Re-associate APs with new controller
WILLIAM STEGMAN
Level 4
Level 4
We have WLCs at two different data centers using different Internet pipes.  I'm looking for a way to modify the controller association of multiple APs to better distribute the load on the Internet pipes. Right now the only way I see to do this is to go to each AP individually and modify the HA primary controller and reboot the AP one at a time.  Is there a way to modify this using WLC or Prime Infrastructure wholesale?
thank you,
Bill
Update, I found this is possible using a template in Prime Infrastructure.
Leo Laohoo
Cisco do NOT recommend inter-controller roaming.  If, say a building has 400 APs, don't split them in two different controllers.
