Community Helping Community
604
Set up a AIR-CAP2702E-E-K9
Can anyone tell me if it is possible to setup a AIR-CAP2702E-E-K9 without a wireless LAN controller?  I have been offered a cheap second hand one and was thinking about using it at home.
6 REPLIES 6
Contributor
Re: Set up a AIR-CAP2702E-E-K9
Yes, its possible, you have to make sure the AP is in autonomous mode, if not you have to change to autonomous and then configure it for your home wireless. just youtube on how to convert to autonomous mode and configure, you will find it easily.
-Rate helpful posts-
VIP Advocate
Please note that you require a special image/operatingsystem if it's not yet in autonomous mode. That image requires a Cisco account and a Smartnet contract.
Beginner
In fact 1700 and 2700 by default come pre-loaded with autonomous IOS and can be switched from the console using:
capwap ap autonomous
… then reload.
Once you've converted it you might want to update to a more recent version of IOS:
https://software.cisco.com/download/home/286256842/type/284180979/release/15.3.3-JJ1
RR
VIP Advocate
I think the 2700 only came with an autonomous IOS if it was ordered that way, but I'm not 100% sure. The 1700 models though, they came with both images.
Beginner
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap1-overview.html
"Note When booting up a 1530, 1700, or a 2700 series AP for the first time, it will boot up with a unified mode software image. To deploy the AP in an autonomous network, use following command from the AP console or telnet to force AP to reboot using autonomous mode software image.
For more information on software images on the AP, see Working with Software Images."
Highlighted
VIP Advocate
Thanks for digging that up, I found the information only for the 1700 :)
Content for Community-Ad
August's Community Spotlight Awards
