02-08-2016 03:04 PM - edited 07-05-2021 04:35 AM
I have a AIR-SAP2602IA-K9 access point that is loaded with 15.3(3) JBB (ap3g2-k9w8-mx.153-3.JBB). I have ap3g2-k9w7-mx.153-3.JC copied into flash (15.3.3-JC) but cannot seem to get it to load.
In ROMMON, I set the BOOT variable to flash:/ap3g2-k9w7-mx.153-3.JC and then reboot the AP, but I get an error that the AP cannot find the file or directory. Is there a specific file inside the ap3g2-k9w7-mx-1513-3.JC directory that I need to specify in my boot parameters? Or what are the exact steps to get this AP to boot this new IOS image?
Thanks.
02-08-2016 03:11 PM
Make sense. To convert the AP to autonomous, I'd recommend you download the TAR file from the Cisco website and use the command: archive download-sw tftp://<TFTP IP address>/filename.tar
02-08-2016 03:15 PM
On my AP archive is an "unrecognized command"
I did a tar -xtract command to get the file from my tftp server onto the AP in the first place
02-08-2016 07:08 PM
In that case, issue the command "debug capwap console cli" first and then run the command again.
An easier method is to use the "Mode" button: Using a TFTP Server to Return to a Previous Release
02-08-2016 07:11 PM
I must have had a typo when I set the BOOT variable.....I retraced my steps and now it seems to be working properly.
Thanks for your help
