Production WLAN
Thomas Ley
I have 3 ea.  4404 with 90 APs  (1231 & 1240) with 30 LXE clients. I'm having issues with overlapping, high CRC counts, RF signal bleedover, and I'm trying to figure out how to make adjustments; such as transmit power threshold settings or channel assignment without creating client and end user havoc? RRM will automatically adjust associated nearby APs if I make a change to one of them. If I turn off RRM that could also create havoc. What is the best way to test changes in a production WLAN environment and yet protect the intergity of the current WLAN? It's working but I'm tasked with tweeking it so as new clients and applications are added the WLAN infrasture will not be the issue.
Any suggestions
Tom
Tom
Amjad Abdullah
Tom:
We dont even know
he issue is due Channel overlapping. Do we?
The issue could be related to neighbor APs interference, noise around or maybe metallic environment.
You betters do a site survey to decide.
You can disable DCA and start assigning static channels if you make sure the issue is due overlapping.
Amjad
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
Tom:
We dont even know
Amjad
Thanks for your help.
TL
