Reason:802.11 Association failed repeatedly. ReasonCode: 2
mkellow
Hi everyone,
I am having an issue with 7921 handsets dropping from the wireless LAN. I am seeing the following log entries on the WLC:
Client Excluded: MACAddress:XX:XX:XX:XX:XX:XX Base Radio MAC  :00:00:00:00:00:00 Slot: 0 User Name: xxxxxx Ip Address: XXX.XXX.XXX.XXX  Reason:802.11 Association failed repeatedly.  ReasonCode: 2
The wireless LAn has been in for over 4 years and has been running fine.
If there are any particular logs that anybody thinks will help to resolve this i will be happy to post them.
WLC = 4402
Software Version = 7.0.235.0
AP's = AIR-LAP1242AG-A-K9
Cheers
Matt
10 Replies 10
Scott Fella
It's a generic error which is: Previous authentication no longer valid
Is it just with a specific phone? Might be a phone going bad, maybe reset the phone and configure it again.
-Scott
Hi Scott,
It seems to be a number of the 7921 phones. at least 3 that i can see so far.
Cheers
Matt
Saurav Lodh
Level 7
Level 7
You can find similiar discussions over here
https://supportforums.cisco.com/thread/340664
Good afternoon Sauray,
I have seen that post and while it is the same error there is no actual confirmed answer .
Matt
Amjad Abdullah
Hi Matt,
What type of security SSID is using?
Were there any recent changes before the problem appears?
Could you try association with open SSID and see if that shows same problem?
It is also advisable to check the RF status where those phones are being used.
Amjad
Rating useful replies is more useful than saying "Thank you"
Hi Amjad,
Ok here we go :
SSID Sec Type     WPA2 AES
Ath Man               802.1X+CCKM
Auth server          Cisco ACS
There have not been any changes for 6 months
I have also rebooted the controller and all associated access poonts
Hope that this info is what you need to help me
Cheers
Matthew
mkellow
Ok so this appears to have been caused by the WLC that the access points were associated to. After changing all of the access points to our backup WLC the problem has completly disappeared and the users have advised that they are no longer having issues with their phones.
Thinking my next step should be to re install the firmware and see if this resolves the issue ?
Cheers
Matt
Your backup WLC has same software version and same hardware model?
mkellow
Ok after reloading the firmware on the WLC and testing we still have the same Issue. Is there anyone else out there that has this issue ? and have you managed to resolve it ?
Cheers
Matt
Matt,
Can you post the following from your controller cli:
>show wlan #
>show 802.11b
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
