Sending station has left the BSS or Sending station has lef channel dfs
Demandonio
Hi all,
I'm having a problem configuring a Cisco Air-SAP1602I-E-K9. I configured everything, I guess, but every time I try to authenticate it it says: Sending station has left the BSS.
How can I solve this issue?
This is the configuration I did:
AP#sh run
Building configuration...
Current configuration : 2869 bytes
! Last configuration change at 21:41:59 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname AP
logging rate-limit console 9
enable secret 5 $1$WyKF$wUlRyeJ1q85u.N2HQb3aK/
no aaa new-model
clock timezone UTC 1 0
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip routing
no ip cef
ip domain name client.local
dot11 syslog
dot11 vlan-name Test vlan 600
dot11 ssid XPRESS
vlan 600
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 7 1344301E183323382E232934321D4157445340
username admin password 7 062F012743712E0B0010130C0B
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 600 mode ciphers aes-ccm tkip
encryption mode wep mandatory
ssid XPRESS
antenna gain 0
stbc
beamform ofdm
mbssid
station-role root access-point
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.600
encapsulation dot1Q 600
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid XPRESS
antenna gain 0
no dfs band block
stbc
beamform ofdm
mbssid
channel dfs
bridge-group 1
interface Dot11Radio1.600
no ip route-cache
bridge-group 2
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
bridge-group 1 spanning-disabled
interface GigabitEthernet0.600
no ip route-cache
bridge-group 2
interface BVI1
ip address 192.168.250.24 255.255.255.224
no ip route-cache
ip default-gateway 192.168.250.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input ssh
end
Do you have a solution for this issue?
Thank you!
7 Replies 7
 Have you tried more then one device?  the message states that the sender has left the BSS and this can be a client problem and not an AP problem.
 You also need to provide more info like are you trying to access the network closer enough?  Can you run a client debug and share the output?
-If I helped you somehow, please, rate it as useful.-
Hi Flavio,
I tried 4 devices, with the same result.
The access point is in laboratory with me, I'm testing it before starting to use it. There are no interferences :/
I don't know how to run a client debug. Can you explain me?
Thank you
Console into AP and run "debug dot11 ? "
This must show you debugs option.  Try as much as possible.
Ok, thanks. I found this:
*Mar 2 01:02:33.819: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 3ccd.5d3a.f837 Associated KEY_MGMT[WPAv2 PSK]
*Mar 2 01:03:09.862: dot11_auth_client_abort: Received abort request for client 3ccd.5d3a.f837
*Mar 2 01:03:09.862: dot11_auth_client_abort: No client entry to abort: 3ccd.5d3a.f837 for application 0x1
*Mar 2 01:03:09.862: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3ccd.5d3a.f837 Reason: Sending station has left the BSS
There are two logs that may help. Maybe you alredy faced this before.
Thank you
Looks like the problem is authentication
dot11 ssid XPRESS
vlan 600
authentication open
mbssid guest-mode
Try to remove the "mbssid guest-mode" line
when I removed the mbssid guest-mode command it stopped broadcasting SSID. Then I activated just the guest-ssid command., removing the mbssid also into the dot11 interface. Now it forwards again but the result is the same..
Jay Vivas
The client is trying to auth with WPAv2 but you are only using WPAv1 on the SSID. I would do two things here:
1. Remove the "encryption mode wep mandatory" from the radio.
2. On the SSID change "authentication key-management wpa" to "authentication key-management wpa version 2"
