12-04-2019 06:03 PM - edited 07-05-2021 11:23 AM
is it possible to transfer a new software image to the wlc as backup image and not disturbing the primary boot image?
i need to do this so i can predownload the later new backup image software down to the AP.
Solved! Go to Solution.
12-05-2019 02:39 AM - edited 12-05-2019 02:40 AM
I've checked the manual again, you are right.
So what you can do, upload the "new" image the normal way (this will overwrite the old image in the backup partition), it will be set as Primary. You don't want that, so you can switch it afterwards to the backup partition with the command:
config boot backup
This will set the currently running image back to the boot image. Now you should be able to upgrade your APs with the command:
config ap image predownload backup (or primary)
To see which partition contains which image, enter:
show boot
Manual for WLC upgrade:
12-04-2019 08:44 PM
Yes, you can do it to reduce down time during WLC upgrade
Rasika
*** Pls rate all useful responses ***
12-05-2019 01:43 AM
thanks for the reply.
i am not trying to upgrade the controller.
i am trying to upload the image as backup image on the controller so that i can download the new backup image to AP via GUI.
my objective is during shutdown, i can just change the primary controller in AP HA tab and the AP can reboot and join the new controller w/o the need to download any software.
12-04-2019 11:43 PM
12-05-2019 02:04 AM
config boot backup
show boot
