03-30-2016 02:36 AM - edited 07-05-2021 04:50 AM
A customer of us tried to enforce a split ACL on an access point (2702I) running in flexconnect mode / office extend enabled.
Cisco WLC is of type 5508 with software 8.0.100.0 running.
I searched the configuration guide but from my understanding this feature is not supported on a 2702 AP running in office extend mode.
The configuration was applied according to following guide:
http://mrncciew.com/2013/09/09/split-tunneling-with-flexconnect/
The ACL itself is pushed to the access point, but the NAT entries are missing.
Is there any known restriction or option that must be enabled to achieve split tunneling on a 2702I access point running in flexconnect / office extend mode?
Solved! Go to Solution.
06-27-2016 05:02 AM
Hi Christian
It is possible, but not if your WLC uses a static anchor to tunnel traffic to the inside WLC.
I filed a SR for this and we worked with TAC on it for weeks before they realized that this in an undocumented limitation.
We have created a feature request for this but there are no schedule for implementing it.
Regards Rasmus
06-27-2016 05:02 AM
Hi Christian
Regards Rasmus
