07-10-2013 06:18 PM - edited 07-04-2021 12:23 AM
Hi everyone,
I am having an issue with 7921 handsets dropping from the wireless LAN. I am seeing the following log entries on the WLC:
Client Excluded: MACAddress:XX:XX:XX:XX:XX:XX Base Radio MAC :00:00:00:00:00:00 Slot: 0 User Name: xxxxxx Ip Address: XXX.XXX.XXX.XXX Reason:802.11 Association failed repeatedly. ReasonCode: 2
The wireless LAn has been in for over 4 years and has been running fine.
If there are any particular logs that anybody thinks will help to resolve this i will be happy to post them.
WLC = 4402
Software Version = 7.0.235.0
AP's = AIR-LAP1242AG-A-K9
Cheers
Matt
07-10-2013 06:24 PM
It's a generic error which is: Previous authentication no longer valid
Is it just with a specific phone? Might be a phone going bad, maybe reset the phone and configure it again.
07-10-2013 08:42 PM
Hi Scott,
It seems to be a number of the 7921 phones. at least 3 that i can see so far.
Cheers
Matt
07-10-2013 10:30 PM
You can find similiar discussions over here
07-10-2013 11:15 PM
Good afternoon Sauray,
I have seen that post and while it is the same error there is no actual confirmed answer .
Matt
07-11-2013 01:41 AM
Hi Matt,
What type of security SSID is using?
Were there any recent changes before the problem appears?
Could you try association with open SSID and see if that shows same problem?
It is also advisable to check the RF status where those phones are being used.
Amjad
Rating useful replies is more useful than saying "Thank you"
07-15-2013 10:03 PM
Hi Amjad,
Ok here we go :
SSID Sec Type WPA2 AES
Ath Man 802.1X+CCKM
Auth server Cisco ACS
There have not been any changes for 6 months
I have also rebooted the controller and all associated access poonts
Hope that this info is what you need to help me
Cheers
Matthew
07-25-2013 05:05 PM
Ok so this appears to have been caused by the WLC that the access points were associated to. After changing all of the access points to our backup WLC the problem has completly disappeared and the users have advised that they are no longer having issues with their phones.
Thinking my next step should be to re install the firmware and see if this resolves the issue ?
Cheers
Matt
08-16-2013 11:58 AM
Your backup WLC has same software version and same hardware model?
08-15-2013 10:03 PM
Ok after reloading the firmware on the WLC and testing we still have the same Issue. Is there anyone else out there that has this issue ? and have you managed to resolve it ?
Cheers
Matt
08-15-2013 10:21 PM
Matt,
Can you post the following from your controller cli:
>show wlan #
>show 802.11b
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
