12-04-2012 12:57 PM - edited 07-03-2021 11:10 PM
I wanted to see if anyone could point me in the right direction. I have a office network that was setup before I started. We have a 172. subnet and a 10.2 subnet. When users on Wifi get a 10.2 address ( ran out of 172 address ) they are not able to get out to the internet. But if the laptop is connected to a LAN port and get a 10.2 address they are able to get to the Internet. Not sure if its the Aps I need to configure or the Pix seeing that if they get a LAN address of 10.2 everything works.
This is becoming a bigger issue now that the company has out grown its main subnet (172.) Any suggestions or conmand that I can try that would help me out would be greatly appreacted .
Thanks Mike B
APs= AIR-AP1231G-A-K9
Vlan = 172.16.1.XXX
Vlan2= 10.2.0.XXX
Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz
Solved! Go to Solution.
12-05-2012 08:16 AM
you can just paste in the config of the AP.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
12-04-2012 01:24 PM
Would be nice if you can post your configuration.
12-04-2012 01:36 PM
how do I load the configs? I dont see any insert notepad just image or video.
12-05-2012 08:16 AM
HTH,
Steve
12-10-2012 07:36 AM
Stephen here you go , I wasnt able to copy and past last week all it gave me was add picture or add link.
version 12.3
no service pad
service password-encryption
hostname MainConferencesRoom
enable secret 5
username admin privilege
ip subnet-zero
no aaa new-model
dot11 ssid aironet
vlan 1
authentication open
guest-mode
infrastructure-ssid optional
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid aironet
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
antenna receive right
antenna transmit right
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 172.16.1.103 255.255.255.0
no ip route-cache
ip default-gateway 172.16.1.2
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
control-plane
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
MainConferencesRoom#
Switch ( Fast Ethernet 4/1 is the one Im trying to configure )
014510sw.pvi.austinfoam.com#sh run
Building configuration...
Current configuration : 20016 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service compress-config
hostname 014510sw.
logging buffered notifications
logging rate-limit 10 except critical
logging cns-events debugging
enable password 7 1236372037272045626160
username administrator privilege 15 secret 5
vtp domain afp-pville
vtp mode transparent
ip subnet-zero
ip dhcp ping packets 0
spanning-tree mode pvst
spanning-tree vlan 1 priority 24576
power redundancy-mode redundant
redundancy
mode rpr
vlan 2
name Vlan2_worstations
vlan 3
name Vlan3_production_floor_devices
vlan 4
name SAN
vlan 30
name Shoretel
vlan 100
interface GigabitEthernet1/1
description uplink to 013500sw.pvi (top switch in skybox)
switchport trunk allowed vlan 1,2
switchport mode trunk
logging event link-status
interface GigabitEthernet1/2
description uplink to 023500sw.pvi (middle switch in skybox)
interface GigabitEthernet2/1
description uplink to 033500sw.pvi (bottom switch in skybox)
interface GigabitEthernet2/2
interface FastEthernet3/1
interface FastEthernet3/2
interface FastEthernet3/3
interface FastEthernet3/4
interface FastEthernet3/5
interface FastEthernet3/6
interface FastEthernet3/7
interface FastEthernet3/8
interface FastEthernet3/9
interface FastEthernet3/10
interface FastEthernet3/11
interface FastEthernet3/12
description old uplink to lab 2900
interface FastEthernet3/13
interface FastEthernet3/14
interface FastEthernet3/15
interface FastEthernet3/16
interface FastEthernet3/17
description port d-121 in IT room west wall
switchport mode access
interface FastEthernet3/18
interface FastEthernet3/19
interface FastEthernet3/20
switchport access vlan 2
interface FastEthernet3/21
interface FastEthernet3/22
interface FastEthernet3/23
interface FastEthernet3/24
description uplink to shipping west aironet 172.16.1.35
interface FastEthernet3/25
interface FastEthernet3/26
description uplink to adminsouth aironet 172.16.1.30
interface FastEthernet3/27
interface FastEthernet3/28
interface FastEthernet3/29
interface FastEthernet3/30
interface FastEthernet3/31
interface FastEthernet3/32
interface FastEthernet3/33
description eddie's desk
switchport trunk native vlan 2
switchport trunk allowed vlan 2,30
interface FastEthernet3/34
interface FastEthernet3/35
interface FastEthernet3/36
interface FastEthernet3/37
interface FastEthernet3/38
interface FastEthernet3/39
interface FastEthernet3/40
interface FastEthernet3/41
interface FastEthernet3/42
interface FastEthernet3/43
interface FastEthernet3/44
interface FastEthernet3/45
interface FastEthernet3/46
interface FastEthernet3/47
interface FastEthernet3/48
interface FastEthernet4/1
description uplink to main conference room aironet 172.16.1.103
switchport nonegotiate
interface FastEthernet4/2
interface FastEthernet4/3
interface FastEthernet4/4
interface FastEthernet4/5
interface FastEthernet4/6
interface FastEthernet4/7
interface FastEthernet4/8
interface FastEthernet4/9
interface FastEthernet4/10
interface FastEthernet4/11
interface FastEthernet4/12
interface FastEthernet4/13
interface FastEthernet4/14
interface FastEthernet4/15
interface FastEthernet4/16
interface FastEthernet4/17
interface FastEthernet4/18
interface FastEthernet4/19
interface FastEthernet4/20
interface FastEthernet4/21
interface FastEthernet4/22
interface FastEthernet4/23
description starsky owen
interface FastEthernet4/24
interface FastEthernet4/25
interface FastEthernet4/26
interface FastEthernet4/27
interface FastEthernet4/28
interface FastEthernet4/29
interface FastEthernet4/30
interface FastEthernet4/31
interface FastEthernet4/32
interface FastEthernet4/33
interface FastEthernet4/34
interface FastEthernet4/35
interface FastEthernet4/36
interface FastEthernet4/37
interface FastEthernet4/38
interface FastEthernet4/39
interface FastEthernet4/40
interface FastEthernet4/41
interface FastEthernet4/42
interface FastEthernet4/43
interface FastEthernet4/44
interface FastEthernet4/45
interface FastEthernet4/46
description howard/kayla office
interface FastEthernet4/47
description ricky lang
interface FastEthernet4/48
interface FastEthernet5/1
interface FastEthernet5/2
interface FastEthernet5/3
interface FastEthernet5/4
interface FastEthernet5/5
interface FastEthernet5/6
interface FastEthernet5/7
interface FastEthernet5/8
interface FastEthernet5/9
interface FastEthernet5/10
interface FastEthernet5/11
interface FastEthernet5/12
interface FastEthernet5/13
interface FastEthernet5/14
interface FastEthernet5/15
interface FastEthernet5/16
interface FastEthernet5/17
interface FastEthernet5/18
interface FastEthernet5/19
interface FastEthernet5/20
interface FastEthernet5/21
interface FastEthernet5/22
interface FastEthernet5/23
interface FastEthernet5/24
interface FastEthernet5/25
interface FastEthernet5/26
interface FastEthernet5/27
interface FastEthernet5/28
interface FastEthernet5/29
interface FastEthernet5/30
interface FastEthernet5/31
interface FastEthernet5/32
interface FastEthernet5/33
interface FastEthernet5/34
interface FastEthernet5/35
interface FastEthernet5/36
interface FastEthernet5/37
interface FastEthernet5/38
interface FastEthernet5/39
interface FastEthernet5/40
interface FastEthernet5/41
interface FastEthernet5/42
interface FastEthernet5/43
interface FastEthernet5/44
interface FastEthernet5/45
interface FastEthernet5/46
interface FastEthernet5/47
interface FastEthernet5/48
interface GigabitEthernet6/1
interface GigabitEthernet6/2
interface GigabitEthernet6/3
description uplink to dell sw in lab "e 1/50"
interface GigabitEthernet6/4
interface GigabitEthernet6/5
interface GigabitEthernet6/6
interface GigabitEthernet6/7
interface GigabitEthernet6/8
interface GigabitEthernet6/9
interface GigabitEthernet6/10
interface GigabitEthernet6/11
description dell 1U shoretel director
switchport access vlan 30
interface GigabitEthernet6/12
description shoretel sg50 00:10:49:0c:bb:a0
interface GigabitEthernet6/13
interface GigabitEthernet6/14
interface GigabitEthernet6/15
description shoretel director
interface GigabitEthernet6/16
description shoretel sg 50
interface GigabitEthernet6/17
description IP phone test
interface GigabitEthernet6/18
interface GigabitEthernet6/19
interface GigabitEthernet6/20
interface GigabitEthernet6/21
interface GigabitEthernet6/22
interface GigabitEthernet6/23
interface GigabitEthernet6/24
interface GigabitEthernet6/25
interface GigabitEthernet6/26
interface GigabitEthernet6/27
interface GigabitEthernet6/28
interface GigabitEthernet6/29
interface GigabitEthernet6/30
interface GigabitEthernet6/31
interface GigabitEthernet6/32
interface GigabitEthernet6/33
description uplink from att ds3
switchport access vlan 100
interface GigabitEthernet6/34
description uplink to 01515fw.(outside)
speed 100
duplex full
interface GigabitEthernet6/35
description uplink to 012851rt.pvi.austinfoam.com gigabitEthernet0/1(outside)
interface GigabitEthernet6/36
description uplink to 022851rt. gigabitEthernet0/1(outside)
interface GigabitEthernet6/37
description ovpn01.outside interface
interface GigabitEthernet6/38
description outside vlan port
interface GigabitEthernet6/39
description
interface GigabitEthernet6/40
description clvpn02
interface GigabitEthernet6/41
shutdown
interface GigabitEthernet6/42
shutdown
interface GigabitEthernet6/43
shutdown
interface GigabitEthernet6/44
shutdown
interface GigabitEthernet6/45
shutdown
interface GigabitEthernet6/46
shutdown
interface GigabitEthernet6/47
shutdown
interface GigabitEthernet6/48
shutdown
interface GigabitEthernet7/1
interface GigabitEthernet7/2
interface GigabitEthernet7/3
interface GigabitEthernet7/4
interface GigabitEthernet7/5
interface GigabitEthernet7/6
interface GigabitEthernet7/7
interface GigabitEthernet7/8
interface GigabitEthernet7/9
interface GigabitEthernet7/10
interface GigabitEthernet7/11
interface GigabitEthernet7/12
interface GigabitEthernet7/13
interface GigabitEthernet7/14
interface GigabitEthernet8/1
interface GigabitEthernet8/2
interface GigabitEthernet8/3
interface GigabitEthernet8/4
interface GigabitEthernet8/5
interface GigabitEthernet8/6
interface GigabitEthernet8/7
interface GigabitEthernet8/8
interface GigabitEthernet8/9
interface GigabitEthernet8/10
interface GigabitEthernet8/11
interface GigabitEthernet8/12
interface GigabitEthernet8/13
interface GigabitEthernet8/14
interface GigabitEthernet9/1
interface GigabitEthernet9/2
interface GigabitEthernet9/3
interface GigabitEthernet9/4
interface GigabitEthernet9/5
interface GigabitEthernet9/6
interface GigabitEthernet9/7
interface GigabitEthernet9/8
interface GigabitEthernet9/9
interface GigabitEthernet9/10
interface GigabitEthernet9/11
interface GigabitEthernet9/12
interface GigabitEthernet9/13
interface GigabitEthernet9/14
interface GigabitEthernet9/15
interface GigabitEthernet9/16
interface GigabitEthernet9/17
interface GigabitEthernet9/18
interface GigabitEthernet9/19
interface GigabitEthernet9/20
interface GigabitEthernet9/21
switchport access vlan 4
interface GigabitEthernet9/22
interface GigabitEthernet9/23
interface GigabitEthernet9/24
interface GigabitEthernet9/25
interface GigabitEthernet9/26
interface GigabitEthernet9/27
interface GigabitEthernet9/28
interface GigabitEthernet9/29
interface GigabitEthernet9/30
interface GigabitEthernet9/31
interface GigabitEthernet9/32
interface GigabitEthernet9/33
interface GigabitEthernet9/34
interface GigabitEthernet9/35
interface GigabitEthernet9/36
interface GigabitEthernet9/37
interface GigabitEthernet9/38
interface GigabitEthernet9/39
interface GigabitEthernet9/40
interface GigabitEthernet9/41
interface GigabitEthernet9/42
interface GigabitEthernet9/43
interface GigabitEthernet9/44
interface GigabitEthernet9/45
interface GigabitEthernet9/46
interface GigabitEthernet9/47
interface GigabitEthernet9/48
interface Vlan1
ip address 10.254.254.28 255.255.255.0 secondary
ip address 172.16.1.2 255.255.255.0 secondary
ip address 172.16.1.28 255.255.255.0
no ip redirects
interface Vlan2
description generic office workstation vlan
ip address 10.2.0.254 255.255.255.0
ip helper-address 172.16.1.70
interface Vlan3
description production floor vlan (handhelds and wyse terms)
ip address 10.3.0.254 255.255.255.0
interface Vlan4
ip address 172.16.20.1 255.255.255.0
interface Vlan30
description vlan 30 gateway
ip address 10.10.100.1 255.255.254.0
interface Vlan100
no ip address
ip route 0.0.0.0 0.0.0.0 172.16.1.1
ip route 10.10.10.0 255.255.255.0 172.16.1.140
ip route 10.69.69.0 255.255.255.0 172.16.1.140
ip route 172.16.2.0 255.255.255.0 172.16.1.140
ip route 172.16.9.0 255.255.255.0 172.16.1.1
ip route 192.168.1.0 255.255.255.0 172.16.1.140
no ip http server
ip http access-class 2
ip http authentication local
logging trap notifications
logging source-interface Vlan1
logging 172.16.1.57
access-list 2 remark acl for http admin
access-list 2 permit 172.16.1.0 0.0.0.255
access-list 100 permit tcp 10.2.0.0 0.0.0.255 any eq www
access-list 100 permit tcp 10.2.0.0 0.0.0.255 any eq 443
access-list 100 deny ip any any
line con 0
stopbits 1
line vty 0 4
access-class 12 in
exec-timeout 30 0
privilege level 15
password
login
transport preferred none
transport input telnet
transport output none
line vty 5 15
privilege level 15
password 7
no login
end
014510sw.#
014510sw.pvi#sh vlan
VLAN Name Status Ports
1 default active Gi2/2, Fa3/1, Fa3/2, Fa3/3
Fa3/4, Fa3/5, Fa3/6, Fa3/7
Fa3/8, Fa3/9, Fa3/10, Fa3/11
Fa3/12, Fa3/13, Fa3/14, Fa3/15
Fa3/16, Fa3/17, Fa3/18, Fa3/19
Fa3/21, Fa3/25, Fa3/26, Fa3/28
Fa3/29, Fa3/30, Fa3/31, Fa3/32
Fa3/33, Fa3/35, Fa3/38, Fa3/39
Fa3/40, Fa3/41, Fa3/42, Fa3/43
Fa3/44, Fa3/45, Fa3/46, Fa3/47
Fa4/2, Fa4/6, Fa4/7, Fa4/8
Fa4/9, Fa4/11, Fa4/12, Fa4/13
Fa4/14, Fa4/16, Fa4/17, Fa4/19
Fa4/20, Fa4/24, Fa4/25, Fa4/26
Fa4/28, Fa4/31, Fa4/32, Fa4/34
Fa4/35, Fa4/36, Fa4/37, Fa4/41
Fa4/42, Fa4/43, Fa4/44, Fa4/47
Fa4/48, Fa5/2, Fa5/6, Fa5/9
Fa5/10, Fa5/11, Fa5/12, Fa5/13
Fa5/14, Fa5/15, Fa5/16, Fa5/17
Fa5/19, Fa5/20, Fa5/21, Fa5/23
Fa5/25, Fa5/27, Fa5/28, Fa5/29
Fa5/31, Fa5/32, Fa5/35, Fa5/37
Fa5/38, Fa5/39, Fa5/40, Fa5/41
Fa5/42, Fa5/43, Fa5/44, Fa5/47
Fa5/48, Gi6/1, Gi6/2, Gi6/4
Gi6/5, Gi6/6, Gi6/7, Gi6/8
Gi6/9, Gi6/10, Gi6/13, Gi6/14
Gi6/20, Gi6/21, Gi6/22, Gi6/23
Gi6/24, Gi6/25, Gi6/26, Gi6/27
Gi6/28, Gi6/29, Gi6/30, Gi6/31
Gi6/32, Gi7/1, Gi7/2, Gi7/3
Gi7/4, Gi7/5, Gi7/6, Gi7/7
Gi7/8, Gi7/9, Gi7/10, Gi7/11
Gi7/12, Gi7/13, Gi7/14, Gi8/1
Gi8/2, Gi8/3, Gi8/4, Gi8/5
Gi8/6, Gi8/7, Gi8/8, Gi8/9
Gi8/10, Gi8/11, Gi8/12, Gi8/13
Gi8/14, Gi9/1, Gi9/2, Gi9/3
Gi9/4, Gi9/6, Gi9/7, Gi9/8
Gi9/9, Gi9/10, Gi9/12, Gi9/13
Gi9/14, Gi9/15, Gi9/16, Gi9/17
Gi9/18, Gi9/19, Gi9/20, Gi9/23
Gi9/24, Gi9/25, Gi9/26, Gi9/27
Gi9/28, Gi9/29, Gi9/30, Gi9/31
Gi9/32, Gi9/33, Gi9/34, Gi9/35
Gi9/36, Gi9/37, Gi9/38, Gi9/39
Gi9/40, Gi9/41, Gi9/42, Gi9/43
Gi9/44, Gi9/45, Gi9/47, Gi9/48
2 Vlan2_worstations active Fa3/20, Fa3/22, Fa3/23, Fa3/27
Fa3/34, Fa3/36, Fa3/37, Fa3/48
Fa4/3, Fa4/4, Fa4/5, Fa4/10
Fa4/15, Fa4/18, Fa4/21, Fa4/22
Fa4/27, Fa4/29, Fa4/30, Fa4/33
Fa4/38, Fa4/39, Fa4/40, Fa4/45
Fa4/46, Fa5/1, Fa5/3, Fa5/4
Fa5/5, Fa5/7, Fa5/8, Fa5/18
Fa5/22, Fa5/24, Fa5/26, Fa5/30
Fa5/33, Fa5/34, Fa5/36, Fa5/45
Fa5/46, Gi6/17, Gi6/18, Gi6/19
Gi9/5, Gi9/11, Gi9/46
3 Vlan3_production_floor_devices active
4 SAN active Gi9/21, Gi9/22
30 Shoretel active Gi6/11, Gi6/12, Gi6/15, Gi6/16
100 VLAN0100 active Gi6/33, Gi6/34, Gi6/35, Gi6/36
Gi6/37, Gi6/38, Gi6/39, Gi6/40
Gi6/41, Gi6/42, Gi6/43, Gi6/44
Gi6/45, Gi6/46, Gi6/47, Gi6/48
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
4 enet 100004 1500 - - - - - 0 0
30 enet 100030 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
014510sw.pvi.austinfoam.com# sh interfaces trunk
Port Mode Encapsulation Status Native vlan
Gi1/1 on 802.1q trunking 1
Gi1/2 on 802.1q trunking 1
Gi2/1 on 802.1q trunking 1
Fa3/24 auto n-802.1q trunking 1
Fa4/1 on 802.1q trunking 1
Fa4/23 on 802.1q trunking 2
Gi6/3 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/1 1-2
Gi1/2 1-2
Gi2/1 1-2
Fa3/24 1-4094
Fa4/1 1-2
Fa4/23 2,30
Gi6/3 1-2
Port Vlans allowed and active in management domain
Gi1/1 1-2
Gi1/2 1-2
Gi2/1 1-2
Fa3/24 1-4,30,100
Fa4/1 1-2
Fa4/23 2,30
Gi6/3 1-2
Port Vlans in spanning tree forwarding state and not pruned
Gi1/1 1-2
Gi1/2 1-2
Gi2/1 1-2
Fa3/24 1-4,30,100
Fa4/1 1-2
Fa4/23 2,30
Gi6/3 2
014510sw.#
12-10-2012 07:58 AM
When the users getting 10.2 connect what SSID are they connections too? Are they static IP?
I only see one SSID linked to VLAN one, but nothing for VLAN two other than the subinterfaces.
So if thy are static and connecting to airport they wouldn't be able to get anywhere since they'd be in the wrong subnet.
Steve
12-10-2012 08:03 AM
We hae one SSID airont , the DHCP server hands out the address and if there is no more 172. the DHCP will will pass out the 10. from vlan2 thru aironet. Which no one with a laptop on the 10 can get out.
Thats my consufion would this issue be in the Cisco or the DHCP server?
12-10-2012 09:09 AM
from your config, nobody should be able to get an address in VLAN 2 on the wireless, unless something is bridged somewhere else. It's all linked to VLAN 1.
But if someone did get an address in VLAN 2, they wouldn't be able to get out, as the SSID is linked to VLAN 1.
HTH,
Steve
12-10-2012 09:13 AM
Ok I need to add the SSID to the 10. /Vlan2 network so user on there laptop are able to get out?
12-10-2012 09:30 AM
an SSID can only be linked to one VLAN. You would need to add another SSID for VLAN 2.
HTH,
Steve
