01-21-2015 03:56 AM - edited 07-05-2021 02:19 AM
Dear community,
I was having several countries configured on a pair of WLC's.
I know it is not optimal to have too much countries codes on the same WLC's, in order to reduce this I have a question :
I see that for instance regulatory domain "E" covers Belgium, France, Netherland, Switzerland etc...
Is it an issue to add for i.e. only Belgium (under the countries list) and put the AP under Belgium even if located physically in France ?
My attempt is to reduce the number of countries and I trying to understand if this is feasible or could conduct to other issues...
Thanks for your replies,
Solved! Go to Solution.
01-21-2015 05:51 AM
I wouldn't say it's not optimal since you are following regulations. Can you reduce the number of country codes, sure you can but you might also be breaking the regulation for that country. I know that Cisco is looking at being able to add many country codes and the AP TX and Power will not be restricted to what all the country codes have in common. You would be able to add many different country code and the AP will be allowed to use all it channels and power levels for that country code.
-Scott
01-21-2015 05:51 AM
-Scott
01-21-2015 06:19 AM
Dear Scott,
Thanks for your reply, so technically it won't a problem, it is more legal issue in your opinion ?
Any ideas when Cisco could release this ? next 8.x version ?
Thanks again
