09-17-2007 07:27 AM - edited 07-03-2021 02:38 PM
we have found a specular error on the radio interface of the Access Point.
Errors on the Radiso Interface area as below.
Dot11Radio0 is up, line protocol is up
47575 output errors, 0 collisions, 4 interface resets
0 lost carrier, 0 no carrier
Please Help me up.
SRIHARI
09-21-2007 10:30 AM
Reset indicate number of tims interface has been reset. This happens when th packet queued for transmission is not sent within specified seconds. This might be due to a cable problem on serial line or malfunctioning modem that is not supplying transmit clock signals.
09-21-2007 11:23 PM
Thank you Dear,
But this problem araises on all the AP's that are in the network. so this cannot be a cable problem. What could be reason.
if the radio interfaces are reset frequently what could be the cause.
Srihari
09-24-2007 02:17 PM
Are all your access points operating on the same channel? It sounds like some sort of malformed packets that they may be receiving...
