Highlighted
Beginner
Trunking Autonomous Cisco 1140 AP and ASA 5505
I have an Autonomous Cisco 1140 AP running  12.4(21a)JA1. It has two SSIDs in vlan 1 and vlan3. The configs are below:
dot11 ssid A
   vlan 1
dot11 ssid B
   vlan 3
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.3
no ip route-cache
The trunk interface on ASA is something like this:
interface Ethernet0/1
switchport trunk allowed vlan 1,3
switchport trunk native vlan 1
switchport mode trunk
interface Vlan1
nameif A
security-level 100
ip address 10.0.0.1 255.255.255.0
interface Vlan3
nameif B
security-level 10
dhcpd address 10.0.0.10-10.0.0.128 A
dhcpd enable A
dhcpd address 192.168.1.5-192.168.1.200 B
dhcpd enable B
As of now the vlan 1 is performing as desired but hosts on SSID B are getting nothing. Please help.
Thanks in advance.
1 ACCEPTED SOLUTION
Highlighted
Re: Trunking Autonomous Cisco 1140 AP and ASA 5505
no ip route-cache
==> You forgot bridge-group 3 here
Hope this helps
4 REPLIES 4
Highlighted
no ip route-cache
Hope this helps
Highlighted
Beginner
Thank you so much, Nicolas. I put that in the AP, now I have to wait for some users to try it.. I will know only monday morning.
Highlighted
Beginner
Hi Nicholas,
Just checked the status of the network. The Vlan  works perfectly fine. Thanks for the help. The devices on network B get  192.168.1.x addresses.
As a different issue, the devices cant access internet. Can you help me with this?
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0
nat (B) 1 192.168.1.0 255.255.255.0
There is no access list blocking or permitting at interface B
Highlighted
Beginner
I fixed it. It was the DNS. The DHCP server configured for the vlan B did not give out DNS addresses. Thanks
Content for Community-Ad
Cisco COVID-19 Survey
