01-14-2011 01:09 AM - edited 07-03-2021 07:40 PM
We have a problem regarding RF Grouping between two WLC 5508.
The two controllers have the same RF Group name,RF Grouping is enabled,they belong to the same mobility group,their management IP
address is on the same subnet, they ping each other but they don't elect a Group Leader. Each one
elects itself as the Group Leader.
We have tried to place 2 APs,each belonging to different controller, close one to the other but nothing changed.
Any help would be much appreciated.
01-14-2011 02:16 AM
Please post the 2 "show run-config" of the WLCs and let us know which APs are close to each other.
Nicolas
01-14-2011 03:23 AM
Hi Nicolas,
Because we have an almost live network, we wouldn't like to go public with our configurations. Is there any other way we can send them to you?
Thanks in advance,
Theofilos
01-14-2011 05:17 AM
That is called opening a TAC case. That's why the service is there ;-)
Nicolas
01-16-2011 01:31 AM
Thanks for your response.
Best Regards,
Theofilos
09-15-2011 12:41 PM
Theofilos,
Did you figure out what the issue was regarding rf grouping?
thx
Craig
09-15-2011 01:29 PM
I had a similar problem once before. After I rebooted the WLCs all was well. Have you tried that by chnace?
