Beginner
Tracking down High Channel Utilization
Trying to figure out what is causing high channel utilization on 2.4Ghz channels in our environment.
The thing thats really frying my noodle is that if I use spectrum expert to get a look at a channel (Ch. 1 in this case) on a particular AP, this is what I see:
Ie. Almost nothing. To me that channel looks almost bare. The issue is when I look at the WLC Config Analyzer to see what it thinks of my RF conditions, this is what I see:
The Highlighted AP is the AP from the Spectrum Expert shot. The APs that are showing as 100% healthy have had their 2.4Ghz radios disabled in an attempt to cut down on Co-Channel Interference.
As you can see, WLCCA is showing that the channel capacity is 0 (ie. totally utilized). I need to do some more checking but anecdotal reports from users at the site support the WLCCA outlook, ie. that my 2.4Ghz network is fragged.
Can someone give me some tips on how I can track down what is causing such apparent high channel utilization, and help me with some idea's on how to mitigate it. I've already shut down 50% of my 2.4Ghz radios to cut down the Co-Channel interference from them, but that doesn't seem to have made much of a difference.
Any help would be much appreciated.
7 REPLIES 7
What is the AP Model and the WLC firmware?
There is a known bug on x800 AP Series.
Cisco Wave2 APs (Cisco AP2800, 3800, 1850 APs) on 8.2 release: falsely show 100% channel utilization
CSCvd40978
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd40978/?referring_site=bugquickviewredir
I had the same issue on 1850 APs.
Best regards,
Christos
Beginner
The AP's in question are AIR
The APs are AIR-CAP2702I-Z-K9's running v8.2.151.0. The bug states that CleanAir reports spectrum as being clean whilst the AP etc all report high utilization. I can confirm that is what I'm seeing. A CleanAir report run on that AP over the past 2 weeks shows air quality at between 97 and 100 which seems to be what Spectrum Expert is suggesting. The Bug report suggests that this is only a short term problem though, whilst I'm seeing it almost continually and on all of my 2.4Ghz radios in that deployment.
From the screenshot from the WLC GUI you can see that the Channel Utilization and Interference is running at 77%, but the Air Quality metric is 99 (almost perfect).
I guess the question that arises from this is, does this incorrect reporting of channel utilization affect how my APs / WLC will perform in terms of things like RRM?
VIP Advocate
8.2.160.0 has been released,
8.2.160.0 has been released, which is supposed to fix the before mentioned bug:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr6.html
It's supposed to only affect Wave2 APs though, not your 2700 model. Can you, for a test, disable the 5 GHz interface on an affected AP and connect with a client to it and test if everything is working as it should?
Highlighted
Enthusiast
Re: The AP's in question are AIR
Did upgrading to 8.2.160 fix your issues?  I am experiencing the same exact problem.  The controller reports high utilization but spectrum analyzer says otherwise.
VIP Advocate
Do you have inhouse mobile
Do you have inhouse mobile phone amplifiers? They can completely spam your 2.4 GHz if they are within 1-2 meters. I had this issue and my spectrum analizer didn't show anything, but clients were unable to join. Had to move the AP 2 meters to the side to get a good working signal.
Beginner
Re: Tracking down High Channel Utilization
Using 3800  ap with code 8.5.131.6. The channel utilization on Band 5 channel 56 shows 70% with 9 clients. How to track this. No interference factor or rouge showing on the ap.
Hall of Fame Master
Look at the traffic that is being used. If the user is heavily using the wireless like in upload/downloads, etc, that can cause high utilization. If you already determined that there is no interference on that channel, then you need to look at what the users connected to that AP are doing. That isn’t high in my opinion and the users most likely don’t see and degradation in their experience.
-Scott
Content for Community-Ad
August's Community Spotlight Awards
