Highlighted
Enthusiast
Recommended WLC software version
Can anyone recommend a WLC software version. software.cisco.com hasn't got a suggested and all the available versions are ED releases.
1 ACCEPTED SOLUTION
Re: Recommended WLC software version
May be you can check tac recommended link:
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
Once you choose version check its release notes.
3 REPLIES 3
Highlighted
Hall of Fame Community Legend
Pick any version & read the Release Notes.
Highlighted
Beginner
Leo! :)
More specifically narrow down the choices by checking which versions support the hardware (WLC and APs) you'll be using.  Then look at the features you want to use and that may narrow your options further.  Then go for the latest build of the major release which you select.
FYI: 8.0.152.0 (which is available) is MD not ED but I wouldn't recommend it as it's close to end of support so if your hardware is supported in a later release you should probably be looking at minimum 8.3.
https://www.cisco.com/c/en/us/support/wireless/wireless-lan-controller-software/products-release-notes-list.html
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Content for Community-Ad
August's Community Spotlight Awards
