RESTORE IOS AP1131G
kalderini
I HAVE AN AIR-AP1131AG-A-K9, when turned on THIS ERROR APPEARS IN THE CONSOLE:
I've Been interrupted system, or an error Encountered
DURING initializion of the flash filesystem. The Following
commands will initialize the flash filesystem, and finish
loading the operating system software:
     flash_init
     ether_init
     tftp_init
     boot
ap: flash_init
Initializing Flash ...
flashfs [0]: out of memory
Initializing Flash ... done.
ap: ether_init
Initializing ethernet port 0 ...
Reset ethernet port 0 ...
Reset done!
ap: set IP_ADDR 10.0.0.1
Can not set variable - out of memory.
ap: tftp_init
Unable to get our ip address: no "IP_ADDR" variable in September
Try putting the ip but get the error Can not set variable - out of memory.
  any suggestions to reload the IOS?
whe i try it..
the console apper
ap: tftp_init
Click on the link I've posted.  It will take you directly to the instructions that requires little work and no hassles.
