reload capwap ap from cli
Josh Sprang
I need to reload a capwap ap from cli  but I cannot figure out how to.  reload command is gone.  Shutting the switchport does not work cause it is plugged into a power injector.  How can I reload v15.3 from cli??  It is not joined to the controller, so reload will not work from there.  Thanks
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Version 15.3(3)JA1, RELEASE SOFTWARE (fc1)
WAR572-APA123_A#?
Exec commands:
  <1-99>           Session number to resume
  access-enable    Create a temporary Access-List entry
  access-profile   Apply user-profile to interface
  access-template  Create a temporary Access-List entry
  capwap           capwap exec commands
  cd               Change current directory
  debug            Debugging functions (see also 'undebug')
  dir              List files on a filesystem
  disable          Turn off privileged commands
  do-exec          Mode-independent "do-exec" prefix support
  dot1x            IEEE 802.1X Exec Commands
  eap              EAP Exec Commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  help             Description of the interactive help system
  if-mgr           IF-MGR operations
  led              LED functions
  lock             Lock the terminal
  logging          Handles logging operations
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapconfig       OfficeExtend AP configurations
  lwapp            lwapp exec commands
  monitor          Monitoring different system events
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  partition        Partition disk
  ping             Send echo messages
  pwd              Display current working directory
  routing-context  Routing Context
  send             Send a message to other tty lines
  show             Show running system information
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  verify           Verify a file
  where            List active connections
Leo Laohoo
debug capwap console cli
reload
6 Replies 6
Leo Laohoo
reload
Leo,
Thanks for the response I do not see the console option..  I tired debug capwap client cli but that did not work.  see below..
WAR572-APA123_A#debug capwap ?
  am           KAM-AP debug
  client       CAPWAP Client Debug Options
  flexconnect  CAPWAP FlexConnect Debug Options
  ids          WIDS debug
  mcast        CAPWAP MCAST Debug Options
  mfp          CAPWAP MFP Debug Options
  rm           CAPWAP RM Debug Options
WAR572-APA123_A#debug capwap clie
WAR572-APA123_A#debug capwap client ?
  avc             CAPWAP Client AVC
  cli             CAPWAP Client Cli Messages
  config          CAPWAP Client Config Messages
  detail          CAPWAP Client Detail Messages
  error           CAPWAP Client Error Messages
  event           CAPWAP Client Event Messages
  fwd             CAPWAP Client dot11 forwarding
  hexdump         CAPWAP Client Hexdump Messages
  info            CAPWAP Client Info Messages
  lsc             CAPWAP Client LSC Events
  mgmt            CAPWAP Client dot11 mgmt
  packet          CAPWAP Client Packets
  payload         CAPWAP Client Payload Messages
  predownload     CAPWAP Client Predownload Messages
  probe           CAPWAP Client dot11 probe
  qos             CAPWAP Client QoS
  reassembly      CAPWAP Client Fragment Reassembly
  tcp-mss-adjust  CAPWAP client MSS adjust
  tcp-mss-print   CAPWAP Client MSS print
WAR572-APA123_A#debug capwap client cli
CAPWAP Client CLI display debugging is on
WAR572-APA123_A#rel
You won't.  It's a hidden command.
yep your right it worked.  Thanks
Thanks, this worked!
robertodevis
Thanks @Leo Laohoo, this worked perfectly!
