11-25-2007 02:09 PM - edited 07-03-2021 02:59 PM
Hi all,
I think I know the answer to my post but I would like a second opinion.
I am trying to trunk a Cisco 1200 AP to an ASA 5505. The AP must have a native VLAN on VLAN 1 according to this link:
The ASA 5505 supports trunking but no native VLAN support.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/int5505.html#wp1057200 (see bottom of step 2).
Then I assume that if I want to do this, I'll have to put a switch in the middle, right?
The other option is to use a WLAN controller and tunnel all VLAN within the LWAPP tunnel.
Any other suggestions?
Martin
11-26-2007 10:35 PM
03-26-2008 12:01 PM
Is there any possible way or suggestion other than putting a switch in the middle to accomplish this setup (AP trunk to ASA)? Please advise. Thank you.
03-30-2008 10:28 PM
Are you not able to configure the vlan 1 option on the sub-interface?
interface GigabitEthernet0/2
speed 1000
duplex full
no nameif
no security-level
no ip address
interface GigabitEthernet0/2.1
vlan 1
nameif LWAP
security-level z
ip address x.x.x.x y.y.y.y
