Software Version Upgrade for Cisco 4402 Wireless Lan Controller
PRASAD BAIT
We have Cisco 4402 Wireless Lan Controller with Software Version 3.2.171.6 and we want to upgrade it to latest version.
So can anyone please let me know the latest version to upgrade the WLC?
Also since WLC is running on very lower version is it possible to upgrade to the latest version directly or we have to move it step by step to upgrade this to latest version?
blakekrone
Level 4
Level 4
Take a look at the compatibility matrix below:
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
7.0.235 is the latest that you can go to:
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_235_0.html
The release notes outline the upgrade process.
"Upgrade to 4.0.206.0 or later 4.0 release, then upgrade to 4.2.176.0, before upgrading to 7.0.235.0."
blakekrone
Level 4
Level 4
Thanks a lot....
Don't forget to upgrade the bootstrap, "-ER" files", as well.
