07-19-2011 02:47 AM - edited 07-03-2021 08:27 PM
Hey,
I have a question about sitesurveying with ap3500's
I'm going to deploy a wireless network in a new building, i have a company that normaly does my site surveys.
I normally provide them with some AP's configured with a designated ssid and local power modes set to 50%, however this does not seem possible with the new 3500i's i'm willing to use, for there is no IOS image available for it.
I dont have any network connectivity yet in this new building, so i cannot f.i place them in a separate ap-group and assign a dedicated wlan to them.
Can Anybody think of a viable solution (ASAP) Thanx in advance
Frans verschoor
Solved! Go to Solution.
07-19-2011 09:58 AM
Some people managed to obtain an IOS image for it.
I think the 1260 IOS image works for the 3500 as well (although not supported for everyday use, it's perfect for a site survey). Try the 1140 image otherwise.
07-19-2011 09:58 AM
07-19-2011 07:15 PM
We use 1140s for site surveys in our 3502i deployments.
07-19-2011 07:27 PM
Not recommended.
07-20-2011 06:03 AM
Recommended practice is to always do a site survey with the AP that you are going to deploy, but in this scenario that is not possible. Why do you not recommend using a 1140 for a 3500 deployment? There is no difference between the two APs except for the extra chip pset in a 3502 for Clean Air. They have the same signal propagation and power. Please educate me.
07-20-2011 08:14 AM
leolaohoo wrote:
We use 1140s for site surveys in our 3502i deployments.Not recommended.
I have the same questions as Thomas. In the thread below I tried to find out any differences between these APs but the consensus was that ClearAir was the only notable difference. The only way the 1140 would be not recommended for a passive survey is if there is differences in the antenna pattern, and active survey if there's a difference in chipset or hardware. So what are the differences?
07-20-2011 10:15 AM
There is no difference.
The 1260 is really a 3500e without cleanair chipset.
The 1140 is like a 3500i without cleanair chipset but I think the 1140 has a slightly different radio chipset too but nothing that will create a difference that you will perceive.
07-20-2011 02:39 AM
Thanx a bunch,
I have yet to try the 1260 image, but have provided some 1140's for now.
site survey is friday so i might be able to get them some 1260 imaged 3500s.
