08-02-2012 12:49 AM - edited 07-03-2021 10:29 PM
a client has a roaming issue with summit clients
SDC-PE15N. He has installed the latest driver, now.
He has installed IOS-based AP1231 and IOS-based AP1260.
When a client roams from AP1231 to AP1260 and the N-standard is active then he has a roaming issue. He looses the connection for a few seconds.
If 802.11n is deactivated and 1MBps is configured as mandatory then roaming works fine.
Does everyone has an idea?
thanks
Martin
08-02-2012 01:42 AM
That sounds more like the device needs 1mb as mandatory vs an 'N' issue per se.
N will work with 1M as mandatory.
Leave all the N config in place and set 1M a mandatory and let us know if roaming works as it should.
Steve
08-02-2012 02:28 AM
I will try and let you know
best regards
martin
