578
Participant
Remote Site Having Wifi Slowness
Very vague issue I know.
From what I have gathered so far, download speeds on the wifi are fine at times and sporadically slow at 4Mbps downloads on a 100Mbps circuit. I do see some drops on the Internet circuit connecting interface, but not a very high amount.
I am looking at all angles - not just wifi...Internet facing interface on firewall for speed and duplex, but I am thinking this is a wifi issue as we are not experiencing the same slowness on the wired. Also, these people are stationary so likely not a roaming issue.
At the remote site we are using 37021 APs using FlexconnectAP mode. Internet traffic is directed to the local Internet circuit..as previously mentioned 100Mbps.
There should not be any issues with contention as there are only 5 people at the site - going to be many more in the future.
And the is plenty of AP coverage
Because this is in an urban environment, I'm am first thinking this could be an interference issue.
I admit that I am trying to take the easy way out of this issue and trying to find a smoking gun, but isnt there a configuration on the AP that fixes interference in an Urban environment with many wireless signals?
If not, where should I start? Wireshark, Controller logs, switch logs. I will paste any and all
Thank you
Everyone's tags (1)
8 REPLIES 8
VIP Mentor
I would suggest below
1. Using a wired PC (on the same vlan wireless users use) test the performance over 1 hr period and see bench mark speeds you get.
2. Do a comparison test with a wireless user
3. If you see considerable performance drop, first check the configuration and make sure WPA2-AES  with WMM enabled on WLAN. Also check "show client detail <mac_addr>" output to confirm RSSI & SNR of the clients. Also check the wireless client capability (spatial streams,802.11n/ac, etc)
4. All values in number 3 indicate client should get higher througput, try to go with different version of software code and see.
Rasika
*** Pls rate all useful responses ***
Participant
Thanks Rasika for your
Thanks Rasika for your response.
Could you explain what you mean by "all values in number 3"?
I cannot find the setting for "WMM" under the WLAN...
Also, do you think we should enable "Avoid Persistent Non-WiFi Interference" under wireless
Thank you, Pat.
VIP Mentor
Post "show client <mac_addr>"
Post "show client <mac_addr>" output for your wireless client when it experience this slowness.
Also post "show wlan <wlan_id>" to see how you configure the SSID for this.
To see software version "show sysinfo" output would be useful as well.
Rasika
Participant
Thanks Rasika
Thanks Rasika
I will be sure to post the "show client" when the user is experiencing issues.
Could you please answer the questions below when you have a moment?
Thank you
VIP Mentor
WLAN > QoS > WMM Policy [ you can have either required or allowed ]
If you have enabled EDRRM, then it is good to tick that box, so if AP detect some non-wifi interference on particular channel, then AP will change its channel to avoid that interference.
Refer this post for more detail
https://mrncciew.com/2013/05/02/event-driven-rrm/
Rasika
Highlighted
Participant
Here is some show client info
Here is some show client info:
Client MAC Address............................... 7c:7a:91:bf:33:9e
Client Username ................................. USER
AP MAC Address................................... 84:3d:c6:08:23:d0
AP Name.......................................... BOS-AP07
AP radio slot Id................................. 1
Client State..................................... Associated
Client User Group................................ USER
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 1
Wireless LAN Network Name (SSID)................. SSID
Wireless LAN Profile Name........................ SSID
Hotspot (802.11u)................................ Not Supported
BSSID............................................ 84:3d:c6:08:23:df
Connected For ................................... 3274 secs
Channel.......................................... 161
IP Address....................................... 10.25.222.61
Gateway Address.................................. 10.25.222.1
Netmask.......................................... 255.255.254.0
Association Id................................... 2
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
--More-- or (q)uit
Client CCX version............................... 4
Client E2E version............................... No E2E support
Re-Authentication Timeout........................ 301
QoS Level........................................ Silver
Avg data Rate.................................... 0
Burst data Rate.................................. 0
Avg Real time data Rate.......................... 0
Burst Real Time data Rate........................ 0
Avg Uplink data Rate............................. 0
Burst Uplink data Rate........................... 0
Avg Uplink Real time data Rate................... 0
Burst Uplink Real Time data Rate................. 0
802.1P Priority Tag.............................. disabled
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
Qos Map Capability............................... No
WMM Support...................................... Enabled
  APSD ACs.......................................  BK(T/D)  BE(T/D)  VI(T/D)  VO(T/D)
Current Rate..................................... m8 ss2
Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0,
    ............................................. 48.0,54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
--More-- or (q)uit
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Audit Session ID................................. 0a14cb0b0002b1c55829d83d
AAA Role Type.................................... none
Local Policy Applied............................. none
IPv4 ACL Name.................................... none
FlexConnect ACL Applied Status................... Unavailable
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Layer2 ACL Name.................................. none
Layer2 ACL Applied Status........................ Unavailable
URL ACL Name..................................... none
URL ACL Applied Status........................... Unavailable
Client Type...................................... SimpleIP
mDNS Status...................................... Disabled
mDNS Profile Name................................ none
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
Authentication Key Management.................... CCKM
Encryption Cipher................................ CCMP (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
--More-- or (q)uit
EAP Type......................................... PEAP
FlexConnect Data Switching....................... Local
FlexConnect Dhcp Status.......................... Local
FlexConnect Vlan Based Central Switching......... No
FlexConnect Authentication....................... Central
FlexConnect Central Association.................. No
FlexConnect VLAN NAME............................ SSID
Quarantine VLAN.................................. 0
Access VLAN...................................... 0
Local Bridging VLAN.............................. 222
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Not implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 225
      Fast BSS Transition........................ Not implemented
      11v BSS Transition......................... Not implemented
Client Wifi Direct Capabilities:
      WFD capable................................ No
      Manged WFD capable......................... No
      Cross Connection Capable................... No
--More-- or (q)uit
      Support Concurrent Operation............... No
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 1739527
      Number of Bytes Sent....................... 17284424
      Total Number of Bytes Sent................. 17284424
      Total Number of Bytes Recv................. 1739527
      Number of Bytes Sent (last 90s)............ 16724
      Number of Bytes Recv (last 90s)............ 33112
      Number of Packets Received................. 10162
      Number of Packets Sent..................... 19363
      Number of Interim-Update Sent.............. 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Id Request Msg Failures...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Request Msg Failures......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of EAP Key Msg Failures............. 0
      Number of Data Retries..................... 7927
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 1
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
--More-- or (q)uit
      Number of Mic Missing Packets.............. 0
      Number of RA Packets Dropped............... 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -59 dBm
      Signal to Noise Ratio...................... 35 dB
Client Rate Limiting Statistics:
      Number of Data Packets Received............ 0
      Number of Data Rx Packets Dropped.......... 0
      Number of Data Bytes Received.............. 0
      Number of Data Rx Bytes Dropped............ 0
      Number of Realtime Packets Received........ 0
      Number of Realtime Rx Packets Dropped...... 0
      Number of Realtime Bytes Received.......... 0
      Number of Realtime Rx Bytes Dropped........ 0
      Number of Data Packets Sent................ 0
      Number of Data Tx Packets Dropped.......... 0
      Number of Data Bytes Sent.................. 0
      Number of Data Tx Bytes Dropped............ 0
      Number of Realtime Packets Sent............ 0
      Number of Realtime Tx Packets Dropped...... 0
      Number of Realtime Bytes Sent.............. 0
      Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
--More-- or (q)uit
      BOS-AP01(slot 0)
        antenna0: 18 secs ago.................... -61 dBm
        antenna1: 18 secs ago.................... -60 dBm
      BOS-AP01(slot 1)
        antenna0: 20 secs ago.................... -63 dBm
        antenna1: 20 secs ago.................... -60 dBm
      BOS-AP06(slot 0)
        antenna0: 18 secs ago.................... -48 dBm
        antenna1: 18 secs ago.................... -44 dBm
      BOS-AP06(slot 1)
        antenna0: 20 secs ago.................... -58 dBm
        antenna1: 20 secs ago.................... -57 dBm
      BOS-AP07(slot 0)
        antenna0: 18 secs ago.................... -54 dBm
        antenna1: 18 secs ago.................... -50 dBm
      BOS-AP07(slot 1)
        antenna1: 20 secs ago.................... -65 dBm
      BOS-AP03(slot 0)
        antenna0: 1226 secs ago.................. -81 dBm
        antenna1: 1226 secs ago.................. -82 dBm
      BOS-AP04(slot 0)
        antenna0: 1226 secs ago.................. -74 dBm
--More-- or (q)uit
        antenna1: 1226 secs ago.................. -76 dBm
      BOS-AP04(slot 1)
        antenna0: 20 secs ago.................... -79 dBm
        antenna1: 20 secs ago.................... -84 dBm
      BOS-AP02(slot 0)
        antenna0: 18 secs ago.................... -83 dBm
        antenna1: 18 secs ago.................... -85 dBm
DNS Server details:
      DNS server IP ............................. x.x.x.x
Assisted Roaming Prediction List details:
 Client Dhcp Required:     True
Allowed (URL)IP Addresses
AVC Profile Name: ............................... SSID
Fastlane Client: ................................ No
I attached a link test from the Controller to the client as well...seems to be alot of Transmit Replies at AP everytime I run the test.
Also, I would like to mention that we are using a mix of 3702I-A-K9 and B-K9 APs. I've read that it shouldn't cause any issues, but I thought it was worth mentioning.
Thx, Pat
Participant
Here is the WLAN and sysinfo:
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... SkillSecure
Network Name (SSID).............................. SkillSecure
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Enabled
     DHCP ....................................... Enabled
     HTTP ....................................... Enabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum Clients Allowed.......................... Unlimited
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
ATF Policy....................................... 0
Number of Active Clients......................... 393
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ skillsecure
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
WLAN URL ACL..................................... unconfigured
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
--More-- or (q)uit
PMIPv6 Mobility Type............................. none
    PMIPv6 MAG Profile........................... Unconfigured
    PMIPv6 Default Realm......................... Unconfigured
    PMIPv6 NAI Type.............................. Hexadecimal
    PMIPv6 MAG location.......................... AP
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
--More-- or (q)uit
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... 802.1P (Tag=0)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 10.20.116.12 1812
   Authentication................................ 10.1.116.112 1812 *
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
--More-- or (q)uit
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
      OSEN IE.................................... Disabled
      Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Enabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Enabled
         PMF-PSK(802.11w)........................ Disabled
         OSEN-1X................................. Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
--More-- or (q)uit
   Web Based Authentication...................... Disabled
   Web Authentication Timeout.................... 300
   Web-Passthrough............................... Disabled
   Mac-auth-server............................... 0.0.0.0
   Web-portal-server............................. 0.0.0.0
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
   FlexConnect Central Association............... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Optional
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
--More-- or (q)uit
   Eap-params.................................... Enabled
      EAP-Identity-Request Timeout (seconds)..... 45
      EAP-Identity-Request Max Retries........... 4
      EAP-Request Timeout (seconds).............. 45
      EAP-Request Max Retries.................... 4
      EAPOL-Key Timeout (milliseconds)........... 2000
      EAPOL-Key Max Retries...................... 3
AVC Visibilty.................................... Enabled
AVC Profile Name................................. SkillSecure
Flex Avc Profile Name............................ None
Flow Monitor Name................................ None
Split Tunnel Configuration
    Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Enabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Enabled
802.11v BSS Max Idle Service..................... Enabled
--More-- or (q)uit
802.11v BSS Transition Service................... Disabled
802.11v BSS Transition Disassoc Imminent......... Disabled
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
Number of active DMS Clients..................... 4
DMS ID           Client MAC Addresses
1               1c:5c:f2:87:ed:d7
                c4:b3:01:3e:0b:cd
                dc:9b:9c:16:e2:89
                68:fb:7e:28:75:73
Band Select...................................... Enabled
Load Balancing................................... Client-Count Based
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Enabled
Broadcast Tagging................................ Disabled
 Mobility Anchor List
 WLAN ID     IP Address            Status                             Priority
802.11u........................................ Disabled
--More-- or (q)uit
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
Lync State ...................................... Disabled
Audio QoS Policy................................. Silver
Video QoS Policy................................. Silver
App-Share QoS Policy............................. Silver
File Transfer QoS Policy......................... Silver
QoS Fastlane Status.............................. Disable
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.102.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... NAS-WIRE-WAC1
System Location.................................. Nashua 300 Computer Room
System Contact................................... Global Network Team
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. SSO
IP Address....................................... 10.20.203.11
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 6 days 11 hrs 31 mins 29 secs
System Timezone Location......................... (GMT -5:00) Eastern Time (US and Canada)
System Stats Realtime Interval................... 5
--More-- or (q)uit
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries : CA,DE,FR,GB,IE,IN,US
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +42 C
External Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 666
OUI Classification Failure Count................. 47605
Burned-in MAC Address............................ F8:66:F2:FA:3B:00
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 500
System Nas-Id.................................... NAS-WIRE-WAC1
WLC MIC Certificate Types........................ SHA1
--More-- or (q)uit
(Cisco Controller) >?
clear          Clear selected configuration elements.
config         Configure switch options and settings.
cping          Send capwap echo packets to a specified mobility peer IP address.
debug          Manages system debug options.
eping          Send Ethernet-over-IP echo packets to a specified mobility peer IP address.
grep           Print lines matching a pattern.
help           Help
license        Manage Software License
linktest       Perform a link test to a specified MAC address.
logout         Exit this session. Any unsaved changes are lost.
mping          Send Mobility echo packets to a specified mobility peer IP address.
ping           Send ICMP echo packets to a specified IP address.
redundancy     Manage HA Redundancy
reset          Reboot (hard reload) options.
rping          Send Redundancy ping packets to peer RP and RMI
save           Save switch configurations.
show           Display switch options and settings.
test           Test trigger commands
transfer       Transfer a file to or from the switch.
help           Help
help           Help
help           Help
help           Help
help           Help
VIP Mentor
Based on the provided output
Based on the provided output here is my input.
WLAN configuration is ok to support 802.11n rates (Encryption & WMM perspective). I have noticed you have enabled CCKM, do you have cisco phones in this WLAN ?
Auth Key Management
Regarding WLC config, I noticed it is configured for multiple country codes that belong to different regulatory domain. This will restrict AP power level & channels to a lowest common value in these regulatory domain. This is not recommended and you may experience unwanted results.
Also noticed you are running latest 8.3.x code which is less than 6 months old. Always be aware of known issues in such a latest code. Below link may useful to find any known issues
https://supportforums.cisco.com/discussion/13136886/83mr1-beta-availability
Once you provide client detail, we can assess the situation much better.
Rasika
Content for Community-Ad
August's Community Spotlight Awards
