07-25-2013 02:55 PM - edited 07-04-2021 12:31 AM
Any and all help is appreciated..
So I am seeing an issue where guest clients on an open L3 passthrough anchored wlan are having to reauth upon every roam. (intractroller) I scoured documentation today and found verbage of several variations of this situation, just not this exactly. I do not have mac filter failure enabled and the below logs are from Prime via the foreign.
2013-Jul-25, 10:16:21 EST | INFO | 172.27.26.9 | Controller association request message received. |
2013-Jul-25, 10:16:21 EST | INFO | 172.27.26.9 | Mobility role update request. from Export Foreign to Local Peer = 172.21.21.8, Old Anchor = 172.21.21.8, New Anchor = 172.27.26.9 |
2013-Jul-25, 10:16:21 EST | INFO | 172.27.26.9 | Received reassociation request from client. |
2013-Jul-25, 10:16:21 EST | INFO | 172.27.26.9 | Client moved to associated state successfully. |
2013-Jul-25, 10:16:21 EST | INFO | 172.27.26.9 | Mobility role update request. from Export Foreign to Export Foreign Peer = 172.21.21.8, Old Anchor = 172.21.21.8, New Anchor = 172.21.21.8 |
2013-Jul-25, 10:16:21 EST | INFO | 172.27.26.9 | Mobility role changed. State Update from Mobility-Incomplete to Mobility-Complete, mobility role=ExpForeign, client state=APF_MS_STATE_ASSOCIATED |
2013-Jul-25, 10:17:24 EST | INFO | 172.27.26.9 | Controller association request message received. |
2013-Jul-25, 10:17:24 EST | INFO | 172.27.26.9 | Mobility role update request. from Export Foreign to Local Peer = 172.21.21.8, Old Anchor = 172.21.21.8, New Anchor = 172.27.26.9 |
2013-Jul-25, 10:17:24 EST | INFO | 172.27.26.9 | Received reassociation request from client. |
2013-Jul-25, 10:17:24 EST | INFO | 172.27.26.9 | Client moved to associated state successfully. |
2013-Jul-25, 10:17:24 EST | INFO | 172.27.26.9 | Mobility role update request. from Export Foreign to Export Foreign Peer = 172.21.21.8, Old Anchor = 172.21.21.8, New Anchor = 172.21.21.8 |
2013-Jul-25, 10:17:24 EST | INFO | 172.27.26.9 | Mobility role changed. State Update from Mobility-Incomplete to Mobility-Complete, mobility role=ExpForeign, client state=APF_MS_STATE_ASSOCIATED |
07-25-2013 03:00 PM
You have multiple anchors?
07-25-2013 03:03 PM
We did, but currently only anchored off the wlan to one of them. The other anchor that used to also be used is still probably a mobility member from another group in an up/up state, but not referenced here.
07-25-2013 03:04 PM
I see .8 and .9 for the roaming.
07-25-2013 03:06 PM
The .9 is actually the ip of the foreign that my APs home to, the other anchor is a .10.
07-25-2013 03:09 PM
Post your show WLAN
07-26-2013 05:24 AM
07-26-2013 07:08 AM
I need to see both controllers... you just have one.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
07-26-2013 07:13 AM
07-26-2013 06:04 PM
That is fine that your WiSM is running v7.4 and the 4400 is running v7.0.... thats not an issue.
I would change the session timout on the WiSM2 to Infinity and make sure the idle timer on the anchor is set to 14400.
See if that helps.
Scott
09-04-2014 05:02 PM
Did you solve this issue? I am having a very similar issue.
