221
Question about Antenna settings on 1852E in Mobility express
Hi all,
I'm not sure about the settings of the"Antenna Configuration" for an 1852E Mobility Express Access Point.
If I look at the datasheet for the 1852E, it notes that 2.4GHz uses 3 antennas. -> Does that mean that for Radio 1 only 3 Antennas need to be ticked (which 3)?
The antennas I use are AIR-ANT2524DW-R-RF 2.4GHz2 dBi/5 GHz4 dBi DipoleAnt.White,RP-TNC
so, is it correct that I have to change the Antenna Gain for 2.4GHz to 4 x 0.5 dBi?
Thanks a lot
Willem
1 REPLY 1
Rising star
Re: Question about Antenna settings on 1852E in Mobility express
>>> Does that mean that for Radio 1 only 3 Antennas need to be ticked <<<
-> NO. the 4th is also used, it means only max. 3 antenna's are used to transmit, this could vary according to client position.
if 4 antenna's are mounted -> all boxes ticked
the current shown  antenna gain settings are correct
   2,4GHz: 2dBi -> 4x0.5dBi
   5GHz: 4dBi -> 8x0.5dBi
Content for Community-Ad
August's Community Spotlight Awards
