01-06-2011 08:19 AM - edited 07-03-2021 07:38 PM
hi, all, happy new year! got a question here.
I have a testbed with one WDS AP and two infrastructure APs, both infrastructure ones are registered with WDS AP via wlccp correctly, I can also associate wireless client using LEAP+CCKM on either of them, if the radio is shutdown on one of them, the client will roam from one to another, vice versa.
the issue is that, no fast roaming happened at all when clients roam, they always perform a full 4way handshak for some reason. I tried to find out if the keys have been cached, but it seems that there is no commands to do that in the IOS image, do any of you know there are something such as "show pmk-cache all" in IOS image? or any other method to check this out?
01-06-2011 09:25 PM
Hi ,
The Master key cached by the WDS when using CCKM will be retained for the duration of the user session which is specified by the RADIUS server. If no
session timeout is specified, the key is retained indefinitely.
Note that client & WDS must maintain state for this to happen however, so if the client device is reset, a new key must be negotiated.
I am not sure if there is a command which can show the cahced key .
Since the questiosn remainded unasnswered for a while ,trying my luck
Regards ,
Sharath K.P.
01-06-2011 10:27 PM
Stupid one but I always forget about it too. Did you register your WDS with itself ? Otherwise you can't roam to the WDS in a quick manner.
Nicolas
01-07-2011 06:40 AM
Sorry, I believe your statement is 100 percent right but it doesn't seem related to my question, still appreciate your reply though.
01-07-2011 06:44 AM
I believe it is.
Let's say you have 2 APs and your WDS. If you client is roaming from AP1 to WDS AP, then the roaming will not be fast if the WDS is not registered to itself. That was my point.
Moreover, how do you know it's doing the 4 way handshake ? If you're doing an EAP authentication you should actually even do more than that if fast roaming is not happening.
01-07-2011 07:10 AM
Hey Nicolas,
I believe you have setup something like this before, did you actually try to verify if the Fast Roaming was happening? If so, can you share how?
01-07-2011 11:47 PM
Yes indeed.
The easiest way to know if you did fast roaming or not when you are doing leap or whatever else as eap authentication is to check if the radius server was contacted for each roaming. If it was not, then you did fast roaming. As simple as that.
How did you verify on your side ?
Nicolas
01-10-2011 07:20 AM
