Highlighted
ahk Beginner
Beginner
Syslog messages from peer redundancy management ip
Good day!
I have 4 controllers 5508 in  2 HA pairs with 8.0.133.0 software.
I noticed strange messages like:
 %CHKPT-4-INVALID: [SS]chkpt_message.c:3047 Invalid checkpoint client ID (0).[...It occurred 8 times/sec!.]
 *spamApTask4: Jul 15 09:03:44.096: %LOG-4-Q_IND: [SS]chkpt_message.c:3047 Invalid checkpoint client ID (0).[...It occurred 7 times.!]
 *spamApTask4: Jul 15 09:03:44.096: %LWAPP-3-INVALID_AID2: [SS]spam_api.c:1588 Association identifier 1 for client ac:fd:ec:a4:84:dd is already in use by ac:fd:ec:a4:84:dd for AP 00:3a:9a:1e:22:c0 slot 0 vap 7
The main strange for me is that the messages comes from address of redundancy standby peer.
Maybe someone knows why this happening? Can this message points to the network or HA problem?
Thanks!
Everyone's tags (1)
13 REPLIES 13
Highlighted
Beginner
I have this same problem too
I have this same problem too on my 5508 HA pair running 8.0.132.0 showing up in Syslog from my standby controller redundancy mgmt port IP. This issue started after migrating primary/secondary controllers to HA pair.
*spamApTask5: Jan 24 07:53:06.303: %LWAPP-3-INVALID_AID2: [PA]spam_api.c:1588 Association identifier 6 for client 5c:8d:4e:dc:7e:33 is already in use by d8:bb:2c:98:d9:48 for AP 70:e4:22:83:14:10 slot 1 vap 4
Highlighted
Rising star
I'm running 8.0.140.0 and
I'm running 8.0.140.0 and also still get syslog messages from the standby WLC.
Please rate helpful / correct posts
Highlighted
we get the same notifications and quite a lot of them too, about 6000 per hour.
%LOG-4-Q_IND: [SS]chkpt_message.c:3047 Invalid checkpoint client ID (0).[...It occurred 3 times.!]
running with 2 AIR-CT5508-K9 on version 8.2.141.0
There is very little to be found on this subject on the internet or the cisco site
Highlighted
You might want to check out
You might want to check out this bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy78583/?reffering_site=dumpcr
it is fixed after 8.0.134.x so 8.0.133.0 can be affected due to this. Kindly upgrade to 8.0.140.0 and see if you still get the messages
Highlighted
Beginner
Re: Syslog messages from peer redundancy management ip
For these messages "%CHKPT-4-INVALID: [SS]chkpt_message.c:3047 Invalid checkpoint client ID (0)."  there is a bug that is opened CSCvf22697.  It is found on a different level of code but it my be the same issue you are seeing.
For the other messages like "%LOG-4-Q_IND: [SS]chkpt_message.c:3047 Invalid checkpoint client ID (0).[...It occurred 3 times.!]"  I can't find anything in the bug search tool but I am going to contact TAC.  I have been complaining for a while about all the background syslog messages/noise.  The workaround has always been reduce the logging level, but if you reduce the logging level you miss stuff when you try to troubleshoot.
Highlighted
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf22697
Help  | Feedback Feedback
Flooding "Invalid checkpoint client ID (0)" message on Standby WLC
CSCvf22697
Description
Symptom:
Following message is appeared a lot on Standby WLC
Conditions:
HA SSO
Workaround:
Configure Logging Level higher than "Error"
Details
Last Modified:
Jan 11,2018
Status:
Fixed
Severity:
3 Moderate
Product:
(1)
Cisco 5500 Series Wireless Controllers
Known Affected Releases:
(1)
8.2(141.0)
Known Fixed Releases:
(4)
8.6(101.0)
8.6(1.73)
8.5(110.0)
8.5(107.23)
Highlighted
VIP Mentor
Good to see you are back in to CSC forum Saravanan, you provide great value to the community.
Keep allocate your time here :)
Rasika
Highlighted
Thanks, Rasika. it is indeed an inspiration and experience.
Highlighted
Enthusiast
Seeing this on many controllers as well.  8.5.131.0, 8.2.164.0 releases.  Was there ever a resolution, other than filtering ?
Highlighted
Beginner
Same issue 5508 - 8.3
Highlighted
VIP Advocate
Which exact 8.3 version? There were some fixes in the past for various HA issues.
Beginner
8.3.143 but its ok I'm going to upgrade to 8.5.140 in 1 month.
Highlighted
Hall of Fame Community Legend
This issue is found in 8.8.120.0 and 8.8.125.0.
Content for Community-Ad
