07-09-2019 09:12 AM - edited 07-05-2021 10:40 AM
I would like to know if I can see CCX packets sent from RFID tag can be observed on WLC 3504 by using WAP371.
To check the tag I wanted to check the connection from the WLC to the WAP, so I connected WAP371 to the port 1 of WLC 3504 and used show ap cdp neighbors all to view the connected APs. I couldnt see the WAP371 connected to port1 in the output of the command.
Is there any configuration change to see WAP371 in the WLC 3504?
Is it possible to see CCX updates with this setup?
Thank you,
Kishore.
07-10-2019 05:45 PM
HI,
Does anyone have an update on this?
Thank you,
Kishore.
07-11-2019 05:29 AM
07-12-2019 09:47 AM - edited 07-12-2019 09:58 AM
Hi Patoberli,
I connected CIsco Aironet AIR-AP1242G-A-K9 to the WLC 3504 controller. I can see that the controller is detected from the AP in Service -> CDP section (attached screenshot of the same). When I do a CDP in WLC with show ap cdp neighbors all or show ap cdp all the access point is not listed in the output.
Is there any extra steps I need to see the AP in the WLC?
Thank you,
Kishore.
07-14-2019 10:36 PM
