06-06-2018 02:11 PM - edited 07-05-2021 08:42 AM
Hello we are debating on what version of code we would like to upgrade too. Currently we are running 8.3.133.0 and debating on moving to 8.3.141 or 8.5.120. Does anyone know the major differences between the two versions?
I know running the latest code is never a good idea so im am leaning towards 8.3.141.
Solved! Go to Solution.
06-06-2018 02:40 PM - edited 06-06-2018 02:42 PM
In a few days 8.2 MR7 and 8.5 MR3 will be posted on CCO. This will be the last maintenance release for the 8.2 train, for 8.5 the next MR is planned for later this summer. Cisco is putting a lot of effort in the 8.5 train so it can get the stable/MD label somewhere later this year.
Regarding your deployment; the "best fit" heavily depends on the hardware and configuration within your infrastructure. I highly recommend you to bookmark this page, read the release notes, keep an eye on the support forums and perform a "bug scrub" once you have selected a release. Be aware that the release you are referring to (8.3 MR4) will also be "reposted" in a few days with a specific regulatory domain bug fixed, so I would at least wait for that one if you decide to stick with 8.3. Good luck!
Please rate useful posts... :-)
06-07-2018 07:16 AM
Great thank you! This is very helpful.
06-06-2018 02:58 PM
06-07-2018 01:13 AM
