Highlighted
Beginner
Strange problem client authentication on the AP
I have a WLC 2504 with six AIR-LAP1042N APs. Authenticate scheme is WPA2 with PSK. All APs in same mobility group.
I have problem, one client cann’t authenticate with one AP.  The following occurs: client poweron, associated with nearest AP1, attempts to auth with it, but can’t. It try to connect to other AP2 (not nearest), associated and well authenticated on it. Some seconds later, client found AP1 (nearest) and try to reassociated with it (roaming), but again can’t auth. Then client connect again to AP2, and all repeat infinitely. Outwardly it looks, that wi-fi connecting constantly disappeared and again appeared on client.
When auth failed, AP1 sends to client three EAPOL messages with an interval of one second, but don't receive any answer from client (timer expired).
There is client debug.
5c:0a:5b:47:66:c3 192.168.110.252 - client
0c:d9:96:9d:1b:20 - AP1
0c:d9:96:9d:55:10 - AP2
*pemReceiveTask: Dec 12 17:51:19.430: 5c:0a:5b:47:66:c3 192.168.110.252 Added NPU entry of type 1, dtlFlags 0x0
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 Reassociation received from mobile on AP 0c:d9:96:9d:1b:20
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Changing ACL 'printer' (ACL ID 0) ===> 'printer' (ACL ID 0) --- (caller apf_policy.c:1698)
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 Applying site-specific IPv6 override for station 5c:0a:5b:47:66:c3 - vapId 2, site 'default-group', interface 'dynamic1'
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 Applying IPv6 Interface Policy for station 5c:0a:5b:47:66:c3 - vlan 10, interface id 11, interface 'dynamic1'
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 STA - rates (6): 152 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 Processing RSN IE type 48, length 20 for mobile 5c:0a:5b:47:66:c3
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Deleted mobile LWAPP rule on AP [0c:d9:96:9d:55:10]
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 Updated location for station old AP 0c:d9:96:9d:55:10-0, new AP 0c:d9:96:9d:1b:20-0
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 apfMsRunStateDec
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 apfMs1xStateDec
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 192.168.110.252 START (0) Initializing policy
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 192.168.110.252 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 192.168.110.252 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) DHCP required on AP 0c:d9:96:9d:1b:20 vapId 2 apVapId 2for this client
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 0c:d9:96:9d:1b:20 vapId 2 apVapId 2
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 apfPemAddUser2 (apf_policy.c:223) Changing state for mobile 5c:0a:5b:47:66:c3 on AP 0c:d9:96:9d:1b:20 from Associated to Associated
*apfMsConnTask_5: Dec 12 17:52:04.149: 5c:0a:5b:47:66:c3 Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_5: Dec 12 17:52:04.150: 5c:0a:5b:47:66:c3 Sending Assoc Response to station on BSSID 0c:d9:96:9d:1b:20 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_5: Dec 12 17:52:04.150: 5c:0a:5b:47:66:c3 apfProcessAssocReq (apf_80211.c:5237) Changing state for mobile 5c:0a:5b:47:66:c3 on AP 0c:d9:96:9d:1b:20 from Associated to Associated
*pemReceiveTask: Dec 12 17:52:04.151: 5c:0a:5b:47:66:c3 192.168.110.252 Removed NPU entry.
*dot1xMsgTask: Dec 12 17:52:04.153: 5c:0a:5b:47:66:c3 Creating a PKC PMKID Cache entry for station 5c:0a:5b:47:66:c3 (RSN 2)
*dot1xMsgTask: Dec 12 17:52:04.153: 5c:0a:5b:47:66:c3 Adding BSSID 0c:d9:96:9d:1b:21 to PMKID cache for station 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:04.153: New PMKID: (16)
*dot1xMsgTask: Dec 12 17:52:04.153:      [0000] 1a 44 36 b7 64 f6 8d 8a b1 16 69 2a 75 fe bd d8
*dot1xMsgTask: Dec 12 17:52:04.153: 5c:0a:5b:47:66:c3 Initiating RSN PSK to mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:04.153: 5c:0a:5b:47:66:c3 dot1x - moving mobile 5c:0a:5b:47:66:c3 into Force Auth state
*dot1xMsgTask: Dec 12 17:52:04.153: 5c:0a:5b:47:66:c3 Skipping EAP-Success to mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:04.153: Including PMKID in M1  (16)
*dot1xMsgTask: Dec 12 17:52:04.153: 5c:0a:5b:47:66:c3 Starting key exchange to mobile 5c:0a:5b:47:66:c3, data packets will be dropped
*dot1xMsgTask: Dec 12 17:52:04.153: 5c:0a:5b:47:66:c3 Sending EAPOL-Key Message to mobile 5c:0a:5b:47:66:c3
state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*dot1xMsgTask: Dec 12 17:52:04.153: 5c:0a:5b:47:66:c3 Sending 802.11 EAPOL message  to mobile 5c:0a:5b:47:66:c3 WLAN 2, AP WLAN 2
*dot1xMsgTask: Dec 12 17:52:04.154: 00000000: 02 03 00 75 02 00 8a 00  10 00 00 00 00 00 00 00  ...u............
*dot1xMsgTask: Dec 12 17:52:04.154: 00000010: 00 36 24 73 10 bb 2b 7e  84 3d e0 62 4a 7f 0a f5  .6$s..+~.=.bJ...
*dot1xMsgTask: Dec 12 17:52:04.154: 00000020: 3a bb 17 c7 2f 3c b1 0c  c0 94 70 fb 0e c0 28 b3  :.../<....p...(.
*dot1xMsgTask: Dec 12 17:52:04.154: 00000030: b0 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:04.154: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:04.154: 00000050: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:04.154: 00000060: 00 00 16 dd 14 00 0f ac  04 1a 44 36 b7 64 f6 8d  ..........D6.d..
*dot1xMsgTask: Dec 12 17:52:04.154: 00000070: 8a b1 16 69 2a 75 fe bd  d8                       ...i*u...
*osapiBsnTimer: Dec 12 17:52:05.156: 5c:0a:5b:47:66:c3 802.1x 'timeoutEvt' Timer expired for station 5c:0a:5b:47:66:c3 and for message = M2
*dot1xMsgTask: Dec 12 17:52:05.157: 5c:0a:5b:47:66:c3 Retransmit 1 of EAPOL-Key M1 (length 121) for mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:05.157: 5c:0a:5b:47:66:c3 Sending 802.11 EAPOL message  to mobile 5c:0a:5b:47:66:c3 WLAN 2, AP WLAN 2
*dot1xMsgTask: Dec 12 17:52:05.157: 00000000: 02 03 00 75 02 00 8a 00  10 00 00 00 00 00 00 00  ...u............
*dot1xMsgTask: Dec 12 17:52:05.157: 00000010: 01 36 24 73 10 bb 2b 7e  84 3d e0 62 4a 7f 0a f5  .6$s..+~.=.bJ...
*dot1xMsgTask: Dec 12 17:52:05.157: 00000020: 3a bb 17 c7 2f 3c b1 0c  c0 94 70 fb 0e c0 28 b3  :.../<....p...(.
*dot1xMsgTask: Dec 12 17:52:05.157: 00000030: b0 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:05.157: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:05.157: 00000050: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:05.157: 00000060: 00 00 16 dd 14 00 0f ac  04 1a 44 36 b7 64 f6 8d  ..........D6.d..
*dot1xMsgTask: Dec 12 17:52:05.157: 00000070: 8a b1 16 69 2a 75 fe bd  d8                       ...i*u...
*osapiBsnTimer: Dec 12 17:52:06.156: 5c:0a:5b:47:66:c3 802.1x 'timeoutEvt' Timer expired for station 5c:0a:5b:47:66:c3 and for message = M2
*dot1xMsgTask: Dec 12 17:52:06.157: 5c:0a:5b:47:66:c3 Retransmit 2 of EAPOL-Key M1 (length 121) for mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:06.157: 5c:0a:5b:47:66:c3 Sending 802.11 EAPOL message  to mobile 5c:0a:5b:47:66:c3 WLAN 2, AP WLAN 2
*dot1xMsgTask: Dec 12 17:52:06.157: 00000000: 02 03 00 75 02 00 8a 00  10 00 00 00 00 00 00 00  ...u............
*dot1xMsgTask: Dec 12 17:52:06.157: 00000010: 02 36 24 73 10 bb 2b 7e  84 3d e0 62 4a 7f 0a f5  .6$s..+~.=.bJ...
*dot1xMsgTask: Dec 12 17:52:06.157: 00000020: 3a bb 17 c7 2f 3c b1 0c  c0 94 70 fb 0e c0 28 b3  :.../<....p...(.
*dot1xMsgTask: Dec 12 17:52:06.157: 00000030: b0 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:06.157: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:06.157: 00000050: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:06.157: 00000060: 00 00 16 dd 14 00 0f ac  04 1a 44 36 b7 64 f6 8d  ..........D6.d..
*dot1xMsgTask: Dec 12 17:52:06.157: 00000070: 8a b1 16 69 2a 75 fe bd  d8                       ...i*u...
*osapiBsnTimer: Dec 12 17:52:07.156: 5c:0a:5b:47:66:c3 802.1x 'timeoutEvt' Timer expired for station 5c:0a:5b:47:66:c3 and for message = M2
*dot1xMsgTask: Dec 12 17:52:07.157: 5c:0a:5b:47:66:c3 Retransmit failure for EAPOL-Key M1 to mobile 5c:0a:5b:47:66:c3, retransmit count 3, mscb deauth count 0
*dot1xMsgTask: Dec 12 17:52:07.157: 5c:0a:5b:47:66:c3 Sent Deauthenticate to mobile on BSSID 0c:d9:96:9d:1b:20 slot 0(caller 1x_ptsm.c:534)
*dot1xMsgTask: Dec 12 17:52:07.157: 5c:0a:5b:47:66:c3 Scheduling deletion of Mobile Station:  (callerId: 57) in 10 seconds
*apfMsConnTask_3: Dec 12 17:52:15.749: 5c:0a:5b:47:66:c3 Association received from mobile on AP 0c:d9:96:9d:55:10
*apfMsConnTask_3: Dec 12 17:52:15.749: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) Changing ACL 'printer' (ACL ID 0) ===> 'printer' (ACL ID 0) --- (caller apf_policy.c:1698)
*apfMsConnTask_3: Dec 12 17:52:15.749: 5c:0a:5b:47:66:c3 Applying site-specific IPv6 override for station 5c:0a:5b:47:66:c3 - vapId 2, site 'default-group', interface 'dynamic1'
*apfMsConnTask_3: Dec 12 17:52:15.749: 5c:0a:5b:47:66:c3 Applying IPv6 Interface Policy for station 5c:0a:5b:47:66:c3 - vlan 10, interface id 11, interface 'dynamic1'
*apfMsConnTask_3: Dec 12 17:52:15.749: 5c:0a:5b:47:66:c3 STA - rates (6): 152 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 Processing RSN IE type 48, length 20 for mobile 5c:0a:5b:47:66:c3
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) Deleted mobile LWAPP rule on AP [0c:d9:96:9d:1b:20]
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 Updated location for station old AP 0c:d9:96:9d:1b:20-0, new AP 0c:d9:96:9d:55:10-0
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) Initializing policy
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 192.168.110.252 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) DHCP required on AP 0c:d9:96:9d:55:10 vapId 2 apVapId 2for this client
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 0c:d9:96:9d:55:10 vapId 2 apVapId 2
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 apfPemAddUser2 (apf_policy.c:223) Changing state for mobile 5c:0a:5b:47:66:c3 on AP 0c:d9:96:9d:55:10 from Associated to Associated
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 Sending Assoc Response to station on BSSID 0c:d9:96:9d:55:10 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_3: Dec 12 17:52:15.750: 5c:0a:5b:47:66:c3 apfProcessAssocReq (apf_80211.c:5237) Changing state for mobile 5c:0a:5b:47:66:c3 on AP 0c:d9:96:9d:55:10 from Associated to Associated
*dot1xMsgTask: Dec 12 17:52:15.753: 5c:0a:5b:47:66:c3 Creating a PKC PMKID Cache entry for station 5c:0a:5b:47:66:c3 (RSN 2)
*dot1xMsgTask: Dec 12 17:52:15.753: 5c:0a:5b:47:66:c3 Adding BSSID 0c:d9:96:9d:55:11 to PMKID cache for station 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:15.753: New PMKID: (16)
*dot1xMsgTask: Dec 12 17:52:15.753:      [0000] 18 16 8e 32 db 77 3f ed 76 87 9a d6 0b 80 5e 12
*dot1xMsgTask: Dec 12 17:52:15.753: 5c:0a:5b:47:66:c3 Initiating RSN PSK to mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:15.753: 5c:0a:5b:47:66:c3 dot1x - moving mobile 5c:0a:5b:47:66:c3 into Force Auth state
*dot1xMsgTask: Dec 12 17:52:15.753: 5c:0a:5b:47:66:c3 Skipping EAP-Success to mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:15.753: Including PMKID in M1  (16)
*dot1xMsgTask: Dec 12 17:52:15.753: 5c:0a:5b:47:66:c3 Starting key exchange to mobile 5c:0a:5b:47:66:c3, data packets will be dropped
*dot1xMsgTask: Dec 12 17:52:15.753: 5c:0a:5b:47:66:c3 Sending EAPOL-Key Message to mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:15.753: 5c:0a:5b:47:66:c3 Sending 802.11 EAPOL message  to mobile 5c:0a:5b:47:66:c3 WLAN 2, AP WLAN 2
*dot1xMsgTask: Dec 12 17:52:15.754: 00000000: 02 03 00 75 02 00 8a 00  10 00 00 00 00 00 00 00  ...u............
*dot1xMsgTask: Dec 12 17:52:15.754: 00000010: 00 36 24 73 10 bb 2b 7e  84 3d e0 62 4a 7f 0a f5  .6$s..+~.=.bJ...
*dot1xMsgTask: Dec 12 17:52:15.754: 00000020: 3a bb 17 c7 2f 3c b1 0c  c0 94 70 fb 0e c0 28 b3  :.../<....p...(.
*dot1xMsgTask: Dec 12 17:52:15.754: 00000030: b4 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:15.754: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:15.754: 00000050: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:15.754: 00000060: 00 00 16 dd 14 00 0f ac  04 18 16 8e 32 db 77 3f  ............2.w?
*dot1xMsgTask: Dec 12 17:52:15.754: 00000070: ed 76 87 9a d6 0b 80 5e  12                       .v.....^.
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 5c:0a:5b:47:66:c3 Received 802.11 EAPOL message (len 121) from mobile 5c:0a:5b:47:66:c3
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 00000000: 01 03 00 75 02 01 0a 00  00 00 00 00 00 00 00 00  ...u............
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 00000010: 00 5e 0c a9 8f ae 78 d7  bc 21 96 bd dd 59 23 bd  .^....x..!...Y#.
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 00000020: 03 eb d0 a3 c2 c5 54 ed  aa 60 9b 4a 38 b0 07 11  ......T..`.J8...
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 00000030: 0f 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 00000050: 00 f8 7e a2 cd 8d 9f 05  f4 b7 29 52 f5 d5 04 35  ..~.......)R...5
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 00000060: 69 00 16 30 14 01 00 00  0f ac 04 01 00 00 0f ac  i..0............
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 00000070: 04 01 00 00 0f ac 02 00  00                       .........
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 5c:0a:5b:47:66:c3 Received EAPOL-Key from mobile 5c:0a:5b:47:66:c3
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 5c:0a:5b:47:66:c3 Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile 5c:0a:5b:47:66:c3
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.790: 5c:0a:5b:47:66:c3 Received EAPOL-key in PTK_START state (message 2) from mobile 5c:0a:5b:47:66:c3
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 5c:0a:5b:47:66:c3 Stopping retransmission timer for mobile 5c:0a:5b:47:66:c3
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 5c:0a:5b:47:66:c3 Sending EAPOL-Key Message to mobile 5c:0a:5b:47:66:c3
state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 5c:0a:5b:47:66:c3 Sending 802.11 EAPOL message  to mobile 5c:0a:5b:47:66:c3 WLAN 2, AP WLAN 2
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000000: 02 03 00 97 02 13 ca 00  10 00 00 00 00 00 00 00  ................
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000010: 01 36 24 73 10 bb 2b 7e  84 3d e0 62 4a 7f 0a f5  .6$s..+~.=.bJ...
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000020: 3a bb 17 c7 2f 3c b1 0c  c0 94 70 fb 0e c0 28 b3  :.../<....p...(.
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000030: b4 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000050: 00 73 a8 2b 31 96 d7 b7  64 26 61 50 95 42 68 52  .s.+1...d&aP.BhR
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000060: 28 00 38 23 d2 26 34 ae  9b 9f 84 40 60 70 31 35  (.8#.&4....@`p15
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000070: 3b a5 d8 f3 76 9c d0 b0  91 d2 72 5e d2 8f 92 89  ;...v.....r^....
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000080: f3 6f aa 90 d4 d0 02 1b  ea 54 fa b3 a0 1b 76 31  .o.......T....v1
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.791: 00000090: 09 2a 39 ad ea 75 9e d6  fc aa 90                 .*9..u.....
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 5c:0a:5b:47:66:c3 Received 802.11 EAPOL message (len 99) from mobile 5c:0a:5b:47:66:c3
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 00000000: 01 03 00 5f 02 03 0a 00  00 00 00 00 00 00 00 00  ..._............
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 00000010: 01 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 00000020: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 00000030: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 00000050: 00 07 02 8b a7 65 ce 75  37 9f 2e 7c 58 d6 92 f9  .....e.u7..|X...
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 00000060: 7c 00 00                                          |..
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 5c:0a:5b:47:66:c3 Received EAPOL-Key from mobile 5c:0a:5b:47:66:c3
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 5c:0a:5b:47:66:c3 Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile 5c:0a:5b:47:66:c3
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.794: 5c:0a:5b:47:66:c3 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 5c:0a:5b:47:66:c3
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 apfMs1xStateInc
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 192.168.110.252 L2AUTHCOMPLETE (4) DHCP required on AP 0c:d9:96:9d:55:10 vapId 2 apVapId 2for this client
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 192.168.110.252 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 0c:d9:96:9d:55:10 vapId 2 apVapId 2
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 apfMsRunStateInc
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 192.168.110.252 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Reached PLUMBFASTPATH: from line 4918
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Adding Fast Path rule
type = Airespace AP Client
on AP 0c:d9:96:9d:55:10, slot 0, interface = 1, QOS = 0
ACL Id = 0, Jumbo Frames = NO
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 7006  IPv6 Vlan = 10, IPv6 intf id = 11
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Successfully plumbed mobile rule (ACL ID 0)
*Dot1x_NW_MsgTask_3: Dec 12 17:52:15.795: 5c:0a:5b:47:66:c3 Stopping retransmission timer for mobile 5c:0a:5b:47:66:c3
*pemReceiveTask: Dec 12 17:52:15.796: 5c:0a:5b:47:66:c3 192.168.110.252 Added NPU entry of type 1, dtlFlags 0x0
*apfMsConnTask_5: Dec 12 17:52:39.650: 5c:0a:5b:47:66:c3 Reassociation received from mobile on AP 0c:d9:96:9d:1b:20
*apfMsConnTask_5: Dec 12 17:52:39.650: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Changing ACL 'printer' (ACL ID 0) ===> 'printer' (ACL ID 0) --- (caller apf_policy.c:1698)
*apfMsConnTask_5: Dec 12 17:52:39.650: 5c:0a:5b:47:66:c3 Applying site-specific IPv6 override for station 5c:0a:5b:47:66:c3 - vapId 2, site 'default-group', interface 'dynamic1'
*apfMsConnTask_5: Dec 12 17:52:39.650: 5c:0a:5b:47:66:c3 Applying IPv6 Interface Policy for station 5c:0a:5b:47:66:c3 - vlan 10, interface id 11, interface 'dynamic1'
*apfMsConnTask_5: Dec 12 17:52:39.650: 5c:0a:5b:47:66:c3 STA - rates (6): 152 36 48 72 96 108 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_5: Dec 12 17:52:39.650: 5c:0a:5b:47:66:c3 Processing RSN IE type 48, length 20 for mobile 5c:0a:5b:47:66:c3
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Deleted mobile LWAPP rule on AP [0c:d9:96:9d:55:10]
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 Updated location for station old AP 0c:d9:96:9d:55:10-0, new AP 0c:d9:96:9d:1b:20-0
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 apfMsRunStateDec
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 apfMs1xStateDec
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 192.168.110.252 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 192.168.110.252 START (0) Initializing policy
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 192.168.110.252 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 192.168.110.252 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) DHCP required on AP 0c:d9:96:9d:1b:20 vapId 2 apVapId 2for this client
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 192.168.110.252 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 0c:d9:96:9d:1b:20 vapId 2 apVapId 2
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 apfPemAddUser2 (apf_policy.c:223) Changing state for mobile 5c:0a:5b:47:66:c3 on AP 0c:d9:96:9d:1b:20 from Associated to Associated
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 Sending Assoc Response to station on BSSID 0c:d9:96:9d:1b:20 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_5: Dec 12 17:52:39.651: 5c:0a:5b:47:66:c3 apfProcessAssocReq (apf_80211.c:5237) Changing state for mobile 5c:0a:5b:47:66:c3 on AP 0c:d9:96:9d:1b:20 from Associated to Associated
*pemReceiveTask: Dec 12 17:52:39.652: 5c:0a:5b:47:66:c3 192.168.110.252 Removed NPU entry.
*dot1xMsgTask: Dec 12 17:52:39.655: 5c:0a:5b:47:66:c3 Creating a PKC PMKID Cache entry for station 5c:0a:5b:47:66:c3 (RSN 2)
*dot1xMsgTask: Dec 12 17:52:39.655: 5c:0a:5b:47:66:c3 Adding BSSID 0c:d9:96:9d:1b:21 to PMKID cache for station 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:39.655: New PMKID: (16)
*dot1xMsgTask: Dec 12 17:52:39.655:      [0000] 1a 44 36 b7 64 f6 8d 8a b1 16 69 2a 75 fe bd d8
*dot1xMsgTask: Dec 12 17:52:39.655: 5c:0a:5b:47:66:c3 Initiating RSN PSK to mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:39.655: 5c:0a:5b:47:66:c3 dot1x - moving mobile 5c:0a:5b:47:66:c3 into Force Auth state
*dot1xMsgTask: Dec 12 17:52:39.655: 5c:0a:5b:47:66:c3 Skipping EAP-Success to mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:39.655: Including PMKID in M1  (16)
*dot1xMsgTask: Dec 12 17:52:39.655: 5c:0a:5b:47:66:c3 Starting key exchange to mobile 5c:0a:5b:47:66:c3, data packets will be dropped
*dot1xMsgTask: Dec 12 17:52:39.655: 5c:0a:5b:47:66:c3 Sending EAPOL-Key Message to mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:39.655: 5c:0a:5b:47:66:c3 Sending 802.11 EAPOL message  to mobile 5c:0a:5b:47:66:c3 WLAN 2, AP WLAN 2
*dot1xMsgTask: Dec 12 17:52:39.655: 00000000: 02 03 00 75 02 00 8a 00  10 00 00 00 00 00 00 00  ...u............
*dot1xMsgTask: Dec 12 17:52:39.655: 00000010: 00 36 24 73 10 bb 2b 7e  84 3d e0 62 4a 7f 0a f5  .6$s..+~.=.bJ...
*dot1xMsgTask: Dec 12 17:52:39.655: 00000020: 3a bb 17 c7 2f 3c b1 0c  c0 94 70 fb 0e c0 28 b3  :.../<....p...(.
*dot1xMsgTask: Dec 12 17:52:39.655: 00000030: b6 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:39.655: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:39.655: 00000050: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:39.655: 00000060: 00 00 16 dd 14 00 0f ac  04 1a 44 36 b7 64 f6 8d  ..........D6.d..
*dot1xMsgTask: Dec 12 17:52:39.655: 00000070: 8a b1 16 69 2a 75 fe bd  d8                       ...i*u...
*osapiBsnTimer: Dec 12 17:52:40.756: 5c:0a:5b:47:66:c3 802.1x 'timeoutEvt' Timer expired for station 5c:0a:5b:47:66:c3 and for message = M2
*dot1xMsgTask: Dec 12 17:52:40.757: 5c:0a:5b:47:66:c3 Retransmit 1 of EAPOL-Key M1 (length 121) for mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:40.757: 5c:0a:5b:47:66:c3 Sending 802.11 EAPOL message  to mobile 5c:0a:5b:47:66:c3 WLAN 2, AP WLAN 2
*dot1xMsgTask: Dec 12 17:52:40.757: 00000000: 02 03 00 75 02 00 8a 00  10 00 00 00 00 00 00 00  ...u............
*dot1xMsgTask: Dec 12 17:52:40.757: 00000010: 01 36 24 73 10 bb 2b 7e  84 3d e0 62 4a 7f 0a f5  .6$s..+~.=.bJ...
*dot1xMsgTask: Dec 12 17:52:40.757: 00000020: 3a bb 17 c7 2f 3c b1 0c  c0 94 70 fb 0e c0 28 b3  :.../<....p...(.
*dot1xMsgTask: Dec 12 17:52:40.757: 00000030: b6 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:40.757: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:40.757: 00000050: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:40.757: 00000060: 00 00 16 dd 14 00 0f ac  04 1a 44 36 b7 64 f6 8d  ..........D6.d..
*dot1xMsgTask: Dec 12 17:52:40.757: 00000070: 8a b1 16 69 2a 75 fe bd  d8                       ...i*u...
*osapiBsnTimer: Dec 12 17:52:41.756: 5c:0a:5b:47:66:c3 802.1x 'timeoutEvt' Timer expired for station 5c:0a:5b:47:66:c3 and for message = M2
*dot1xMsgTask: Dec 12 17:52:41.757: 5c:0a:5b:47:66:c3 Retransmit 2 of EAPOL-Key M1 (length 121) for mobile 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 12 17:52:41.757: 5c:0a:5b:47:66:c3 Sending 802.11 EAPOL message  to mobile 5c:0a:5b:47:66:c3 WLAN 2, AP WLAN 2
*dot1xMsgTask: Dec 12 17:52:41.757: 00000000: 02 03 00 75 02 00 8a 00  10 00 00 00 00 00 00 00  ...u............
*dot1xMsgTask: Dec 12 17:52:41.757: 00000010: 02 36 24 73 10 bb 2b 7e  84 3d e0 62 4a 7f 0a f5  .6$s..+~.=.bJ...
*dot1xMsgTask: Dec 12 17:52:41.757: 00000020: 3a bb 17 c7 2f 3c b1 0c  c0 94 70 fb 0e c0 28 b3  :.../<....p...(.
*dot1xMsgTask: Dec 12 17:52:41.757: 00000030: b6 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:41.757: 00000040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:41.757: 00000050: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
*dot1xMsgTask: Dec 12 17:52:41.757: 00000060: 00 00 16 dd 14 00 0f ac  04 1a 44 36 b7 64 f6 8d  ..........D6.d..
*dot1xMsgTask: Dec 12 17:52:41.757: 00000070: 8a b1 16 69 2a 75 fe bd  d8                       ...i*u...
*osapiBsnTimer: Dec 12 17:52:42.756: 5c:0a:5b:47:66:c3 802.1x 'timeoutEvt' Timer expired for station 5c:0a:5b:47:66:c3 and for message = M2
*dot1xMsgTask: Dec 12 17:52:42.757: 5c:0a:5b:47:66:c3 Retransmit failure for EAPOL-Key M1 to mobile 5c:0a:5b:47:66:c3, retransmit count 3, mscb deauth count 0
*dot1xMsgTask: Dec 12 17:52:42.757: 5c:0a:5b:47:66:c3 Sent Deauthenticate to mobile on BSSID 0c:d9:96:9d:1b:20 slot 0(caller 1x_ptsm.c:534)
*dot1xMsgTask: Dec 12 17:52:42.757: 5c:0a:5b:47:66:c3 Scheduling deletion of Mobile Station:  (callerId: 57) in 10 seconds
Note that other clients work fine with this AP. What it could be? Help please.
10 REPLIES 10
Highlighted
Yury,
Is only 1 specific client acting like this ?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Highlighted
Maybe there are more, while one complained. And then I checked four clients with the same APs works well.
Highlighted
We need to confirm this .. You may only have one client acting up .. The client you have in your first post .. What kind of client is it ?
Highlighted
It is Samsung Galaxy S3, Android 4.1. If it was a laptop, it would be easier, I can run sniffer on it and see the traffic.
Highlighted
I recently tested the S3 and she wouldnt roam. She dropped each time and waited for a minute before attempting to rejoin. you can sniff with andorid. but, you can still sniff the S3 traffic from the laptop. So i dont know what you would gain by actually sniffin in the S3 itself. Frames are frames ..
What you really need is some type of debug on the S3.
http://www.kismetwireless.net/android-pcap/
https://play.google.com/store/apps/details?id=net.kismetwireless.android.pcapcapture
Highlighted
Seeing the frames I can be understood, the client sent a EAPOL response on the request or not. In the description android-pcap:
Capturing from the internal Wi-Fi on Android is not typically possible.
May be I can to deny client on the specific point? And at the same time to the other APs it was allowed?
Highlighted
I'm sorry but I must not be understanding .. You can sniff the frames of the s3 from your laptop.
The issue is the s3. Perhaps looking on the Samsung forums someone might have a fix.
As for the android .. That is from the internal card .. You could ise a external adapter .. Again just to turn it into a pcap sniffer
Highlighted
Yes I can sniff, but is there anything not encrypted?
I looked at the controllers logs and found that not only this client have a problem. For some there are similar but not as frequently and significantly. I'm beginning to doubt that the case samsung galaxy s3.
Logs except client (#cat log  | grep retransmissions | grep -v "5c:0a:5b:47:66:c3"):
*dot1xMsgTask: Dec 13 18:30:30.300: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 44:d8:84:65:15:ad
*dot1xMsgTask: Dec 13 18:26:04.360: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 44:d8:84:65:15:ad
*dot1xMsgTask: Dec 13 18:26:04.360: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 18:26:01.360: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 3c:d0:f8:4f:0d:08
*dot1xMsgTask: Dec 13 18:21:15.752: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 00:26:37:13:7e:73
*dot1xMsgTask: Dec 13 18:21:15.752: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 74:e2:f5:20:b9:a6
*dot1xMsgTask: Dec 13 17:51:03.652: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 3c:d0:f8:1e:13:20
*dot1xMsgTask: Dec 13 17:46:56.236: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 17:46:19.628: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 17:41:15.012: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client e4:ce:8f:bc:54:a3
*dot1xMsgTask: Dec 13 17:28:43.956: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 34:51:c9:9c:a2:56
*dot1xMsgTask: Dec 13 17:25:15.825: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 3c:d0:f8:4f:0d:08
*dot1xMsgTask: Dec 13 17:25:15.825: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 18:87:96:62:44:e5
*dot1xMsgTask: Dec 13 17:25:11.625: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client c0:9f:42:58:56:f4
*dot1xMsgTask: Dec 13 17:20:56.209: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client e4:ce:8f:bc:54:a3
*dot1xMsgTask: Dec 13 17:20:56.209: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 68:09:27:7c:3b:c5
*dot1xMsgTask: Dec 13 16:58:39.761: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 50:ea:d6:e8:b3:e2
*dot1xMsgTask: Dec 13 16:58:27.761: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 50:ea:d6:e8:b3:e2
*dot1xMsgTask: Dec 13 16:54:45.545: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 74:e2:f5:dc:55:6c
*dot1xMsgTask: Dec 13 16:54:45.545: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 16:54:45.545: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 10:9a:dd:0e:37:dd
*dot1xMsgTask: Dec 13 16:43:48.525: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 50:ea:d6:e8:b3:e2
*dot1xMsgTask: Dec 13 16:25:13.360: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 00:23:6c:2b:40:9b
*dot1xMsgTask: Dec 13 16:25:13.360: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 28:cf:da:85:72:bf
*dot1xMsgTask: Dec 13 16:25:13.360: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 3c:d0:f8:4f:0d:08
*dot1xMsgTask: Dec 13 16:24:39.152: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 10:9a:dd:07:d7:de
*dot1xMsgTask: Dec 13 16:20:46.744: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 50:ea:d6:e8:b3:e2
*dot1xMsgTask: Dec 13 16:14:19.128: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 44:d8:84:65:15:ad
*dot1xMsgTask: Dec 13 16:06:49.108: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 16:06:39.908: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 16:06:18.108: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 16:06:05.308: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 16:05:36.904: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 44:d8:84:2c:dc:b3
*dot1xMsgTask: Dec 13 16:05:06.304: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 15:55:02.020: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 74:e2:f5:dc:55:6c
*dot1xMsgTask: Dec 13 15:54:03.016: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 30:17:c8:45:f1:2f
*dot1xMsgTask: Dec 13 15:28:07.916: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 34:51:c9:9c:a2:56
*dot1xMsgTask: Dec 13 15:24:48.784: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 00:23:6c:2b:40:9b
*dot1xMsgTask: Dec 13 15:24:48.784: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 50:ea:d6:e8:b3:e2
*dot1xMsgTask: Dec 13 15:24:29.584: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 10:9a:dd:07:d7:de
*dot1xMsgTask: Dec 13 15:12:48.728: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 15:08:37.916: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 50:46:5d:1a:a0:f5
*dot1xMsgTask: Dec 13 15:00:50.304: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 14:56:14.088: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 44:a7:cf:74:28:ab
*dot1xMsgTask: Dec 13 14:55:18.288: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 50:ea:d6:e8:b3:e2
*dot1xMsgTask: Dec 13 14:25:03.293: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 68:09:27:7c:3b:c5
*dot1xMsgTask: Dec 13 14:24:45.293: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 3c:d0:f8:4f:0d:08
*dot1xMsgTask: Dec 13 14:19:26.077: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 50:46:5d:1b:26:b7
*dot1xMsgTask: Dec 13 14:10:49.433: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 14:10:39.433: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 14:10:29.433: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 14:10:19.633: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 14:08:41.625: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 18:87:96:62:44:e5
*dot1xMsgTask: Dec 13 14:07:30.625: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 14:07:16.025: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 14:07:06.225: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 14:06:56.225: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client d4:20:6d:76:e7:5f
*dot1xMsgTask: Dec 13 14:05:54.017: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 13:55:54.593: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 3c:d0:f8:4f:0d:08
*dot1xMsgTask: Dec 13 13:52:41.985: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 74:e2:f5:dc:55:6c
*dot1xMsgTask: Dec 13 13:44:51.749: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 13:42:37.550: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 10:40:f3:b8:3f:01
*dot1xMsgTask: Dec 13 13:42:01.949: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 00:16:d4:61:67:43
*dot1xMsgTask: Dec 13 13:25:46.384: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:19:d2:bb:33:40
*dot1xMsgTask: Dec 13 13:25:33.376: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:19:d2:bb:33:40
*dot1xMsgTask: Dec 13 13:25:19.176: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:19:d2:bb:33:40
*dot1xMsgTask: Dec 13 13:25:08.776: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 00:19:d2:bb:33:40
*dot1xMsgTask: Dec 13 13:24:03.776: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 50:ea:d6:e8:b3:e2
*dot1xMsgTask: Dec 13 13:24:03.776: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 00:23:6c:2b:40:9b
*dot1xMsgTask: Dec 13 13:19:21.160: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 00:19:d2:bb:33:40
*dot1xMsgTask: Dec 14 10:48:11.660: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:47:19.460: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:47:02.860: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:46:39.860: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:46:09.252: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:46:00.052: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:38:29.028: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:38:01.428: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:37:30.616: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:37:09.016: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:36:50.216: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:36:41.016: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:34:16.812: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:34:07.612: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:33:48.812: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:33:39.612: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:33:20.812: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:33:11.612: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:33:10.004: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 00:23:6c:2b:40:9b
*dot1xMsgTask: Dec 14 10:33:10.004: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 00:16:dc:64:2b:45
*dot1xMsgTask: Dec 14 10:32:52.804: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:32:43.604: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:31:44.804: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:30:56.396: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:30:37.248: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:30:28.049: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:29:14.648: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:29:09.849: %DOT1X-3-WPA_SEND_STATE_ERR: 1x_kxsm.c:1337 Unable to send EAPOL-key msg to client  - invalid WPA state (2) for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 14 10:28:00.997: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 14 10:27:54.848: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:27:13.248: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:26:03.844: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:25:02.244: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 14 10:23:43.263: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 14 10:18:58.224: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:18:28.224: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:16:38.216: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:16:14.816: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:16:05.416: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:15:46.608: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:15:37.408: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:14:05.608: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:13:56.408: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:13:37.604: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:13:28.404: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 14 10:13:04.660: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 14 10:12:59.204: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:12:50.004: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 14 10:12:29.665: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_4: Dec 14 10:12:27.666: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 14 10:12:10.004: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:11:51.204: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:11:42.000: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:11:02.400: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:10:53.200: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:09:42.200: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:09:32.996: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:08:32.396: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:08:29.796: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client a0:0b:ba:e3:ad:d4
*dot1xMsgTask: Dec 14 10:08:23.196: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:06:19.388: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 50:ea:d6:e8:b3:e2
*dot1xMsgTask: Dec 14 10:05:29.388: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:05:08.580: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:04:59.380: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 10:01:36.372: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 74:e2:f5:dc:55:6c
*dot1xMsgTask: Dec 14 09:58:16.756: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client a0:0b:ba:e3:ad:d4
*dot1xMsgTask: Dec 14 09:56:46.956: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:56:37.756: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:52:33.336: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client a0:0b:ba:e3:ad:d4
*dot1xMsgTask: Dec 14 09:43:59.708: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:43:32.100: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:40:51.492: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:39:31.892: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:38:00.692: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:37:42.492: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 44:d8:84:65:15:ad
*dot1xMsgTask: Dec 14 09:37:27.692: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:36:35.288: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client a0:0b:ba:e3:ad:d4
*dot1xMsgTask: Dec 14 09:36:12.088: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:34:40.680: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:33:06.280: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:33:03.480: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 50:ea:d6:e8:b3:e2
*dot1xMsgTask: Dec 14 09:32:45.872: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:31:08.272: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:30:59.072: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:30:58.272: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client a0:0b:ba:e3:ad:d4
*dot1xMsgTask: Dec 14 09:30:16.925: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:30:07.725: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:29:49.325: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:29:40.125: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:29:12.525: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:26:08.117: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:25:58.917: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:25:27.917: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:25:06.917: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:24:45.717: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:24:29.517: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:24:14.109: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 14 09:13:36.281: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M3 retransmissions exceeded for client 3c:d0:f8:1e:13:20
*apfMsConnTask_4: Dec 14 09:11:19.057: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_4: Dec 14 09:09:37.980: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_4: Dec 14 09:08:52.861: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 14 06:35:19.753: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 34:51:c9:9c:a2:56
*dot1xMsgTask: Dec 14 04:29:42.673: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 8c:fa:ba:8f:92:c2
*dot1xMsgTask: Dec 14 01:27:59.761: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 8c:fa:ba:8f:92:c2
*dot1xMsgTask: Dec 13 22:26:20.148: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 8c:fa:ba:8f:92:c2
*dot1xMsgTask: Dec 13 22:26:20.148: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client f0:b4:79:18:29:30
*dot1xMsgTask: Dec 13 21:26:14.634: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 8c:fa:ba:8f:92:c2
*dot1xMsgTask: Dec 13 20:27:07.333: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 44:d8:84:2c:dc:b3
*dot1xMsgTask: Dec 13 20:25:55.125: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client d8:a2:5e:61:12:c5
*dot1xMsgTask: Dec 13 19:46:46.621: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 44:d8:84:aa:63:33
*dot1xMsgTask: Dec 13 19:36:50.593: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 50:46:5d:1b:26:b7
*dot1xMsgTask: Dec 13 19:26:57.840: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M5 retransmissions exceeded for client 3c:d0:f8:1e:13:20
*dot1xMsgTask: Dec 13 18:33:59.504: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:33:50.304: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:33:00.104: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:32:50.904: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:32:00.904: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:31:51.704: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:30:57.500: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:30:30.100: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:30:10.500: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:28:37.096: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:27:34.168: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:24:19.952: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:24:10.752: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:23:31.752: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:23:11.752: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:23:02.552: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:20:06.748: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:19:57.548: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:18:45.744: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:18:36.544: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:18:08.944: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:17:19.744: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:16:48.544: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:16:24.332: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:16:03.732: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:15:46.732: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:14:52.732: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:14:34.332: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:14:24.932: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:07:40.117: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:606 Client 5c:0a:5b:47:66:c3 may be using an incorrect PSK
*dot1xMsgTask: Dec 13 18:07:40.116: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:07:30.716: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:07:14.116: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 18:07:04.916: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 17:58:57.674: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 17:44:55.628: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:44:42.228: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:44:29.028: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:38:04.804: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:37:55.604: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:37:46.400: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:30:38.968: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:30:19.168: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:29:55.168: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:29:05.556: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 17:28:45.890: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_4: Dec 13 17:25:56.863: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_4: Dec 13 17:21:32.173: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 17:20:47.010: %DOT1X-3-WPA_SEND_STATE_ERR: 1x_kxsm.c:1337 Unable to send EAPOL-key msg to client  - invalid WPA state (2) for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:20:45.609: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 17:20:17.897: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_4: Dec 13 17:19:25.710: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_4: Dec 13 17:19:01.777: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_4: Dec 13 17:17:06.954: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_4: Dec 13 17:16:19.501: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 17:15:53.201: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:14:08.401: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:13:28.989: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:13:19.589: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:13:00.989: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:12:51.789: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:11:30.389: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:11:21.190: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:10:39.589: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:10:21.789: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:09:37.985: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:08:00.785: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:07:35.781: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 17:07:26.381: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 17:03:59.348: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 16:55:22.753: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:55:13.553: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 16:55:08.177: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 16:54:20.545: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:54:06.345: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:53:46.345: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:53:25.945: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:47:30.333: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:47:21.133: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:45:16.325: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:43:46.125: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:43:08.125: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:42:40.725: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:42:13.325: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:41:43.721: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:41:23.521: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:41:03.321: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:40:43.121: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:40:22.921: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:40:02.521: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:39:42.317: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:39:22.117: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:38:51.117: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:38:14.117: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:37:29.509: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:36:37.509: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:36:28.309: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:36:19.109: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:29:57.098: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:606 Client 5c:0a:5b:47:66:c3 may be using an incorrect PSK
*dot1xMsgTask: Dec 13 16:29:57.097: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:29:47.697: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:29:23.697: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:29:14.493: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:28:50.493: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:26:21.160: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 16:24:55.956: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 16:06:49.109: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:606 Client 00:16:d4:61:67:43 may be using an incorrect PSK
*dot1xMsgTask: Dec 13 16:03:29.492: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 16:01:48.432: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 15:54:44.182: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*apfMsConnTask_2: Dec 13 15:54:37.497: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:17:c8:45:f1:2f.
*dot1xMsgTask: Dec 13 15:53:27.216: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:52:58.016: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_2: Dec 13 15:48:04.666: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 30:17:c8:45:f1:2f.
*apfMsConnTask_4: Dec 13 15:24:32.147: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 15:21:53.972: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:20:51.768: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:18:29.352: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:13:17.140: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:12:49.728: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:12:20.528: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:12:11.328: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:11:33.528: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:09:40.324: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:01:41.904: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 15:01:03.904: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:59:12.896: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 14:54:20.459: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 14:48:33.868: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:45:26.464: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:45:06.264: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:44:14.664: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:43:54.464: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:42:42.060: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:42:21.860: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:42:01.660: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:40:57.652: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:40:09.452: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:39:40.852: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:39:22.252: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:39:13.052: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:38:51.244: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:38:42.044: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:38:18.044: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:38:03.844: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:37:18.644: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 14:24:08.445: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*Dot1x_NW_MsgTask_7: Dec 13 14:19:16.981: %DOT1X-3-INVALID_WPA_KEY_STATE: 1x_eapkey.c:2066 Received EAPOL-key message while in invalid state (0) - version 1, type 3, descriptor 2, client 50:46:5d:1b:26:b7
*dot1xMsgTask: Dec 13 14:10:49.434: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:606 Client d4:20:6d:76:e7:5f may be using an incorrect PSK
*dot1xMsgTask: Dec 13 14:08:45.425: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:08:24.625: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:07:45.825: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:07:30.626: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:606 Client d4:20:6d:76:e7:5f may be using an incorrect PSK
*dot1xMsgTask: Dec 13 14:07:22.425: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:07:07.825: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:02:11.801: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:01:51.601: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:01:31.401: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:01:08.001: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:00:47.801: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:00:27.602: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 14:00:07.402: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:59:47.193: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:59:26.993: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:59:06.793: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:58:46.593: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:58:26.393: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:58:06.193: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:57:33.389: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:57:13.189: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:56:52.989: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:56:32.789: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:56:05.989: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:55:53.789: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*apfMsConnTask_4: Dec 13 13:53:56.691: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 13:53:22.985: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:52:52.185: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:52:29.785: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:52:09.585: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:51:49.385: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:51:18.377: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:50:57.777: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:50:37.578: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:50:17.377: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:49:46.377: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:49:26.177: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:49:05.969: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:48:45.769: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:48:24.969: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:48:04.769: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:47:44.169: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:47:23.969: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:47:03.757: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:46:43.557: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:46:23.357: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:46:03.157: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:45:42.157: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:45:22.957: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:40:20.345: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:38:53.745: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:38:32.937: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:36:49.137: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:36:33.537: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:35:38.929: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:35:18.929: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:34:58.729: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:33:25.325: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:31:28.513: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:30:41.313: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:30:32.113: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:30:08.513: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:28:31.513: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:25:46.384: %DOT1X-3-PSK_CONFIG_ERR: 1x_ptsm.c:606 Client 00:19:d2:bb:33:40 may be using an incorrect PSK
*apfMsConnTask_4: Dec 13 13:23:44.754: %APF-3-CHECK_SUPP_RATES_FAILED: apf_utils.c:179 Could not check supported rates. Invalid Supported Rates from station . Length :0. Mobile MAC: 00:16:dc:64:2b:45.
*dot1xMsgTask: Dec 13 13:17:16.948: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:17:07.748: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:16:27.748: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:16:18.548: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:15:33.348: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:15:24.148: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:14:50.144: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:12:46.736: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:12:37.536: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:11:52.536: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:10:47.136: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:09:37.128: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:07:28.520: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:06:58.920: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:06:49.720: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:06:20.320: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:06:11.112: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
*dot1xMsgTask: Dec 13 13:05:33.512: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 5c:0a:5b:47:66:c3
Highlighted
Beginner
I have the same problem now with 8540 WLC and 3800 APs in flex connect. I can see a timeout even occurring during M2 event in the handshake process.
The issue got resolved once I restarted the AP which client was connected to. I do not see a bug associated with this issue. Any permanent fix would be encouraged.
Client debug log:
*apfMsConnTask_3: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx Sending assoc-resp with status 0 station:xx:xx:xx:xx:xx:xx AP:28:6f:7f:18:b3:8f-01 on apVapId 1
*apfMsConnTask_3: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx VHT Operation IE: width 40/0 ch 157 freq0 0 freq1 0 msc0 0x3f msc1 0x3f
*apfMsConnTask_3: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx Including FT Mobility Domain IE (length 5) in Initial assoc Resp to mobile
*apfMsConnTask_3: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx Sending R1KH-ID as 84:3d:c6:0f:a6:e5
*apfMsConnTask_3: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx Sending R0KH-ID as:10.29.22.81
*apfMsConnTask_3: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx Including FT IE (length 98) in Initial Assoc Resp to mobile
*apfMsConnTask_3: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx Clearing the existing FT session data for mobile as we received a fresh Association.
*apfMsConnTask_3: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx Sending Assoc Response (status: '0') to station on AP SAP21B55H-2-16 on BSSID 28:6f:7f:18:b3:8f ApVapId 1 Slot 1, mobility role 0
*apfMsConnTask_3: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx apfProcessAssocReq (apf_80211.c:10966) Changing state for mobile xx:xx:xx:xx:xx:xx on AP 28:6f:7f:18:b3:80 from Associated to Associated
*spamApTask5: Mar 01 17:09:47.219: [PA] xx:xx:xx:xx:xx:xx Successful transmission of LWAPP Add-Mobile to AP 28:6f:7f:18:b3:80
*spamApTask5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Received ADD_MOBILE ack - Initiating 1x to STA xx:xx:xx:xx:xx:xx (idx 62)
*spamApTask5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Sent dot1x auth initiate message for mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx reauth_sm state transition 0 ---> 1 for mobile xx:xx:xx:xx:xx:xx at 1x_reauth_sm.c:47
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Creating a PKC PMKID Cache entry for station xx:xx:xx:xx:xx:xx (RSN 2)
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Resetting MSCB PMK Cache Entry 0 for station xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Adding BSSID 28:6f:7f:18:b3:8f to PMKID cache at index 0 for station xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] New PMKID: (16)
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] [0000] dd de 46 77 7d 39 5d 69 7c b0 98 05 dd 5b a7 ec
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Creating global PMK cache for this TGr client
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Created PMK Cache Entry for TGr AKM:PSK xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx R0KH-ID:10.29.22.81 R1KH-ID:84:3d:c6:0f:a6:e5 MSK Len:48
pmkValidTime:86398
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx apfCreatePmkCacheEntry: added a new pmk cache entry for xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Adding Audit session ID payload in Mobility handoff
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx 4 PMK-update groupcast messages sent
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Initiating RSN PSK to mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx EAP-PARAM Debug - eap-params for Wlan-Id :1 is disabled - applying Global eap timers and retries
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Disable re-auth, use PMK lifetime.
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx dot1x - moving mobile xx:xx:xx:xx:xx:xx into Force Auth state
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Skipping EAP-Success to mobile xx:xx:xx:xx:xx:xx (encryptBit:0)
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx key Desc Version FT - 1
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Found an cache entry for BSSID 28:6f:7f:18:b3:8f in PMKID cache at index 0 of station xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] Including PMKID in M1 (16)
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] M1 - Key Data: (22)
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] [0000] dd 14 00 0f ac 04 dd de 46 77 7d 39 5d 69 7c b0
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] [0016] 98 05 dd 5b a7 ec
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Starting key exchange to mobile xx:xx:xx:xx:xx:xx, data packets will be dropped
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Sending EAPOL-Key Message to mobile xx:xx:xx:xx:xx:xx
state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.222: [PA] xx:xx:xx:xx:xx:xx Allocating EAP Pkt for retransmission to mobile xx:xx:xx:xx:xx:xx
*dot1xSocketTask: Mar 01 17:09:47.224: [PA] xx:xx:xx:xx:xx:xx validating eapol pkt: key version = 3
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.224: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-Key from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.224: [PA] xx:xx:xx:xx:xx:xx key Desc Version FT - 1
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.224: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-key in PTK_START state (message 2) from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.224: [PA] xx:xx:xx:xx:xx:xx Encryption Policy: 4, PTK Key Length: 48
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.224: [PA] R1KHID+S1KHID: (12)
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.224: [PA] [0000] 84 3d c6 0f a6 e5 d0 c5 f3 26 6c ed
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.224: [PA] xx:xx:xx:xx:xx:xx Successfully computed PTK from PMK!!!
*Dot1x_NW_MsgTask_5: Mar 01 17:09:47.224: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-key M2 with invalid MIC from mobile xx:xx:xx:xx:xx:xx version 3
*osapiBsnTimer: Mar 01 17:09:48.335: [PA] xx:xx:xx:xx:xx:xx 802.1x 'timeoutEvt' Timer expired for station xx:xx:xx:xx:xx:xx and for message = M2
*Dot1x_NW_MsgTask_5: Mar 01 17:09:48.335: [PA] xx:xx:xx:xx:xx:xx Retransmit 1 of EAPOL-Key M1 (length 121) for mobile xx:xx:xx:xx:xx:xx
*dot1xSocketTask: Mar 01 17:09:48.336: [PA] xx:xx:xx:xx:xx:xx validating eapol pkt: key version = 3
*Dot1x_NW_MsgTask_5: Mar 01 17:09:48.336: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-Key from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:48.336: [PA] xx:xx:xx:xx:xx:xx key Desc Version FT - 1
*Dot1x_NW_MsgTask_5: Mar 01 17:09:48.336: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-key in PTK_START state (message 2) from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_5: Mar 01 17:09:48.336: [PA] xx:xx:xx:xx:xx:xx Encryption Policy: 4, PTK Key Length: 48
*Dot1x_NW_MsgTask_5: Mar 01 17:09:48.336: [PA] R1KHID+S1KHID: (12)
*Dot1x_NW_MsgTask_5: Mar 01 17:09:48.336: [PA] [0000] 84 3d c6 0f a6 e5 d0 c5 f3 26 6c ed
*Dot1x_NW_MsgTask_5: Mar 01 17:09:48.336: [PA] xx:xx:xx:xx:xx:xx Successfully computed PTK from PMK!!!
*Dot1x_NW_MsgTask_5: Mar 01 17:09:48.336: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-key M2 with invalid MIC from mobile xx:xx:xx:xx:xx:xx version 3
Highlighted
Retransmit failure for EAPOL-Key M1 to mobile 5c:0a:5b:47:66:c3,
You can try increasing the EAPOL Key value under WLC to 3 or 4 seconds.
Security -> Advanced EAP
This should clear the problem. The default value is 2 , which needs to be increased on busy environments.
Content for Community-Ad
