Routing issues when AP connected to the LAN
andrewmccabe1
Bit of an odd one here...
Configured an autonomous 1602 Access Point and connected to the LAN. Once connected it prevents users from outside the LAN connecting in. When the AP is set to DHCP, experience no issues at all. The config of the AP is below and as a workaround have added an ip route. Any ideas?
hostname XXXXX
logging rate-limit console 9
enable secret 5 $1$y7Fp$l3MW/v/u4slB82Wxlo/EZ/
no aaa new-model
ip cef
dot11 syslog
dot11 ssid xxxxx
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 106A5917550336484D573E78
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
ssid xxxxxx
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
ip address dhcp
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.x.x.x 255.255.0.0
ip default-gateway 10.x.x.x
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community xxx RO
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
Hi Andrew,
Are you still having this issue ?
Post the "show run interface x/x" where x/x  is the switch port AP connected to. As per your config it should be an access port on the vlan where your configure BVI interface.
Rasika
**** Pls rate all useful resposnes ****
