
We also have the same problems with MSE and experience the exact same log messages in the logs.
Looking forward to find the solution to this problem.
regards
Knut Eilif Husa
Scott Fella
The operational service is down as it shows on what you posted. Did you enable the service in Prime?
-Scott
which service exactly?
I was looking at the wrong service.... so you do have it up but the MSE doesn't show any clients... The only thing I would try is to remove the MSE and add teh MSE back to PI.  There is nothing else you can do especially if the WLC5508 has clients authenticated to itself.  The WLc sends the info to PI and then MSE handles it from there.
Scott
-Scott
had a similar issue with my internal MSE.  I had to default it, and then run throught the setup script again.  Once I did that I started tracking clients
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Vinay Sharma
Level 7
Level 7
CSCuh07165
Description
Symptom:
Conditions:
Single Band AP
Workaround:
Vinay Sharma
Community Manager
Thanks & Regards
